Iterating to ODEsolve soltution (shooting method)
JM_14109889
I am using Mathcad Prime Release 8.0 and Datecode8.0.0.0
I want to add an iteration process to an ODEsolve block. It would require iterating an initial condition until two of the solutions match.
LucMeekes
(To:JM_14109889)
Answer: T1(0)=202.446 °C
Your problem:
Solve the set of ODE:
Extract the functions:
Check that it's the solution:
Solve the problem to find T10 for T1(L)=T2(L):
Fill in the numbers:
Plot:
Note that Prime 9 and higher (present version is 11) can solve your set of DE symbolically, allowing you to through above exercise.
You can, (in your Prime 8 ) make the solve block be a function of T10 and then numerically solve it. For a simple example see: https://community.ptc.com/t5/Mathcad/Solve-Block-Iteration/m-p/889162
This forum (part) is for installation and licensing problems. For more help, post your problem in the proper forum (part): https://community.ptc.com/t5/Mathcad/bd-p/PTCMathcad
7 REPLIES 7
hi @JM_14109889
Can you please share a sample worksheet?
Dhiraj
Hi @DhirajPatil ,
See attached worksheet.  This worksheet has been simplified down to the basic equations.  Currently I am required to iterate variables until the solution of both equations is equal at "L" (T1(L)=T2(L).  All variables could potentially be iterated to achieve the solution, but most common would be T1(0) or U1.
Thanks.
Hi, I have shared the sample worksheet.
LucMeekes
(To:JM_14109889)
Your problem:
Plot:
JM_14109889
(To:LucMeekes)
Thanks for the reply.  If I'm understanding correctly, I need to upgrade my MathCad version to make use of the above solution.
LucMeekes
(To:JM_14109889)
That is one way. As usual there are several ways (to Rome). So you can also do it the numeric way, by making the result of the solve-block a (set of) function(s) in T10, after which you can solve for the proper T10-value that makes T1(L)=T2(L).
You can also use the symbolics available in Prime 8 to compute the solution via the Laplace transform, which changes the set of ODE into a set of equations, which you solve and then transform back to the x-domain.
That goes like this:
Now with results
Note that in Prime the result may have the laplace integral (definition)
(  Something like LucMeekes_7-1758579389325.png   )
instead of "laplace(T1(x),x,s)" and "laplace(T2(x),x,s)" so you may have to change the substitution below for your needs.
Simplify:
The functions may become big, but they should still be workable.
JM_14109889
(To:LucMeekes)
Thanks!
