3-Newcomer
September 18, 2025
Mathcad Prime 11.0.1.0 updates from 11.0.0.0?
I'm trying to find out what was changed or fixed in datecode 11.0.1.0 compared to 11.0.0.0. If there is a summary of changes/fixes on the website someplace, I haven't been able to find it. I support our company's users and would like to be able to tell them what is changed in 11.0.1.0 before they upgrade their installed version.
18-Opal
September 18, 2025
"Bug Fixes" and  below shows no results.
Hi @PaulOrtmann and @ppal_205706 ,
Please do check the Update Advisor for the fix in Mathcad Prime date code 11.0.0.0 to 11.0.1.0
The issue of the result not being shown has been fixed.
Dhiraj
18-Opal
September 24, 2025
Hi @PaulOrtmann,
You can refer to this Knowledge article:
  • CS132280 How to access Update Advisor on PTC Support website
Note: (We are aware that the list of SPR fixed from Mathcad Prime Date code 11.0.0.0 to 11.0.1.0 are not shown and PTC team is working to fix it)
Dhiraj
18-Opal
September 18, 2025
Dhiraj rakho !
PTC Technical Support Note:
In addition to reviewing the Update Advisor lists generated instantly, please note the following:
  • The x.x.1.x releases are primarily designed for bug fixes that follow a x.x.0.x release.
  • The x.x.1.x releases are based on the x.x.0.0 documents, which remain unchanged.
For instance:
  • Mathcad Prime 10.0.0.0 and 10.0.1.0 are both based on the 2024 product specification, released in Spring and Fall 2024, with respective bug fixes.
  • Mathcad Prime 11.0.0.0 and 11.0.1.0 are both based on the 2025 product specification, released in Spring and Fall 2025, with respective bug fixes.
Please refer to the PTC support articles, which are continuously updated:
  • CS415162 What's New in PTC Mathcad Prime 10.0.0.0 and 10.0.1.0
  • CS440988 What's New in PTC Mathcad Prime 11.0.0.0 and 11.0.1.0
18-Opal
September 24, 2025
