We took a six month hiatus on highlighting Most Noteworthy Posts and Top Community Engagers of the month. We are now ready to resume with this PTC Community Monthly Stand Out post series. Always check back here on the PTC Cooler to see the top community engagers and the top noteworthy posts of the month.
Top July 2022 Community Engagers:
@TomU @VladimirN @tbraxton @MartinHanak @LucMeekes @Werner_E @HelesicPetr @Shashi_Preetham
@nmilleson @StephenW @Dale_Rosema @KK_10171856 @ttokoro @avillanueva @VeqTor @ValeryOchkov
@XQ_10003318 @BenLoosli @S_Edgenear @HD_10225728 @d_graham @ppal @SrikanthM @Marco_Tosin
MOST NOTEWORTHY POSTS
Below are some of the top engaging or most viewed PTC Community topic threads for July 2022! See if your community username made this list! Or, read more about a topic that interests you! (Note: Links to be added soon).
CAD
1. Creo: @Nicolas_G started the topic thread Drawing report-BOM Report Region. Thank you for contributing to the thread @KenFarley @MartinHanak @Dale_Rosema !
https://community.ptc.com/t5/3D-Part-Assembly-Design/Drawing-report-BOM-Repeat-region/m-p/805855
2. Creo: Great collaboration from @tbraxton @kdirth and @AB_9239964 for the Domed Surface topic thread started by @John.Pryal
https://community.ptc.com/t5/3D-Part-Assembly-Design/Domed-surface/m-p/809280
3. Creo: @jferguson4 received an Accepted Solution from @tbraxton for the topic thread Can Shrinkwrap me make to use the existing tellestration on an imported quilted surface.
4. Creo: Thank you @SM_10081957 for coming back and marking the accepted solution when you discovered the answer to your question about Annotate Dimensions. Marking solutions helps other community members to more easily find answers. Thank you @BenLoosli and @Mfridman for participating in the conversation!
https://community.ptc.com/t5/3D-Part-Assembly-Design/Annotate-Dimensions/m-p/808429#M124853
IOT
5. ThingWorx: @HD_10225728 started the topic thread Sending Image from Repository (not download Link) to SharePoint List @PaiChung Senior PTC IoT Technical Architect gave some great feedback. Check it out!
6. ThingWorx: The String replace not working topic by @SB_9732186 is receiving great input from @nmilleson @VP_10348089 @SB_9732186 @M4RC @VladimirRosu and @wcui Feel free to add to this conversation!
https://community.ptc.com/t5/ThingWorx-Developers/String-replace-not-working/m-p/805615
7. ThingWorx: @Shashi_Preetham found an Accepted Solution with the help of @VladimirRosu for the topic Subscriptions are not getting invoked, or delay in the invoke
AR
8. Vuforia Studio: @Velkumar received an Accepted Solution from @sdidier for the topic Vuforia Studio collaboration with other users in runtime. Excellent contribution also in text and images by @Martini3119 and @vkrayushkin
9. Vuforia Studio: @RolandRaytchev provided an Accepted Solution for the topic Navigator/ zones of interest extension created by @KlemenM
https://community.ptc.com/t5/Vuforia-Studio/Navigator-zones-of-interest-extension/m-p/805645
10. Vuforia Studio: @CP_10187386 started the topic Binding ThingWorx infotable to the time series chart in Vuforia studio Great contribution with a screenshot by @RolandRaytchev
PLM
11. Windchill: @SrikanthM is sharing about the Windchill 12.1 in-place Upgrade asking about versions being overwritten. An Accepted Solution by @TomU and great contribution by @BenLoosli @MikeLockwood @RandyJones @LukaszMazur and @ascorupco
https://community.ptc.com/t5/Windchill/WIndchill-12-1-in-place-Upgrade/m-p/808558
12. Windchill: @ES_9976227 received an Accepted Solution from @HelesicPetr for the topic How to change display of lifecycle status indicator (“Production” vs “In Work”). Thank you @avillanueva for also participating!
13. Windchill: What is an IBA? was asked by @jfrancis a resource from the PTC Help Center is shared by @cgorni
https://community.ptc.com/t5/Windchill/What-is-an-IBA/m-p/124226
14. Windchill: @Sathish_Rosario created the topic thread Promotion request status Rejected with an Accepted Solution by @MikeLockwood and contribution by @joe_morton. Thank You for your participation!
https://community.ptc.com/t5/Windchill/Promotion-request-status-REJECTED/m-p/806304
ABORTEXT
15. Arbortext: @vigneshj received an Accepted Solution by @GarethOakes for the topic Arbortext Publishing Engine-Accessing Activation file from network share @VladimirN also contributed to the conversation. Thank You!
16. Arbortext: @GarethOakes shared a PTC Help Center article to answer question by @bfriesen How to set the default stylesheet used by Publishing engine
17. Arbortext: @GregV asked about Licensing Error Gui points toward non-existent host ID An Accepted Solution given by @GarethOakes and contribution by @DmitryTsarev
18. Windchill SSE: @AD_10334222 received an Accepted Solution from @kjain2 for the query Adding requirement to a test case via cmd
Mathcad
19. Mathcad: @LearningENG11 asked about Extracting Rows based on Array Values and received an Accepted Solution from @LucMeekes Thank you @terryhendicott and @Werner_E for contributing to the conversation!
https://community.ptc.com/t5/Mathcad/Extracting-Rows-Based-on-Array-Values/m-p/806677
20. Mathcad: @FC_10037391 asked about Mathcad plot in prime and got great responses by @ttokoro and @JD_10370348
https://community.ptc.com/t5/Mathcad/Mathcad-plot/m-p/805500
