String replace not working
  • July 6, 2022
  • 2 replies
  • 3784 views
Hi all,
I am trying to replace '_' underscores from a given string, using the string.replace function,
but I am not able to achieve this,
can anyone tell me where I am going wrong.
Sujith
Sujith,
What version of ThingWorx are you on?  I'm in 9.0 and it seems to work for me:
Hi @nmilleson ,
I am using the latest build available on the cloud, I guess it is 9.2
In output even I am getting the desired result,
but in log I am not getting it.
Sujith
Sujith,
What happens if you try and run the replace right in the log statement?
logger.warn(Unique.replace(/_/g,''));
hi SB_9732186
below code worked fine on TW 9.3.2. Can you try on your TW instance?
var test = 'IOTMH22G022420_';
var result = test.replace('_','');
logger.warn("replace test : " + test.replace('_',''));
