Domed surface
- 17 replies
- 7620 views
- Translate All
Hi all, i have been trying to create a domed surface from this flat surface. I need to maintain the outside shape & draw the surface up towards the centre about 5mm up ideally with a single arc. The outside profile cannot lift off the datum on which it sits. The flat surface does not have to be used, i just figured there might be some way of pulling/dragging or distorting it using warp or free form surface manipulation but i have not managed to, thus far. I have tried boundary blend too but cannot achieve the flawless surface i require. Any ideas?
John
