by
IA_12762388
1686
Views
| Hi,In electronics, we use an operator for the parallel connection of
resistors. For example: R1 || R...
1686
Views
by
AkmarulSalleh
585
Views
| Hello Mathcadeers, I could not find a way to properly set the Legend on
"Chart Component". The legen...
585
Views
by
IS_10705139
1141
Views
| I need to ask about the possibility that Mathcad will allow me to
process images through the image p...
1141
Views
by
Lenin
2256
Views
| I tried to convert old mathcad file but the following error pops up ( I
have a Mathcad prime 7 insta...
2256
Views
by
YA_10963798
1262
Views
| Hi there , I need to create this table using programing I wrote this
program , but it doesn't give m...
1262
Views
1 Reply
710
Views
| Hello everyone!I have been creating with Mathcad 15, worksheets for the
analysis of electrical netwo...
1 Reply
710
Views
by
TP_10251883
11645
Views
| I typically do all my work in a textbox and recently I cannot copy
equations and text together and p...
11645
Views
by
AkmarulSalleh
1373
Views
| Hello Mathcadeers, I am trying to polynomial curve fitting, but could
not find any good example on h...
1373
Views
by
MS_12003747
1376
Views
| Hello,I actually want to plot an if function for a certain range of
numbers. I have tried to generat...
1376
Views
by
RasmusSkjøtt
9145
Views
| Hi I just started in calculating on transformers, and i have the problem
i cant get Mathcad to calcu...
9145
Views
by
Ivan_Pat
3572
Views
| Hi there! I 'm trying to master the slider advanced control option to
see how my goal function will ...
3572
Views
by
JC_10106130
1 Reply
559
Views
| I need to convert a file, but I'm concerned about not being able to
convert the hundreds of old file...
1 Reply
559
Views
by
TikkaMasala
1 Reply
576
Views
| Hi,I created the attached sheet to generate a histogram using the chart
component. If anyone has sug...
1 Reply
576
Views
by
EP_10996709
1269
Views
| working with Prime 10. I have two lists with different type of tubular
threads. Using the first comb...
1269
Views
by
AkmarulSalleh
831
Views
| Hello Mathcadeers, Been using MP10 for the last few days/weeks, and
these are the thing that I hope ...
831
Views
by
AkmarulSalleh
722
Views
| Hello Mathcadeers, I am designing a phase lock loop circuit (electrical
engineering) and trying to u...
722
Views
by
BY_9768522
660
Views
| Hello,I can not find the result. Example11 is my sheet it should be like
in the file example22.regar...
660
Views
2618
Views
| Hello,Why does PTC Mathcad Prime seem more oriented towards CIVIL and
MECHANICAL Engineering, and mu...
2618
Views
by
VL_12679279
445
Views
| Hello, I want to print a Mathcad worksheet to PDF by using Mathcad15
command (mathcad.exe -p test.xm...
445
Views
by
RK_12705188
1094
Views
| I want to solve the following equation at the bottom and get
T_react/T_com on one side and the rest ...
1094
Views
by
RD_12573711
753
Views
| We have aging licenses of Mathcad 14 that we've kept going as long as
possible but the end is nigh. ...
753
Views
818
Views
| Hi, using Mathcad 15.0. I have a solve block producing some very strange
units, and I can't get it s...
818
Views
14392
Views
| Attached is a Prime 4 file that allows you to plot text in a graph,
like: Of course it runs in Prime...
14392
Views
by
TL_3328905
1239
Views
| I have downloaded the trial version of PTC Mathcad Prime and want to
review how the current version ...
1239
Views
by
Davids1
1127
Views
| The issue that I am experiencing might be an old and known issue but I
just can't seem to find a sol...
1127
Views
by
MB_12486492
3461
Views
| I am looking for an implementation of a program for curve fitting. I
have already achieved a good ap...
3461
Views
by
IA_12699372
984
Views
| Hi, Looking for assistance with a formatting issue we are encountering
with our math text. Some of t...
984
Views
by
AS_9781967
1 Reply
551
Views
| If I have a more complicated equation and want to find its derivative
using a symbolic tool, how can...
1 Reply
551
Views
by
AkmarulSalleh
2360
Views
| Hello all, I found out the WRITEEXCEL generate excel file with wrong
time stamp. This is my workshee...
2360
Views
by
ED_12686351
1 Reply
414
Views
| I'm curious if there's a method to generate a 2D plot of f(x) versus x,
where x is the variable and ...
1 Reply
414
Views
| User | Count |
| 8 | |
| 3 | |
| 2 | |
| 1 | |
| 1 |
| Subject | Author |
