ENGAGE= KUDO, REPLY, or SOLVE!
1. Creo: Lively discussion started by @T_F about Color To Holes. Thank you for contributing to the thread! @KenFarley @pausob @Patriot_1776 @MartinHanak @BenLoosli @S_Edgenear
https://community.ptc.com/t5/3D-Part-Assembly-Design/color-to-holes/m-p/738456#M120180
2. Creo: @J_Sattler asked for help with Problem with placing a UDF on a sketch as reference Thank you!
@YaroslavSin and @FV for contributing to the conversation!
3. Creo: @Patriot_1776 is enjoying using Creo for his Fun and Practice: Rectangular Helical Spring
4. ThingWorx: @TanmeyTWX started a conversation about Advanced Grid: is Editable actually not working
5. ThingWorx: @AP_9587236 received an Accepted Solution from @vi1 for his post Import failed
https://community.ptc.com/t5/ThingWorx-Developers/Import-failed/m-p/737508
6. ThingWorx: @DanWolf provided an Accepted Solution for the How to publish development to production thread started by @EM_9923519
7. ThingWorx: @Nguyen_Khue started a conversation Click on the icon and open new mashup
https://community.ptc.com/t5/ThingWorx-Developers/Click-on-the-icon-and-open-new-mashup/m-p/737947
8. Vuforia: @JD_9967989 started a conversation while playing with his model in Vuforia Creo Illustrate Animations Randomly dissolve
Thank you @whity and @Suraj_Patil for contributing to the thread!
https://community.ptc.com/t5/Vuforia-Studio/Creo-Illustrate-Animations-Randomly-dissolve/m-p/736488
9. Vuforia: @AS_9962540 received some help from @Suraj_Patil and @dsgnrClarK for his post
How can I add popup after the last step of sequence is finished?
10. Vuforia: @KS_ @KS_9982057 restarted the post Enable microphone on mobile devices created by @ClayHelberg in 2019
https://community.ptc.com/t5/Vuforia-Studio/Enable-microphone-on-mobile-devices/m-p/615695
11. Vuforia: @BenAtLmco received an Accepted Solution from @Suraj_Patil for the post Automated Model Target Generation
https://community.ptc.com/t5/Vuforia-Studio/Automated-Model-Target-Generation/m-p/738660
12. Vuforia: @SS_9757450 is getting assistance from @NA_nur and @ClayHelberg with his inquiry about Data Matrix Scanning Alternative in Vuforia.
https://community.ptc.com/t5/Vuforia-Studio/Data-Matrix-Scanning-Alternative-in-Vuforia/m-p/738507
13. Windchill: @RME_DH started the conversation Windchill Visualisation Job Queue Visibility
Thank you, @d_graham @Marco_Tosin @STEVEG and @HJ1 for contributing to the discussion!
https://community.ptc.com/t5/Windchill/Windchill-Visualisation-Job-Queue-Visability/m-p/738869
14. Windchill: @mohitenw received an Accepted Solution from @imendiola for the inquiry How to get latest revision of a WTPart using Windchill Rest API?
15. Windchill: @avillanueva worked with d_graham to solve Issue with Business Rule and ERPConnector
https://community.ptc.com/t5/Windchill/Issue-with-Business-Rule-and-ERPConnector/m-p/736609
16. Arbortext: @IC_9796729 asked about Arbortext Stylesheet Error
https://community.ptc.com/t5/Arbortext/Arbortext-Stylesheet-Error/m-p/736239
17. Arbortext: @khoward started the post IsoDraw 7.3 Fillet Thank you for proving helpful advice, @briesen
https://community.ptc.com/t5/Arbortext/IsoDraw-7-3-Fillet/m-p/736599
18. Arbortext: @xhuang received an Accept Solution from @JeffStevenson for the post error )-103): Cannot checkout an uncounted license within a Windows Terminal Services guess session.
Thank you @GarethOakes for contributing to the conversation!
19. Windchill SSE: @RN_9991146 @RN_9991146 asked How to extract data from ptc Integrity using API
Thank you @kjain2 for collaborating!
20. Windchill SSE: @EP_9964574 started a topic about Package State configuration (entry scripts in ModelStateDescriptor.txt)
21. Mathcad: @RY_8246596 received an Accepted Solution from @-MFra- for the post Transfer Function solution Thank you for contributing to the conversation, @mvenich and @LucMeekes
https://community.ptc.com/t5/PTC-Mathcad/Transfer-Function-solution/m-p/736295
22. Mathcad: @Werner_E provided an Accepted Solution for the post Slice of a 3D Surface
created by @payman Thank you @ttokoro for also contributing to the thread!
https://community.ptc.com/t5/PTC-Mathcad/slice-of-a-3D-surface/m-p/738555
23. Mathcad: @JCBanks replied to a “throwback” 2003 Tri-diagonal Matrix Algorithm (TDMA) and provided some helpful algorithms!
https://community.ptc.com/t5/PTC-Mathcad/Tri-diagonal-Matrix-Algorithm-TDMA/m-p/213242
24. Mathcad: @ValeryOchkov asked for help with One specific three bodies problem (Mathcad Prime 6.0) Thank you Werner_E, LucMeekes, @MG_9991200 for contributing!
https://community.ptc.com/t5/PTC-Mathcad/One-specific-three-bodies-problem/m-p/737725
