Jul 2, 2021 9:17 AM UTC
How to get latest revision of a WTPart using Windchill Rest API ?
Hi all,
I am using Windchill 11.0 M030-CPS15
I want to get latest revision of a WTPart using Rest API.
I tried to use filter,
$filter : latestiteration eq true ;but not getting using this also.
eg. A.1 and B.1 and B.2
I only want to fetch the latest i.e B.2
Is there any way to get the latest version of a part through Rest API?
imendiolaAnswer
Jul 5, 2021 6:54 AM UTC
Hi mohitenw,
I think that the parameter was introduced in windchill REST Services 1.6.... (https://support.ptc.com/help/windchill_rest_services/r1.6/en/index.html#page/windchill_rest_services%2Fwccg_restapis_latest_version_search.html%23)
Perhaps you have a previous version installed?
Anyway, there is a workaround in https://www.ptc.com/en/support/article/CS334913
Jul 2, 2021 2:04 PM UTC
try adding the following parameter:
ptc.search.latestversion=true
mohitenw12-AmethystAuthor
Jul 5, 2021 4:33 AM UTC
Thanks for the response,
"/Windchill/servlet/odata/v1/ProdMgmt/Parts?filter=Number%20eq%20'VWTM42SE'&ptc.search.latestversion=true"
I had tried with this solution also but no expected output.
Any workaround solution?
imendiola13-AquamarineAnswer
Hi mohitenw,
