July 2021 Noteworthy Posts
Jaime_Lee
Community Manager
ENGAGE= KUDO, REPLY, or SOLVE!
1. Creo: Lively discussion started by @T_F  about Color To Holes. Thank you for contributing to the thread! @KenFarley @pausob @Patriot_1776 @MartinHanak @BenLoosli @S_Edgenear
https://community.ptc.com/t5/3D-Part-Assembly-Design/color-to-holes/m-p/738456#M120180
2. Creo:  @J_Sattler  asked for help with Problem with placing a UDF on a sketch as reference Thank you!
@YaroslavSin and  @FV for contributing to the conversation!
https://community.ptc.com/t5/Customization/Problem-with-placing-a-UDF-on-a-sketch-as-reference/m-p/736691
3. Creo:  @Patriot_1776 is enjoying using Creo for his Fun and Practice: Rectangular Helical Spring
https://community.ptc.com/t5/3D-Part-Assembly-Design/For-fun-and-practice-Rectangular-helical-spring/m-p/736257
4. ThingWorx:  @TanmeyTWX  started a conversation about Advanced Grid: is Editable actually not working
https://community.ptc.com/t5/ThingWorx-Developers/Advanced-Grid-isEditable-actually-not-working/m-p/737978
5. ThingWorx: @AP_9587236  received an Accepted Solution from  @vi1 for his post Import failed
https://community.ptc.com/t5/ThingWorx-Developers/Import-failed/m-p/737508
6. ThingWorx:  @DanWolf  provided an Accepted Solution for the How to publish development to production thread started by @EM_9923519
https://community.ptc.com/t5/ThingWorx-Developers/How-to-publish-development-to-production/m-p/737579
7. ThingWorx:   @Nguyen_Khue  started a conversation Click on the icon and open new mashup
https://community.ptc.com/t5/ThingWorx-Developers/Click-on-the-icon-and-open-new-mashup/m-p/737947
8. Vuforia:  @JD_9967989 started a conversation while playing with his model in Vuforia Creo Illustrate Animations Randomly dissolve
Thank you @whity and @SurajPatil   for contributing to the thread!
https://community.ptc.com/t5/Vuforia-Studio/Creo-Illustrate-Animations-Randomly-dissolve/m-p/736488
9. Vuforia:  @AS_9962540  received some help from @SurajPatil  and @dsgnrClarK  for his post
How can I add popup after the last step of sequence is finished?
https://community.ptc.com/t5/Vuforia-Studio/How-can-I-add-popup-after-the-last-step-of-sequence-is-finished/m-p/736732
10. Vuforia: @KS_  @KS_9982057 restarted the post Enable microphone on mobile devices created by @ClayHelberg  in 2019
https://community.ptc.com/t5/Vuforia-Studio/Enable-microphone-on-mobile-devices/m-p/615695
11. Vuforia:  @BenAtLmco  received an Accepted Solution from @SurajPatil  for the post Automated Model Target Generation
https://community.ptc.com/t5/Vuforia-Studio/Automated-Model-Target-Generation/m-p/738660
12. Vuforia:  @SS_9757450  is getting assistance from @NA_nur   and  @ClayHelberg with his inquiry about Data Matrix Scanning Alternative in Vuforia.
https://community.ptc.com/t5/Vuforia-Studio/Data-Matrix-Scanning-Alternative-in-Vuforia/m-p/738507
13. Windchill:  @RME_DH  started the conversation Windchill Visualisation Job Queue Visibility
Thank you, @d_graham  @Marco_Tosin @STEVEG and @HJ1  for contributing to the discussion!
https://community.ptc.com/t5/Windchill/Windchill-Visualisation-Job-Queue-Visability/m-p/738869
14. Windchill:  @mohitenw received an Accepted Solution from @imendiola   for the inquiry How to get latest revision of a WTPart using Windchill Rest API?
https://community.ptc.com/t5/Windchill/How-to-get-latest-revision-of-a-WTPart-using-Windchill-Rest-API/m-p/736500
15. Windchill:  @avillanueva  worked with d_graham to solve Issue with Business Rule and ERPConnector
https://community.ptc.com/t5/Windchill/Issue-with-Business-Rule-and-ERPConnector/m-p/736609
16. Arbortext:  @IC_9796729  asked about Arbortext Stylesheet Error
https://community.ptc.com/t5/Arbortext/Arbortext-Stylesheet-Error/m-p/736239
17. Arbortext: @khoward started the post IsoDraw 7.3 Fillet Thank you for proving helpful advice, @briesen
https://community.ptc.com/t5/Arbortext/IsoDraw-7-3-Fillet/m-p/736599
18. Arbortext:  @xhuang received an Accept Solution from @JeffStevenson  for the post error )-103): Cannot checkout an uncounted license within a Windows Terminal Services guess session.
Thank you  @GarethOakes  for contributing to the conversation!
https://community.ptc.com/t5/Arbortext/error-103-Cannot-checkout-an-uncounted-license-within-a-Windows/m-p/185015
19. Windchill SSE: @RN_9991146 @RN_9991146  asked How to extract data from ptc Integrity using API
Thank you  @kjain2  for collaborating!
https://community.ptc.com/t5/Windchill-Systems-Software/How-to-extract-data-from-ptc-Integrity-using-API/m-p/739070
20. Windchill SSE:  @EP_9964574  started a topic about Package State configuration (entry scripts in ModelStateDescriptor.txt)
https://community.ptc.com/t5/Windchill-Systems-Software/Package-State-configuration-entry-scripts-in/m-p/738633
21. Mathcad:  @RY_8246596  received an Accepted Solution from @-MFra- for the post Transfer Function solution Thank you for contributing to the conversation, @mvenich and @LucMeekes
https://community.ptc.com/t5/PTC-Mathcad/Transfer-Function-solution/m-p/736295
22. Mathcad:  @Werner_E provided an Accepted Solution for the post Slice of a 3D Surface
created by @payman  Thank you  @ttokoro  for also contributing to the thread!
https://community.ptc.com/t5/PTC-Mathcad/slice-of-a-3D-surface/m-p/738555
23. Mathcad:  @JCBanks  replied to a “throwback” 2003 Tri-diagonal Matrix Algorithm (TDMA) and provided some helpful algorithms!
https://community.ptc.com/t5/PTC-Mathcad/Tri-diagonal-Matrix-Algorithm-TDMA/m-p/213242
24. Mathcad:  @ValeryOchkov asked for help with One specific three bodies problem (Mathcad Prime 6.0) Thank you Werner_E, LucMeekes,  @MG_9991200 for contributing!
https://community.ptc.com/t5/PTC-Mathcad/One-specific-three-bodies-problem/m-p/737725
0 REPLIES 0
