See the Top Community Engagers and the Top Noteworthy posts for the month of February.
Top February 2023 Community Engagers:
@Werner_E @MartinHanak @avillanueva @jensc @tbraxton @HelesicPetr @VladimirN @TomU @Sathishkumar_C @LucMeekes @StephenW @BenLoosli @BryantMorgan @ValeryOchkov @pausob @kdirth @terryhendicott @skunks @KenFarley @ilyachaban @ttokoro
MOST NOTEWORTHY POSTS
Below are some of the top engaging or most viewed PTC Community topic threads for February 2023! See if your community username made this list! Or, read more about a topic that interests you!
1. Creo: @KA_10463142asked about Negative version level for product. Great contributions by @llie, @StephenW, @kdirth and @TomU.
2. Creo: @MrSteveR_3 received an accepted solution from @YaroslavSin for the topic ProSolidMdlnameCreate does not contain Csys. Thank you!
https://community.ptc.com/t5/3D-Part-Assembly-Design/Cosmetic-Thread-in-drawing/m-p/851178#M127448
3. Creo: Thank you @tbraxton for providing an accepted solution for @gshockxcc on this topic -Square tubing.
https://community.ptc.com/t5/3D-Part-Assembly-Design/Square-tubing/m-p/858447#M128003
5. Creo: A question about Layer rule based was posted by @MB_9236701 and an Accepted Solution was provided by @msmith.
https://community.ptc.com/t5/3D-Part-Assembly-Design/Layer-rule-based/m-p/857265#M127893
6. ThingWorx: @bchaudharygave an Accepted Solution to @RB_10191565 for the topic Dynamic Grid Configuration. Thank you, @jensc for your input as well!
https://community.ptc.com/t5/ThingWorx-Developers/Dynamic-Grid-Configuration/m-p/858681#M61371
7. ThingWorx: The topic Chip Based Data Filter Query Output posted by @AS_10340651 received an accepted solution provided by @Sathishkumar_C.
8. ThingWorx: @DanZ provided a speedy response and Accepted Solution to the inquiry by @jensc about Empty grid tooltip.
https://community.ptc.com/t5/ThingWorx-Developers/Empty-grid-tooltip/m-p/856945#M61292
9. ThingWorx: @eyli asked How can I run InfluxQL in ThingWorx to query data? and @VladimirRosu provided a quick Accepted Solution.
10. ThingWorx: @NH_shree posted the topic How to send the data from a table created in Hostinger Cloud Database to ThingWorx (version 9.3) ? and received an Accepted Solution from @jensc.
11. Vuforia: @HK_10594428 shared a post about where can i get apk file for "vuforia"? not via google playstore. Thank you @pandersson for providing an Accepted Solution!
12. Vuforia: @newieKek was Unable to see publish project in Hololens. Thanks @VladimirN for contributing with the Accepted Solution!
13. Windchill: @Imad_Aposted the topic Empty Life Cycle History when checked-out and received an Accepted Solution by @avillanueva.
https://community.ptc.com/t5/Windchill/Empty-Life-Cycle-History-when-checked-out/m-p/858833#M70468
14. Windchill: @SWeiler_9940261 asked about the License information page access and @Marco_Tosin provided the Accepted Solution. Thank you @joe_morton, @rhart, @STEVEG and @ScottMorris for your contributions as well.
https://community.ptc.com/t5/Windchill/License-information-page-access/m-p/825279#M68392
15. Windhill: @SebastianR1984 asked about Get Product Enditem via API with an Acccepted Solution @bhushan.d.
https://community.ptc.com/t5/Windchill/Get-Product-Enditem-via-API/m-p/856078#M70275
16. Windchill: Sha11 asked how to Send email to non-windchill users and HelesicPetr provided an Accepted Solution!
https://community.ptc.com/t5/Windchill/Send-email-to-non-windchill-users/m-p/856280#M70290
17. Windchill: @SebastianDrees asked a question about Windchill JAVA_HOME and @dnordin delivered an Accepted Solution. Thank you @AndyHermanson for participating!
https://community.ptc.com/t5/Windchill/Windchill-JAVA-HOME/m-p/856105#M70277
18. Mathcad: @JBlackhole needed help with Cholesky decomposition & the LDL decomposition. finding D? and @Werner_E provided the Accepted Solution! Thank you, @TH_10592087 for also participating in the conversation!
19. Mathcad: @hsrao77needed to Convert XMCD to Prime format
and @VladimirN helped with an Accepted Solution. Thank you @DJNewman for participating as well!
https://community.ptc.com/t5/Mathcad/Convert-XMCD-to-Prime-format/m-p/856559#M205203
20. Arbortext: FOSI Tag Description Table was @BW_9476867's topic, which received an Accepted Solution from @GarethOakes.Thank you!
https://community.ptc.com/t5/Arbortext/FOSI-Tag-Description-Table/m-p/854383#M32806
