7-Bedrock
Square tubing
It's been a while since I have done modeling in CREO.  What's the best way to model square tubing?  I thought there used to be a feature that you could extrude a line with a thickness to get simple square tube.  I am just trying to sketch up a simple weldment bracket, and I don't want to put a lot of time into the modeling.  It's not necessary.
Thanks in advance.
tbraxton
tbraxtonAnswer
Extrude a thin protrusion is what you are looking for.
tbraxton
tbraxton22-Sapphire IIAnswer
gshockxcc7-BedrockAuthor
7-Bedrock
Bingo!  That's it.  Thank you.
You can use the Framework extension to get your tube size and length against a single line.
