How to send the data from a table created in Hostinger Cloud Database to ThingWorx (version 9.3) ?
Hi , can anyone help me how to send the data to the properties created in thingworx-thing from the database located in the Hostinger with steps as i am new to use thingworx platform. i tried to import csv file successfully to thingworx but i am unable to find the imported csv file stored in which location inside the thingworx composer, please help me out with this issue , i am expecting some quick reply from community to this message please .
jenscAnswer
As I said I'm not really familiar with Hostinger hosting.
But looks like you would need to first give access to your MySQL server; link
Then I found this PTC support article on how to connect thingworx to a MySQL DB.
I am not sure if the MySQL JDBC drivers are installed out of the box on thingworx. You might have to follow this support article to get it to work.
There are also some related topics at the very bottom that might be good to read up on.
Hope this helps.
Jens
I am not really sure what your problem is.
Are you trying to import CSV files or do you want to connect to a database that is hosted on Hostinger?
For importing CSV files, you can use the file upload widget:
To upload your file to a repository which you will find under "Manage":
You can also upload the file directly into the repository if you want.
Then you can use the CSVParser to read the file and import whatever data you need from it.
Here you can read more about the CSV parser.
Here you can see how you can use the CSV parser.
If you want to connect to an external database you need to create a thing that is using the database base thing template:
Then in the configuration of this thing you would add your configurations for the database.
I couldn't really find any good guides on how to do this. But it is pretty self explanatory. If you need more help though, don't hesitate to ask here again.
Jens
NH_shree14-AlexandriteAuthor
Hi @jensc ,
Exactly I want to connect on a database that is hosted on hostinger , but i am not sure how to connect my thingworx to hostinger database.
Shree
jensc17-PeridotAnswer
Hope this helps.
Jens
