December Community Posts
ENGAGE= KUDO, REPLY, or SOLVE!
“Thanks, this steered me in the right direction and I was able to retrieve the xml files needed to do an silent install of the applications.” Thank you @dnordin and @rreifsnyder for also contributing to the thread!
https://community.ptc.com/t5/System-Administration/working-quot-copy-name-quot-mapkey/m-p/448286
Thank you @ptc-129614 @StevenDumon @tmenkveld, @manjunathrv, @dschenken for contributing to the thread!
https://community.ptc.com/t5/IoT-Tech-Tips/How-to-set-up-and-configure-Schedulers/m-p/537793
Thank you, @SachinSharma for also contributing to the thread!
https://community.ptc.com/t5/ThingWorx-Developers/MQTT-Thing-Unauthorized-to-set-Password/m-p/703332
" We were able to solve the issue….” Related threads and eSupport Help article were shared to help troubleshoot !
https://community.ptc.com/t5/Vuforia-Studio/Sequence-animations-on-hololens/m-p/701157
https://community.ptc.com/t5/Vuforia-Studio/Transmit-text-from-label-with-js/m-p/702599
9. Vuforia: @BenAtLmco asked Manipulating Scene to Add New AR Content
10. Windchill: @kwoodley @ScottMorris @MikeLockwood @jvonzastrow1 are having a conversation about How to notify specific group of users when file is Revised
11. Windchill: New member @avis called @mlockwood-2
“better than Batman! faster than the flash!” with his post about his First Time Windchill Installation Thank you
@BenLoosli also for contributing to the thread!
https://community.ptc.com/t5/Windchill/First-Time-Windchill-Installation/m-p/701590
12. Windchill: @JV_8742917 received an Accepted Solution from @mockwood-2 for his question about "link between WTPart and WTDoc for 15.000 files as "described by" relation out of a spreadsheet."
13. Windchill: An Accepted Solution is found in the conversation Make publish rules language independent between @AnderasFromm @MichaelChatel and @BjoernRueegg
https://community.ptc.com/t5/Windchill/Make-publish-rules-language-independend/m-p/703689
14. Windchill: 2018 thread Windchill APIs getting started with contributions by @shambhabi @Sri @mastachef @joshbybee @cyag-5 and @Pradeepa received Top Views in December!
https://community.ptc.com/t5/Windchill/Windchill-APIs-getting-started/m-p/564881
15. Arbortext: @ML_9713336 reactivated the 2013 thread Segment Violation Errors ! New answer needed. Thank you for participating in the conversation! @rarmstrong @GarethOakes @ptc-4447136 @ctant @jmaynard @amodee
https://community.ptc.com/t5/Arbortext/Segment-Violation-Errors/m-p/103079
16. Arbortext: An active thread Figure numbers in my Appendix are wrong is being discussed by @ML_9713336 and @rlaborde
https://community.ptc.com/t5/Arbortext-Tips/Figure-numbers-in-my-Appendix-are-wrong/m-p/698119
17. Arbortext: @ptc-1178792 started a discussion about Licence Management
Thank you @GarethOakes and @VladimirN for your participation!
https://community.ptc.com/t5/Arbortext/Licence-Management/m-p/703511
18. Arbortext: The topic (–103): Cannot checkout an uncounted license within a Windows Terminal Services guest session started by @xhuang with an Accepted Solution by @JeffStevenson made the top viewed threads for December!
19. Arbortext: The topic (–103): Cannot checkout an uncounted license within a Windows Terminal Services guest session started by @xhuang with an Accepted Solution by @JeffStevenson made the top viewed threads for December!
20. Windchill SSE: The 2016 topicIn a computed field, how do I count the number of items where a pick list is unspecified? was revitalized by @Chittaranjan_11 and more answers are needed! Maybe @phartwig @DanR. @mkiessling @KaelLizak previous contributors can help!
21. Mathcad: @payman started a thread about finding number of maxima of a noisy signal with an Accepted Solution from @ttokoro @ttokoro !
https://community.ptc.com/t5/PTC-Mathcad/finding-number-of-maxima-of-a-noisy-signal/m-p/702847
22. Mathcad: @ValeryOchkov started an engaging discussion titled Pendulum Math model
https://community.ptc.com/t5/PTC-Mathcad/Pendulum-Math-model/m-p/703824
23. Mathcad: @lvl107 started a lively discussion with @-MFra- and @Werner_E about Inscribed circle and altitude of triangle ?
https://community.ptc.com/t5/PTC-Mathcad/Inscribed-circle-and-altitude-of-triangle/m-p/701039
24. Mathcad: The 2016 post How to convert XMCD file into MCDX format? created by @dkothia
became active again last quarter by @ptc-4817179 @ptc-4817179 @LucMeekes @VladimirN
https://community.ptc.com/t5/PTC-Mathcad/How-to-convert-XMCD-file-into-MCDX-format/m-p/400986
25. Mathcad: @ValeryOchkov received help from @Werner_E and @Fred_Kohlhepp with his inquiry about Help please with ODE solution
https://community.ptc.com/t5/PTC-Mathcad/Help-please-with-ODE-solution/m-p/703103
