3-Newcomer
Figure numbers in my Appendix are wrong
I am using Arbortext Editor with Styler V7.0 M070 with DTD 38784STS-BV9a. Somehow, the numbering of the figures in my Appendix got out of whack. In my chapter 8 I have 35 figures and they are numbered 1-35. But in my appendix the first figure shows as A-36. I need it to be A-1. Any help is appreciated.
Are you using the appendix tag to start your appendix?
Did you use a chapter tag to start your appendix?
Did you update/refresh your SGML file?
The appendix tag is placed between the <rear> and <ending of the document> tags.
rlaborde3-NewcomerAuthor
3-Newcomer
Yes to appendix tag following rear and no chapter tag. Not sure what you mean by "update/refresh SGML"
Use this tag in your icon bar.
