See the Top Community Engagers and the Top Noteworthy posts for the month of March.
Top March 2024 Community Engagers:
@Werner_E @HelesicPetr @MartinHanak @avillanueva @Velkumar @ttokoro @Cornel @StephenW @d_graham @LucMeekes @tbraxton @terryhendicott @BenLoosli @Perez @Aditya1702 @Marco_Tosin @Amirtharaj_K @Pratik_Aswale @Patriot_1776 @Hari_Vara
MOST NOTEWORTHY POSTS
Below are some of the top engaging or most viewed PTC Community topic threads for March 2024! See if your community username made this list! Or, read more about a topic that interests you!
1. Creo: AA_11007722 asked about Applying Filter-By Rule in Drawing-Tables. Great contributions by Mahesh_Sharma,and MartinHanak.
2. Creo: AS_11004841 received an accepted solution from @ysinitsyn for topic how do I make inner acme/trapezoidal thread? kdirth, StephenW, tbraxtonand Patriot_1776 thank you for participating in the conversation!
3. Creo: An interesting conversation with @XDN @StephenW and @KenFarley around Gear teeth and spline hub shaft
https://community.ptc.com/t5/3D-Part-Assembly-Design/gear-teeth-and-spline-hub-shaft/m-p/841577
4. Creo: Chris3 needed help with MBD combo state start part recommendations and received an accepted solution from llie
5. Creo: A question about Sheet metal Forming was posted by AC_10274110 and an Accepted Solution was provided by Patriot_1776! Thank you for contributing to the conversation BenLoosli
https://community.ptc.com/t5/3D-Part-Assembly-Design/Sheet-metal-Forming/m-p/940146#M134123
6. ThingWorx: Sathishkumar_C gave an Accepted Solution to Jamal8548 for the topic The property VALUE of my thing just hides itself. DanZ thank you for your contribution!
7. ThingWorx: The topic Property values are repeating while using QueryPropertyHistory Service in ThingWorx was posted by Aditya1702 and an accepted solution provided by Velkumar. Thank you Rocko, H_1234 for contributing to the thread!
8. ThingWorx: Sathishkumar_C provided a speedy response and Accepted Solution to the inquiry by Snoopy_hu about How to add an image from a repository to a table?
9. ThingWorx: Pratik2 needed help with How can I Fetch specific property data from QueryPropertyHistory and show in a line chart graph.Thank you Velkumar for providing an accepted solution!
10. ThingWorx: Snoopy_hu posted the topic rest API and received an Accepted Solution from Velkumar.
https://community.ptc.com/t5/ThingWorx-Developers/rest-API/m-p/940240#M66158
11. Windchill: MC_6294097 posted the topic Windchill Save As with Creo files and received an Accepted Solution by RM_11009726.
12. Windchill: RR_10661622 asked about document rename not updating in task headlines and received an Accepted Solution from HelesicPetr Thank you Sarathkumar_M for participating in the conversation.
13. Windhill: PB_11008310 asked about Creo View does not get launched from Windchill Standalone browser with an Acccepted Solution by VladimirN.
14. Windchill: VG_WC12 asked about WTPart OIR doesn't work when auto-associate to EPMDocument and Hari_Vara provided an Accepted Solution!
15. Windchill: ML_10905028 had an inquiry about After installation, unable to view or edit the lifecycle or workflow templates. Sarathkumar_M delivered an Accepted Solution. Thank you avillanueva for your contribution!
16. Mathcad: Bogdan_d posted the topic Capacitor model unit issue and ttokoro provided the Accepted Solution!
https://community.ptc.com/t5/Mathcad/Capacitor-model-unit-issue/m-p/937217#M210760
18. Windchill SSE: AarushiS_0605 asked about OSLC Integration with IBM DNG using Windchill Modele
MangeshDevraj provided an Accepted Solution.
19. Arbortext: JSkog asked about Eliminate an element used throughout document, but retain text it's wrapped in and ClayHelberg provided the Accepted Solution.
20. Arbortext: jsterlin posted the topic Macro for IsoDraw 7.3 - Position and insert a new text in a CGM. Thank you bfriesen for your input!
