See the Top Community Engagers and the Top Noteworthy posts for the month of November.
Top November 2022 Community Engagers:
@Werner_E @TomU @VladimirN @MartinHanak @ttokoro @Cornel @tbraxton @LucMeekes
@ValeryOchkov @avillanueva @CW_9181033 @EdvinTailwind @N.Barnes @Dale_Rosema
@Brndn4 @StephenW @BenLoosli @HelesicPetr @rleir @ptc-4937106 @evandenbrink @FriedhelmK
MOST NOTEWORTHY POSTS
Below are some of the top engaging or most viewed PTC Community topic threads for November 2022! See if your community username made this list! Or, read more about a topic that interests you!
1. Creo: @EdvinTailwind asked about Corner Chamfer Workflow. Thank you @MartinHanak @pausob , @kdirth @BenLoosli and @tbraxton for contributing to the conversation!
2. Creo: The topic Anysys Simulate for Study of bolt pretension was started by @PS_10114112
https://community.ptc.com/t5/Analysis/Ansys-Simulate-for-Study-of-bolt-pretension/m-p/840131#M10997
3. Creo: @DCG received an accepted solution from @tbraxton for the topic Rotate text around circle
Contributions by @kdirth @StephenW and @pausob
https://community.ptc.com/t5/3D-Part-Assembly-Design/rotate-text-around-circle/m-p/839118#M126592
4. Creo: @Patriot_1776 was asking for more advice on how to be more efficient in the realm of Drawing mark ups/ redlines This doesn't seem to be resolved from a Creo standpoint but @Constantin seemed to have given the most satsifactory answer. Thank you, @KenFarley @kdirth @TomU and @StephenW for contributing to the conversation!
5. ThingWorx: @pjbiocco received an accepted solution for the topic How to prevent Custom widget resizing from Mashup Builder from @VladimirRosu
6. ThingWorx: Another accepted solution was received by @VladimirRosu for the topic Working with JSON and Arrays started by @jensc @VladimirN provided a helpful support article as well!
https://community.ptc.com/t5/ThingWorx-Developers/IoT-Hub-Connector-amp-Ports/m-p/833847#M60076
https://community.ptc.com/t5/ThingWorx-Developers/Run-EMS-as-background-job/m-p/837893
9. ThingWorx: @Rishabh345 asked a question about Unable to use JSON stringify0 on a JSON
Thank you @SachinSharma for contributing to the conversation!
https://community.ptc.com/t5/ThingWorx-Developers/Unable-to-use-JSON-stringify-on-a-JSON/m-p/839345
10. Vuforia: @AndreaT bumped up a topic posted in August from PTC Wayfinder Widget Open Beta!
with a follow up question. Great feedback from @AmberWright
https://community.ptc.com/t5/Vuforia-Studio/Wayfinder-Widget-Open-Beta/m-p/812159
11. Vuforia: @Pietro_Padovan received an accepted solution from @ClayHelberg
15. Windchill: @AG_10330040 asked about want to move the data from one context to another context through Customization Thank you @Ajit_Kulkarni @BenLoosli @rleir and @bhushan.d for contributing to the conversation.
16. Mathcad: Lots of creativity being inspired by the topic started by @ValeryOchkov titled New Oval-an ellipse @Werner_E thank you for adding to the fun and entertainment of this post!
https://community.ptc.com/t5/Mathcad/New-oval-an-ellipse-ellipse/m-p/837864#M203694
17. Mathcad: @PEAH is getting help with his inquiry Mathcad Prime 8 is very slow - Tips or tricks to increase speed? from @Werner_E @VladimirN and @terryhendicott
18. Mathcad: @JXBWk received an accepted solution from @AlanStevens for the topic ODE solve give very spiky response Thank you @ValeryOchkov @Werner_E @prop_design and @LucMeekes
https://community.ptc.com/t5/Mathcad/ODE-solve-give-very-spiky-response/m-p/838231
19. Windchill SSE (Integrity): @VladimirN sent @PM_10327162 a knowledge help article to help with Facing issue to Import Reqif
https://community.ptc.com/t5/Windchill-Systems-Software/Facing-issue-to-Import-Reqif/m-p/840081#M7806Facing issue to Import Reqif
20. FlexPLM:@kkari got some great feedback from salder for the videos posted in the Adobe Illustrator Plugin 2.x: Update an existing design
