rotate text around circle
  • November 18, 2022
  • 3 replies
  • 3965 views
I have a UDF which creates cuts and automatically numbers the cuts around a circular part.  The numbers are in the correct place, but I want them to be rotated so they are readable from the center.  Is there a way to do this? udf.PNG
Best answer by tbraxton
Start here:
https://www.ptc.com/en/support/article/CS254748
This is a practical example with model to query. It is linear but the approach will be the same.
https://community.ptc.com/t5/3D-Part-Assembly-Design/text-repetition/m-p/697310
tbraxton
If I understand your design intent, then you can place the text along a circle. Create the circle to locate the text first and then use it to locate & orient the text.
tbraxton
This will orient the text as you intend.
DCG10-MarbleAuthor
Thank you all for your responses.  My numbers are not text in a sketch, they are notes.  It is part of a pattern, as the quantity needs to be adjustable.  Each note is placed at the end of a short curve that is in the first instance of the pattern.
I can unplace the note and replace it with orientation, but there is no way to automatically rotate it.
kdirth
Your text appears to be constrained vertical.  I would suggest making it parallel to the cut edges.
