1623
Views
| Good evening, all. I am in the process of migrating some old MATHCAD 15
worksheet to MATHCAD PRIME 1...
1623
Views
by
GW_9431254
1134
Views
| Saw not long ago, methodology for plotting load, shear and moment
diagrams- Please point me in the r...
1134
Views
by
MR_11012943
2127
Views
| Hi everyone. I have a mathcad worksheet that I am currently using to
generate bending moment and cur...
2127
Views
by
rjwolfgang
2780
Views
| Dear PTC Community, I was recently working with a Mathcad Prime 9.0
worksheet that uses the Pdesolve...
2780
Views
by
Math_10280663
6051
Views
| Good evening all. I have digitized some data points (see the 3D
picture), in order to use interpolat...
6051
Views
by
AlanStevens
1716
Views
| From Val Ochkov: How to solve in Prime 9?
1716
Views
2944
Views
| Hello,The problem is as following:Find currents through R3 and R1 and
voltages of R2, R1 and C1 in b...
2944
Views
by
TerryRickard
8861
Views
| Has anyone figured out how to plot a vector of points using the chart
component in Prime? It used to...
8861
Views
by
NM_10165576
1 Reply
687
Views
| Could someone please convert this MCD file to XMSDIn my Mathcad the
conversion is greyed out in Inpu...
1 Reply
687
Views
by
NM_10165576
1178
Views
| Could someone help me to find the Area, CG and Second moment of area of
a cross section using the tw...
1178
Views
1463
Views
| I tried using symbolic to implement without success. Any hints on how I
can implement this. and late...
1463
Views
1652
Views
| Hi, So i'm currently working on converting a worksheet from MC15 to
Mathcad Prime and have ran into ...
1652
Views
by
YA_10963798
1099
Views
| I wrote the same program in two different sheets , it shows error in the
sheet which has more than o...
1099
Views
by
YA_10963798
1652
Views
| I need to use lookup function to specify the sand layer . I want to say
if the value of qcza is betw...
1652
Views
4530
Views
| Hi, Is it possible to display image with if condition I would like to
display the right side image i...
4530
Views
by
MD_7971553
1052
Views
| Comment exporter un graphique avec une qualité supérieure
1052
Views
by
YA_10963798
4229
Views
| Hi there, I want to write one equation for serveral matrics , however I
can do that if I define a va...
4229
Views
by
MD_7971553
1648
Views
| hello, I would like some help with: I inserted the text file, but I
don't have a graphic.thank you v...
1648
Views
by
JM_10241707
2003
Views
| I want to insert steam and water properties from steam table. How do I
integrate steam tables in Mat...
2003
Views
by
Ally_mech_eng
1792
Views
| Newbie to Mathcad here and I'm struggling to find a tutorial for how to
insert this table into Mathc...
1792
Views
by
CarlosRomero
2931
Views
| Dear community, I am carrying out the coding of the optimization task in
Matlab, from the attached s...
2931
Views
5792
Views
| Elementary schoole children can solve this puzzle. If you need you can
use Mathcad Prime.
5792
Views
by
BoyHowdy
1 Reply
924
Views
| Would anyone have any recommendations on how to improve the code below?
I use this function to solve...
1 Reply
924
Views
by
BF_10802929
1164
Views
| I am using Mathcad Prime Release 9.0 and Datecode9.0.0.0Mathcad won't
print to PDF. This is a new is...
1164
Views
by
AlfredFlaßhaar
1902
Views
| A friendly hello,In the attached calculation it is easy to see from the
angle sums (they must be 180...
1902
Views
2227
Views
| I'm not able to assign the output of the solver to a variable. I can do
it with other examples, but ...
2227
Views
by
GC_5455875
1 Reply
867
Views
| Hi. I tried to put in Mathcad Prime the equations for the attached pdf
file, but I got some error wi...
1 Reply
867
Views
2399
Views
| Hi,Why is not possible to plot like below?
2399
Views
by
TudorMarin
18270
Views
| By Chris Russell This worksheet will: Calculate the bearing capacity
factors and the maximum load of...
18270
Views
1559
Views
| Hi,What does rows and cols? See below the example at which I am
referring: And beside the fact that:
1559
Views
| User | Count |
| 6 | |
| 5 | |
| 1 | |
| 1 | |
| 1 |
| Subject | Author |
