Adding color to surfaces within drawing
Hello all,
To begin, I'm running Creo 3.0. In my application, I have a drawing for a plastic housing and I need to indicate where a coating should be applied and where a mask should be applied. Since it is a complex shape, it would be easiest if I could shade areas of the wireframe view. However, this is becoming quite difficult.
I took the route of applying the color grey to the areas of the model that I want masked from coating and the color white to areas that should be coated. In my drawing, I then used the "shading with edges" view. All is great, except the software tries to give it a 3D feel by giving the faces a gradient/shadow. Therefore, my greys and whites are hard to distinguish from one another. Is there a way to turn off the color gradient/shadows? Is there a better approach to what I'm trying to accomplish?
Thanks for your help!
Kyle
