configuring ModelCheck
okay, so we are transitioning from intralink to teamcenter, apparently teamcenter likes for pro/e files to be 100% spotless and our files are far from that. so i have been assigned to go thru many many pro/e assemblies and try to check them into teacmcenter, but i am coming across a ton of short_edge errors, many of my short edge errors are from parts with imported geometry, like step files and iges files etc etc, so as i was reading thru the help section in pro/e i saw that i can specify the length of the edge so that model will or will not pick up these issues. i tried configuring under the tool-configure modelcheck box and added shot_edge and short_edge_batch to my constant constraint file and added a value of .00001 but that seems to not make a difference. please, any suggestions or comments or does n donts would be greatly appreciated... oh, and incase u are wondering, some of these files have up to 3500 short_edge errors, thats kinda why i dont have the time to go thru each one of those and ignore in future them all one at a time, and NO, i cant select them all at the same time, ive tried every selection method i know but no luck, unless there some other cool way to do it... thanks guys Carlos
