Drawing dimensions moving around.
I am showing model assembly and part dimensions in a large assembly.
The parent assembly contains duplicate subassemblies, the first of which has placement constraints, the 2nd of which (the duplicate)contains mechanism constraints.
After the dimension values are passed down from the parent assembly to the subassemblies (via Pro/Program),the parent assembly is saved (thus saving the dimension values in the subassemblies), and then the mechanism assembly versions are suppressed (and eventually deleted from the parent assembly) This is because the mechanism assemblieswere only included in the parent assembly for the purpose of passing down their dimension values from the parent assembly, via Pro/Program.
The processworks well (we have used it for years), but I have just started to show model dimensions in the parent-assembly drawing, and I am now finding that diameter model dimensionsmove from the location they had before the mechanism subassemblies were suppressed, because the location of the view moves horizontally relative to the drawing format, once the mechanism subassemblies get suppressed.
This only happens with diameter dimensions, not linear dimensions (apparently the 2 witness lines of the linear dimensions keeps their relative position fixed to the model geometry).
Does anyone know of a way to fix the horizontal-direction location of model diameter dimensions (relative to their model geometry references), or else some way to keep the horizontal-direction location of the view from shifting in the horizontal direction, once the mechansim subassemblies get suppressed?
