Jan 22, 2015 8:29 PM UTC
Drawing Practice Question
Not exactly a Creo question, but related.
I have a disagreement of practice on drawing tables, specifically the revision table.
My practice is that when the description cell for the rev. is too small, you make the row taller to accommodate.  Another user will make the description column wider. Of course, back in the paper drawing days, the columns were defined by the pre-printed title block so you couldn't make them wider. That's where I'm probably coming from.
Is there a common or accepted practice on this?  I'm not looking for an ASME spec (although that would be fine) but rather if there's a general consensus.
Jan 22, 2015 8:56 PM UTC
I have ALWAYS made the row taller and added multiple lines of text.
Bob
Jan 22, 2015 9:50 PM UTC
I make the table cell taller to accommodate more lines of text. Some co-workers make the text smaller but I disagree w/ that as my old eyes can't read smaller text. 😉
Steve Shannon
Tooling Engineer
trans-matic
300 East 48th St.
Holland, MI 49423
phone (616) 820-2427
fax (616) 820-2488
www.transmatic.com
Jan 22, 2015 9:56 PM UTC
We always make our rows taller and have the table set to wrap text and
auto height adjustment.
Gary Bunney
Engineering-Supervisor
Harford Systems Inc
Lab Products Inc
a bio Medic Company
2225 Pulaski Hwy
P.O. Box 700
Aberdeen, MD 21001
Jan 22, 2015 11:40 PM UTC
We maintain minimum text height and add a second or third row if needed. Our formats are released forms and document control can be very anal about modifying forms. They consider expanding the block a modification to the form while adding a second row is using the form as intended.
Jim Flores
Mechanical Designer
Sustaining Engrg, Philips Healthcare, PCCI
Jan 23, 2015 6:17 AM UTC
There shouldn't be much need for room in the revision block. The exact changes to the drawing should be identified in the Engineering Change Request or the Engineering Change Order and Notice. I know some companies like to use the block as a detailed reverse list record of every little change, but I think it's a waste of time to do so. In the past it wasn't possible to have more than one original of a drawing and a limit on the number of copies, but with CAD that is no longer true, so if one wants to see what the old drawing was like, take a look.
Most of the time, when pressed to include this excess data, I just make the text a little smaller or increase the row height.
I think there is no ASME drawing guidance on this level of detail.
x
Jan 23, 2015 2:16 PM UTC
It's been 11 years since I worked somewhere that wanted every single alteration listed in the revision block. In the companies between then and now the revision block always refers to an external document where every change is laid out in minute detail: zone, from-to, sometimes including pictures.
Having said that, ASME does show what to do, mostly.
ASME Y14.1-2012 7.7.1
Space shall be reserved to extend the revision history block downward as required. When additional space for the revision history block is needed, a supplemental revision history block may be located to the left of the original revision history block. Revision history blocks may be included on continuation sheets.
It also lays out the exact size of the revision block and each cell within except it omits the horizontal length of the DESCRIPTION field to enter the change details, instead saying AS REQD.
So, it's really up to the admin to determine how wide to make the revision block's DESCRIPTION field (shown in Fig 7-1), then to enforce the "you may only grow cells vertically" if you're following ASME standards.
