Feb 2, 2012 4:11 PM UTC
Equations for Curves (and more)
I wish I had found a list like this a few years ago.  I've searched the web and compiled the following list for your enjoyment.  Many are probably considered basic with a few very cool, complex curves thrown in.  The list is divided into the coordinate systems that you will have to choose when creating the datum curve.
To initiate the command that will allow you to try these, go to Insert>Model Datum>Curve>From Equation.
After the Equations section see the section title Links to find PlanetPTC discussions and videos that have demonstrated and, in some cases, explained the curve from equation command in more detail with ways to incorporate relations and parameters.
Attached is a Creo Elements/Pro 5.0 part file with all of the equations included.
In the comments, please share any equations or links that you know.  Other suggestions are welcome, too.
EQUATIONS
Cartesian Coordinates:  x, y, & z
The z variable is not necessary, but when used will give the curve that extra dimension. If in doubt, try z = t*10.
Sine
Cartesian coordinates
x = 50 * t
y = 10 * sin (t * 360)
Rhodonea
theta = t * 360 * 4
x = 25 + (10-6) * cos (theta) +10 * cos ((10/6-1) * theta)
y = 25 + (10-6) * sin (theta) - 6 * sin ((10/6-1) * theta)
Involute
r = 1
ang = 360 * t
s = 2 * pi * r * t
x0 = s * cos (ang)
y0 = s * sin (ang)
x = x0 + s * sin (ang)
y = y0-s * cos (ang)
Logarithmic
z = 0
x = 10 * t
y = log (10 * t +0.0001)
Double Arc Epicycloid
l = 2.5
b = 2.5
x = 3 * b * cos (t * 360) + l * cos (3 * t * 360)
Y = 3 * b * sin (t * 360) + l * sin (3 * t * 360)
Star Southbound
a = 5
x = a * (cos (t * 360)) ^ 3
y = a * (sin (t * 360)) ^ 3
Leaf
a = 10
x = 3 * a * t / (1 + (t ^ 3))
y = 3 * a * (t ^ 2) / (1 + (t ^ 3))
Helix
x = 4 * cos (t * (5 * 360))
y = 4 * sin (t * (5 * 360))
z = 10 * t
Parabolic
x = (4 * t)
y = (3 * t) + (5 * t ^ 2)
z = 0
Eliptical Helix
X = 4 * cos (t * 3 * 360)
y = 2 * sin (t * 3 * 360)
z = 5
Disc Spiral 1
/* Inner Diameter
d = 10
/* Pitch
p = 5
/* Revolutions
r = 5
/* Height; use 0 for a 2D curve
h = 0
x = ((d/2 + p * r * t) * cos ((r * t) * 360))
y = ((d / 2 + p * r * t) * sin ((r * t) * 360))
z = t * h
Butterfly
a=cos(t*360)
b=sin(t*360)
c=cos(4*t*360)
d=(sin((1/12)*t*360))^5
x=b*(exp(a)-2*c+d)
y=a*(exp(a)-2*c+d)
Fish
a = cos (t * 360)
b = sin (t * 360)
/* As "c" increases the fish gets fatter until it transforms into a figure 8.
c = 10
x = (C*a-20*((b)^2)/1.5)
y = c * a * b
Cappa
/* "c" is a scaling variable
c=20
/* Revolutions
r=1
/* Height
h=0
x=c*cos(t*r*360)*sin(t*r*360)
y=c*cos(t*r*360)
z=t*h
Star
/* "a" & "b" are scaling variables
a=2
b=2
/* If, r=2/3 ----> astroid
/* If, r=2 ----> ellipse; when a=b, its a circle
/* r cannot equal 1
r=2/3
x=a*(cos(t*360))^(2/r)
y=b*(sin(t*360))^(2/r)
z=0
Bicorn
/* "c" is a scaling variable.
c=5
a=cos(t*360)
b=sin(t*360)
x=c*a
y=c*(a^2)*(2+a)/(3+b^2)
Talbots
c=10
a=cos(t*360)
b=sin(t*360)
x=C*a*(1+exp(2)*(b^2))
y=C*b*(1+exp(2)*(b^2))
Cylindrical Coordinates:  r, theta, & z
Spiral
Cylindrical coordinates
r = t
theta = 10 + t * (20 * 360)
z = t * 3
Circle Spiral Column
theta = t * 360
r = 10 +10 * sin (6 * theta)
z = 2 * sin (6 * theta)
Helical Wave
r = 5
theta = t * 3600
z = (sin (3.5 * theta-90)) +24 * t
Basket
r = 5 + 0.3 * sin (t * 180) + t
theta = t * 360 * 30
z = t * 5
Disc Spiral 2
R = 50 + t * (120)
Theta = t * 360 * 5
Z = 0
Apple
a = 10
r = a * (1 + cos (theta))
theta = t * 360
Spherical Coordinates:  rho, theta, & phi
Butterfly Ball
Spherical coordinates
rho = 8 * t
theta = 360 * t * 4
phi = -360 * t * 8
Spherical Helix
rho = 4
theta = t * 180
phi = t * 360 * 20
UFO
rho = 20 * t ^ 2
theta = 60 * log (30) * t
phi = 7200 * t
Unnamed
rho = 200 * t
theta = 900 * t
phi = t * 90 * 10
LINKS
Peruse the links for more equations and explanations as to how they work.
Web Links
  1. Involute Gears
  2. Power Tools: Curves by Equation
    1. This gives details about using Pro/E dimension references in the equation to give it a parametric touch.
Links to curve-from-equation Discussions on PlanetPTC:
  1. Curve from Equation Sample for Newbies
  2. Capto
  3. How to Create a Curve from the Equation? Does Anybody Know?
  4. Datum Curve from Equation Driven by Parameters
  5. Constant Force Spring Model
  6. Involute Helical Gear Geometry
Links for related PlanetPTC content:
If you think curves from equations are cool, then the following is right up your alley.  These delve into the use of variable section sweep and the trajpar variable.
  1. From E-learning with Vladimir Palffy
    1. http://communities.ptc.com/blogs/vpalffy/2011/02/09/user-defined-springs
    2. http://communities.ptc.com/blogs/vpalffy/2011/11/27/sweep-and-trajpar
  2. Fun with Helical Sweeps and Trajpar
  3. Conch Shell in Creo Parametric
  4. How to Create Twisted Wires
Patriot_1776
Feb 2, 2012 7:33 PM UTC
Nice find!  thanks for posting it.
Note:  I suggest downloading by using the "View as PDF" button in the "Actions" menu in the upper right of this page.  That way you can cut & paste and try some out.  Interesting stuff here.  Not a whole lot of practical applications in most cases (except involutes, etc.), but very cool for fun.
Feb 2, 2012 7:41 PM UTC
Thank you, the models that you shared with me lead me to create this document.  I haven't yet figured out how to recreate your models, but I have rediscovered my interest in the curve from equations command.  However, I am aware that you used a different method to create your geometry.  Maybe (or, hopefully) you'll share it with us later.
Patriot_1776
Feb 2, 2012 7:52 PM UTC
I'm kind of waiting to see if someone from PTC can't tell me how some of them, in particular, the wavy-washer, 3rd_curve and the coiled_spiral were created.    How did I get the trajectory in the latter to circle back on itself 4 times without failing?
Feb 3, 2012 1:19 AM UTC
Thanks for the post Kevin. I actually have a couple to add to your list. I discovered one really cool equation while trying to help someone else on Planet PTC> I haven't gotten a chance to write it up yet so I haven't posted it. When I do I'll send it to you, too so you can include it in your document (if you'd like).
Thanks!
-Brian
Feb 3, 2012 1:09 PM UTC
I absolutely want them and will add them to the document.  That goes for everyone.  In time, I think I will also add images for each curve so a user, without having to try all of them, could decide which one they want to experiment with.
May 4, 2012 12:41 AM UTC
l = 2.5
b = 2.5
I have a question about the Double Arc Epicycloid.  I'm looking to make a 4 arc version.  Based on your equation, the (3 * t * 360) would change to (5 * t * 360).  What I'm unclear about is the rest of the formula.  The basic formula to create a epicycloid is:
x = (R + r) cos theta - r cos ((k + 1) theta)
y = (R+ r) sin theta - r sin ((k + 1) theta)
Where R = radius of the circle being revolved around, r = radius of the circle revolving around the R circle and k = the number of arcs.
What does "l" and "b" stand for in your equation?  It looks like "l" stands for the "r", but I'm not sure about the "b". Also, what is the 3 shown before the "b" supposed to stand for?
The outside diameter at the tangent points of the arcs for my project is .7874 (or 2 cm).
Also, do you have a formula for creating a hypocycloid?
Thanks.
brian
May 4, 2012 2:00 AM UTC
These equations aren't my own, but I can shed some light on them with the caveat that I don't have access to Creo and the equations anymore--If I did I could answer your questions better.
Anyway, the l & b from the equation are just multipliers, if I remember correctly. In order to maintain the desired shape of the curve, I think the intention was to only change the l & b values, thereby modifying the size of the curve, yet still being able to call it a double arc epicycloid.  Because if you change the other values then the shape no longer deserves that name (I think).  Did I make any sense?
Brian or Frank, from the posts above, may be able to help more.
Thanks for replying.  It's a fun feature to play around with.
May 4, 2012 6:36 PM UTC
First, it would help if I posted the equation correctly.
x = r (k+1) cos theta - r cos ((k+1) theta)
y = r (k+1) sin theta - r sin ((k+1) theta)
Anyways, I figured out that both "l" and "b" are both the same representation of "r".  Changing them to the value I needed and changing each of the 3's to 5's (which is the k+1 value) made it work.  Thanks for the input.
Dec 23, 2012 8:54 PM UTC
hello!
I would deeply appreciate your help, as I am new to inserting equation into Pro E.
What is the cartesian or cylindrical equation for Logarithmic spiral that I should enter to the ptogram?!?!?
below the equation
http://mathdl.maa.org/images/upload_library/23/picado/seashells/espiraleng.html
Feb 18, 2014 4:34 AM UTC
Greetings,
I've been trying to turn the following into a functional epicycloidal curve from equations but have hit a wall:
I've reduced it to the following after trying it in its original format but it still blows up at zero, rotates the epicycloid CCW 5° or so and generally isn't the correct curve. This request for help may be beyond the scope of this forum in which case I'd be willing to talk consulting terms. Thank you.
A = 90
B = 12
C = 11
D = 3
x = A*cos(t*360) - B*cos((t*360) + atan ((sin(1-C)*(t*360)) /  (A/(D*C) - cos(1-C)*(t*360)))) - D*cos(C*(t*360))
y = -A*sin(t*360) + B*sin((t*360) + atan ((sin(1-C)*(t*360)) / (A/(D*C) - cos(1-C)*(t*360)))) + D*sin(C*(t*360))
