Flexible Spring in Animation
  • March 8, 2012
  • 5917 views
Hi, I have a little assembly of a spring being compressed and released. When I drag the rod which compresses the spring and regenerate the spring compresses correctly.
I have made an animation of this but the spring does not compress, it is not dynamic.
Is there a way to achieve this?
LeeCasey1-VisitorAuthor
OK, so I've figured out that I need to something within mechanism to achieve this.
When I go into mechanism my spring disapears. Does mechanism create springs for you?
Could someone give me a quick crash course?
AFAIK you can only animate springs dynamically using Mechanica Motion by running a simulation.
I figured out how to create the spring in mechanica (very nice!) however this is not animated dynamically.
I have never heard of Mechanica Motion. I will look into that. Is this a plugin or something?
