general notes and absolute coordinates
  • October 29, 2012
  • 1119 views
Is there a way to insert general notes at an exact location in a drawing? -or- What if the notes accidentally get moved - how does onemove those notes back to where they were? There does not seem to be an "absolute coordinates" option or methodin adding notes to a drawing.
20-Turquoise
October 29, 2012
On 10/29/12 11:33, Rob Olds wrote:
> Is there a way to insert general notes at an exact location in a drawing? -or- What if the notes accidentally get moved - how does one move those notes back to where they were? There does not seem to be an "absolute coordinates" option or method in adding notes to a drawing.
You forgot the important part of "I am running Pro/Engineer xxx" however in Wildfire 5 you can do this:
1. select the Annotate tab
2. select the note
3. Edit | Move Special...
4. Select the note vertex that you want to move by
5. and then move by:
* absolute coordinates
* relative coordinates
* snap to a specific reference point on an entity
* snap to a specific vertex
> -----End Original Message-----
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
Fax: 785-667-2695
