How i can create two different views in same drawing in Creo drawing Module.
  • December 27, 2014
  • 3664 views
How i can create these type of views in Creo drawing Module.
How i can create two views in same drawing in Creo drawing Module.
You can add multiple models in drawings. Use the "add model" dialog. One model will be active. You can change the active model in the model tree. The default drawing scale applies to each model.
Typically, your variation will be determined with family tables. Each family table instance can be added to the drawing as a different model.
