How to add automatic parameter using layer properties?
- December 28, 2015
- 3 replies
- 1667 views
Hi all,
I wanted to add automatic parameter associated with features like holes and other cut features.
So my question is, is there any relations for feature types for adding automatic parameters.
For example,
If i am adding hole1 feature in a model. I want the automatic parameter creation "machine=drilling" in that particular hole feature.
right now i am doing manually by adding parameter in each and every hole feature.
i might be dreaming for this type solution. I am thinking this way to make my work easy but if this can be done in some other way then please let me know.
And If its possible. Please help me out for this.
If this can be solved, i can save my hell lot of time and can be free from doing repetitive work.
I am attaching the screenshot hereby to understand what i want.
Jimmy
