How to define transparent surface color as default?
Is there a way to define surface color transparent with different colors for inner and outer edges?
The Idea is to have the possibility to see the edge behavior from wireframe mode (open edges in a different color than closed edges)
and a transparent, shaded representation of the surface.
Inside the default system colors it is only possible to select the color but no way to turn on the transparency.
