Is it me or has PTC lost it's way
  • May 10, 2012
  • 117 replies
  • 59507 views
Have been a user of Pro-E (now CREO, for some unknown reason) since release 2001 and although, initially the program had new developments with subsequent releases, the later versions are a joke!
The sheet metal module has not changed significantly from Wildfire 3, to produce a paper 2d drawing is such a long winded process that it makes you want to give up. With each release they change the position of the menu structure so you have to spend the next couple of months looking for commands. The mapkeys that you spent so long setting up, no longer work. It's a mess!
My discipline is sheet metal and CREO is rubbish at it. It does not even have a library of standard primitives that most CAD programs have been using since the eighties. By that, I mean 'Conical Frustum's, 'Square to Rounds', 'Pipe Branches' etc. These are from known formulas that sheet metal workers have been using for decades. These basic formulas include triangulation and radial and parallel line developments. Why should it be so difficult to develop sheet metal work from within CREO? I believe that Solid Works has this ability but we are stuck with CREO for parity with the companies we deal with.
My other major gripe is the 2D Drawing side. Surely by now, a certain amount of automation should be entering this module. If you get it to auto dimension, it does not do it intelligently but throws every dimension on to the drawing. Does anybody use auto dimensioning in CREO? The alternative is fairly long winded which is why most of our customers just throw a model at us and we are left with dimensioning and producing drawings for manufacture and inspection. The use of BOMS and tables are not very intuitive and this side of CREO has not changed from 2001 days.
All in all, a huge disappointment. After all the hype about CREO it has failed to live up to expectations. We are only a small company and only hold 4 licenses, but we have decided to drop our maintenance cover for the foreseeable future as we find it hard to justify a product that is going nowhere. Perhaps we will pick it up again when PTC finally realise that their customers are not prepared to support their 'bloatware' when they can't even fix the fundamentals.
Does anyone else out there feel as I do? If so hit them where it hurts and drop your maintenance payments until PTC listen to what their customers want.
My updated opinion, if you need more fodder:
http://communities.ptc.com/message/222647#222647
I agree with a lot of the posts on this issue. When I complained about the GUI, I was called old and unable to move with the times. I have been using Pro Engineer since the mid 90's, and I have seen very little change to the core functionality of the software. The only changes that have been made were to the GUI. Some of these changes have been good, but since Wildfire 3, everything has gone downhill.
I resisted changing to Creo until I was forced to change about 2 months ago, and I still hate it, every day I am modifying the ribbon, to make it faster to use.
PTC needs to spend some time watching users working on a normal, everyday job that they do, and see how the GUI should work. My biggest problem with the GUI is the amount of extra mouse clicks and mouse movement that you have to do when doing routine modelling and drafting. For example, if you are modelling and want to change from shaded view to hidden line, in Wildfire, it was just one mouse click, in Creo there are at least 3.
I would like to see the next release, with a more usable ribbon, but more importantly, they need to fix some of the core functionality with sheetmetal, Pro NC machining and other modules.
Fully agree, I call it 'Creo is cruely bad because the ribbon implementation is rubbish'.
Not only the ribbon UI is a disaster, also the new Measure UI ( requiring the CTRL-key to click the second point)
is a step backwards.
For large patterns, Not having the Simple sweep cut command any more is even a showstopper for our company.
Marc Verschelde
TPVision Brugge, Belgium
I didn't read the whole thread but the ribbon can be customized.
What's your experience about the ribbon customization?
I have plenty of experience customising the ribbon.
By the way, you can't customise all of the ribbon - try customising the "component placement" tab!
Another thing that does not work properly is the pattern command.
This morning I grouped two features and patterned the group, the first feature patterened correctly, but the second feature didn't pattern. I ungrouped them and patterned them individually without any issues. By the way the second feature was a simple hole constrained in one direction to a plane and dimensioned from one end of the block.
Come on PTC this is basic stuff!
What version are you running, Edward? Verion Creo 2.0 M090 was suppose to have fixed a serious patterning bug. I have not confirmed this yet.
I am running M010.
M090 is not available on physical media yet!
We are all paying enough for maintenance for PTC to send out a CD of the latest bug fix.
FULLY AGREE, You give a good summary of the bad performance of PTC since the marketing invention 'CREO'
This is my slogan:
CREO is cruely bad because the Ribbon UI is Rubbish.
I am convinced that PTC has to offer, urgently, at least one alternative in the style of Wildfire 4 (NO Ribbon)
'I am convinced that PTC has to offer, urgently, at least one alternative in the style of Wildfire 4 (NO Ribbon)
...not going to happen...
We should not give up too early. If we stop paying maintenance, I hope, something will happen.
After reading all these posts tonight I have to say the "frustration" expressed by everyone is very real and very familar. I am in no way trying to mitgate the validity of the issues. Take my ideas as opinion. I have been an active Pro user since the late eighties and it has ALWAYS been the case, year after year, release after release, bug after bug, hit after hit, and miss after miss, these frustrations have existed with Pro.
In a nut shell, PTC listens but only when it's within their best interest. I like the idea of buying stock to vote out the special interest. However, remember PTC is a 30 year old company with preferred voting stock nowhere near us regular folks buying ability. That train has left the building. Sadly, my opinion is all your frustration is most likely falling on, not necessarily deaf, but indifferent ears. Hope is not lost though.
Having my PTC dance card for 26 years now, I believe it puts me in a postion to offer the following suggestions:
1. If you are able to have a Champion, a few Champions, a team of Champions in your respective organizations that are the Go-To people when people have questions...Do it. You will be better off for it. Pave the way for them to get trained to be Super-Users. Train as many as you can...as often as you can. Always be a learning organization. Do not rely on PTC or the Help line to give you the answers. 1989 was the last time I called 1-800-4PRO-HEL. In fact, I am not sure that is still the number.
2. Have regular internal User Group meetings. Be informed, be open, share your challenges and better yet, do not withhold your stellar techniques from your team or company. You will not gain any special recognition for being stingy or exclusive. Get really good at being good and staying as good as you can be on your particular release with your particular product/processes. Find five or six ways to get to an answer.
3. Humbly I offer this....re-direct the time your are expending attempting to get PTC to listen to the gripes getting great at navigating the obvious landmines within the software. I know it sucks that the code has always been half baked and rife with counter-productive boondoggles. It's always been like this....and unfortunately it always will be so. Learn the work-arounds, don't cheat, don't hack your way through if you can avoid it. I can safely say in my 30 plus year career, on a dozen or so CAD programs, I have rarely found there was no solution to a problem. Granted, we deal with GUI stupidity, ribbons, retina burning white backgrounds, copy cat functionality and other CAD hype...stick with it as no software is perfect.
4. Engage an outside Trainer or Super User once a year to give you a critique. They will have the fresh un-biased eyes that will see things you may have missed. At the very least they will ask questions that will challenge your processes and methods in the same way ISO auditors do.
Hope I didn't Flame On too much.
Amen Pastor Long! I too have applied the same philosophy when dealing with the "sin of software".
My favorite line is from your 3rd chapter - "retina burning white backgrounds" - what was PTC thinking?
It sounds like we started our pro-e careers around the same time and have worked through the same frustrations.
Bob
Creo has become a confusing software.
previously we knew exactly what a command would do, its not the same story now!
Ribbon..hmmm..can't say much....i hope they don't change the ribbon to something else by the time we get used to it .
hope Creo 3.0 brings some relief from bugs!
Pro/E used to be good and different..but now Creo ..huh!
oh PTC suddenly stopped our maintenace for the new license we bought only after 3 months, there is a new rule they say (PTC never cared to inform us when we were buying the license) we should have 51% license under maintenence..for maintenece to work..........so no Creo 3.0 for us...
Johny1-VisitorAuthor
When I kicked of this discussion in 2012, I had no idea that the PTC community also felt let tdown with the advent of CREO.
CREO 3 is now out in BETA, I haven't seen it because we dropped our maintenance back in 2012 also, so have saved a packet in maintenance payments over the last couple of years.
We have discussed wether to re-instate our maintenance with PTC but all our customers have stuck with wildfire 3, 4 & 5. Not one has moved to CREO, saya a lot that does.
We have no need or desire to move to CREO 3, its probably just a bug fix of CREO 2 anyway. Unless, of course, PTC have the balls to send me a copy with a temp license so that I can give them an honest and frank review. But we are talking about PTC here, where nothing is for free! So, come on PTC, put your money where yout mouth is.
As an aside, I would like to thank the PTC community for its support over this post. Your comments have been interesting and amusing. It has also amazed me that some people like the CREO interface. So thanks guys, I will keep you posted.
yes the interface is liked by many....the ones who have done some work on solidworks and inventor and solid edge...they like it..b'coz its similar.
Creo 3.0 even if its just a bug fix..would be a big step forward..but from what i have seen...they are some good enhancements.
I am not talking about the unite technology...
but the pure enhancements like highlighting missing reference, notes in WYSIWYG format, flatten quilt enhancement,...improvement in flexible modelling (which neatly helps in handling non-native CAD data.)
the unite technology..would be fully available in M030...
i am still more comfortable with wildfire 4.0....but the new people would surely like Creo 3.0..it is maturing..though very slowly.
now the max. limit for draft angle is +/- 89.9 deg.
chordal round is there.
improved reorder feature.
yes much more remains to be addressed...wish i knew how PTC decides what to bring in a particular release and what in the next release.....
...and rendering improvements (they say).
As a user with experiance of almost all the 3d cad systems, Solidworks, AutoCAD, Inventor , Catia, NX...
Creo is utter crap!
It's about 5 years behind Solidworks in terms of functionality and simplicity.
Everything is long winded.
The only offical benefit ive seen is that it is not as memory intensive as SW or inventor.
My biggest disapointment however is the inability to do a 3d sketch line.
I've heard peole say "it makes you think and capture design intent properly". Absolute rubbish, it just makes you think twice as long to complete something that should be done in seconds not minutes.
Short answer: YES
Long answer: as a Pro/E user since 1995 (!!), I have seen Pro/E go from THE hottest cad out there to an also-ran. The latest abomination they've foisted on us is embarrassing. Just plain embarrassing. The folks who started Pro/E and built it into a powerhouse, I guarantee they are ashamed to have any connection to this mess.
The functionality has not changed. For that I am grateful: I still contend Pro/E has the best pure modeling abilities in the cad world. The problem is, engineers don't live by modeling alone. We have to make tedious crap like drawings. The drawing portion of Pro/E, never very good, is now practically unusable.
None of our old mapkeys, some going back over a decade, don't work anymore. I'm not talking about the exotic mapkeys, just our simple ones. 'VR' for 'view right', how hard would it have been to leave that alone?
On another job, I had to learn a little of Autodesk Inventor. The basic modeling functionality shows heavy influence from Pro/E. But the similarities end there. The drawing portion is EASY to use, with lots of built-in time savers. Going back to Pro/E was like stepping into the Dark Ages of drawings.
Creo is a sick joke played on Pro/E users who don't have any choice. It requires more clicks to do the same things. I'm not a click-counter, I go by how fast I can actually work. And Pro/E today slows me down, period. Not just because I can't find anything anymore, but because the basic ideas about where to put things are screwed up.
If we could change cad packages, I would. Inventor, Solidworks, anything else but Pro/E. I am sick of PTC screwing around with a good product. They are rearranging the deck chairs while the ship is sinking.
Patriot_1776
"They are rearranging the deck chairs while the ship is sinking."
Most. Awesome. Quote. EVER!
I agree. I LOVE the power of Pro/E....but the interface now s#cks. Ad that to the fac that SW is eating PTC's lunch when it comes to having Engineers fresh out of school trained in SW instead of Pro/E, well, it's a recipe for disaster.
I met a guy at a vendor who was good at SW. Nice guy, but I sent him STEP files of some of the stuff I've done in Pro/E.....and he said he'd struggle to reproduce them, some he didn't even think he could do. They can't do graph functions, to, say, drive a VSS. So, that right there tells me Pro/E is ultimately more capable, but they need to fix the interface. And by "fix", I don't mean copying Micros#cks ribbon or other interfaces for idiots.
Thank you Frank, but I borrowed it from somebody else. I think the quote is actually 'Rearranging the deck chairs on the Titanic' or something like that.
Pro/E has some pretty impressive modeling abilities, but very few people ever really need them. Like using a graph to drive a sweep, that rarely comes up. Nice to know it's there, but still.
A buddy of mine has his own product design firm, we both used Pro/E for years. He said his clients are now 90% SW, where it used to be 90% Pro/E. PTC is getting clobbered, for good reason.
