Need help with repairing tiny surface gaps in a Creo 3.0 model
  • June 29, 2016
  • 3 replies
  • 2886 views
Creo users-
I've got a relatively simple Creo 3.0 model with imported geometry from a STEP file. The model is not a solid because of 4 tiny gaps. This would be quick work for an expert, which I am not. If someone can help, please let me know how to forward you the model.
Jim
Mahesh_Sharma
22-Sapphire I
June 29, 2016
James,
As Stephen suggested attaching the part will be a good option to look in this for steps. However you may try below steps if that fixes the geometry:
1. Open imported part
2. Select Import feature > Right click > Edit Definition
3. Select Icon for "Enter in IDD Editing Environment"
4. Select Repair
5. Finish the repair task and close IDD Mode.
It will repair the geometry if it was possible by simple repairing.
Thanks for all replies. My problem of the moment has been solved.
--Jim
