Projected drawing views
We've recently migrated to Creo 2 from Wildfire 4. On several occasions, I've either been creating a new drawing or revising an existing drawing from models created in Wildfire 4. As is necessary at times, drawing views need be broken to fit the model geometry onto the appropriate drawing format. Usually a general view has no issue with the "view break" process, but views that have been (or will be) projected from that broken parent view will either not show (for new drawings) or will disappear completely when revising an existing drawing.
I've tried several processes to fix this issue, but none seem to be an effective resolution. I've created a full general view then creating projected a view from that which works ok, but as soon as I break the parent view, the projected view disappears. I have created a full general view which I break before projecting the new view and the new view will not show. I've also revised a model then opened the drawing to make the appropriate drawing revision annotations and as soon as I save those revisions and/or regenerate, views that have been projected from a broken parent view disappear. I'm leaning toward drawing template stuff, but since I am basically just a user and not a Creo (nor Pro E) confgiuration type. I am at a loss. Anyone have any thoughts?
