Reg: Model Check Batch Mode in windows
- September 3, 2010
- 4 replies
- 1615 views
Hello Buddies
Good Day!!
Hope every one doing fine. I am using Pro/E Wildfire 3.0. I have succesfuly configured model check in interactive mode.
I am about to run a Modelcheck on some thousands of files. Going through on ptc help and the good article from ProfilesMagazin i decided to run modelcheck in batch mode. I use windows platform.
So that i have created a list of files using the
dir *.prt.* *.asm.* *.drw.* /b > list.lst
Then searched to the installation directory /bin. From there i have run modelcheck.bat. Modelcheck window appeared and i choosed "Batch mode" and browsed for the previously created list.lst file. Nothing happened.
It seems I did not get any model check out put report in my current directory. I am not sure Where I did mistake.
Kindly go through my attachment and help me to slove this issue
Any help will be appreciated.
Suganthan Rajamanickam
Pro-e System AnalystTrane Design Centre, India
Ingersoll RandThis thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
