Render trick with spheres
  • April 24, 2013
  • 2198 views
This is a Creo 2.0 M040 part. There is no reason to believe this will work on future releases as it is likely a bug.
But... for the meantime, I found a way to change the color of half a sphere with basic Creo render. If you ever -tried- to do this you know what a pain it can be.
The idea is that the color is applied with the sphere only revolved half way 'round. Change the color of the solid body and then apply a different color to the hemisphere. Then change the revolve to 360 degrees. Whallah!... you now have two appearances on a contiguous spherical surface.
Video Link : 3913
Mirror works too. Revolve 180 degrees, assign a color to the solid body, then a color to the hemisphere. Mirror that across the sketch plane you used, and it looks exactly the same as the way you showed in the video (just in case future releases fix this, if it is a bug).
That's good to know; Thanks!
