What is the PTC parameter for Quantity.
  • June 17, 2015
  • 5 replies
  • 7328 views
Hello Creo Experts,
I want to create user define parameter which contain actual part quantity+spare quantity.
which need to replicated in BOM table as (4+8)
where 4=actual part quantity used in assemble
and 8=spare quantity delivered with product.
spare quantity will be user input.
Thanks you in advance
Best Regards,
Manoj
that would be  &rpt.qty in the BOM table repeat region
mwaghmode1-VisitorAuthor
Thanks Ron St.Pierre,
How can assign the Value of quantity as actual quantity + spare.
so that my BOM quantity looks like 8+4.
somthing I will create Relation QTY= &rpt.qty+spare.
Assuming you have a bom table, in the table tab > repeat region, select relations then your repeat region in the bom table.
A menu will come up where you can write some programming.
Put this in your relations:
bom_qty=rpt_qty+4
Then in your bom table, the first row of your repeat region, select it (if you select switch dims in the table relation menu, you will see the parameters)
we need to change what is being reported in the bom table
Right mouse button > report parametets
select rpt... > rel... > User Defined > type in bom_qty
switch your symbols back then update tables.
ron
For the components that are supposed to show additional items in the BOM table, use the Include function in the assembly rather than manipulating the BOM table.
Thanks Don,
will it replicate in BOM?
My customer want it in BOM table only.
manoj
Yes, it will show up in the BOM. It will show in the Model Tree, but it will not be shown in the CAD model. I'm pretty sure the intent of the Include function is specifically for cases like yours. It's pretty easy to use, so, try it out.
Thank you all.
Appreciate  your quick help.
Dale_Rosema
Coming late to the discussion, but this was a similar thread where I only needed 1/2 of a part:
1/2 of a part
Patriot_1776
Interesting stuff here.  While I don't have a use for it as yet, I'll have to check it out, thanks!
Not tested, but I guess the following code will do the trick. Put it in repeat region relations.
IF exists("asm_mbr_spare_check")
    RR_SPAREQTY_CHECK=asm_mbr_spare_check
ELSE
    RR_SPAREQTY_CHECK=false
ENDIF
COPY_OF_SPAREQTY=asm_mbr_spare
IF COPY_OF_SPAREQTY<>"" & COPY_OF_SPAREQTY<>" " & RR_SPAREQTY_CHECK=true
    USER_QTY=rpt_qty+"+"+asm_mbr_spare
ELSE
    USER_QTY=rpt_qty
ENDIF
For the code to work &rpt.rel.USER_QTY needs to be defined in the repeat region column table, SPARE parameter needs to be defined on part level as a string, SPARE_CHECK parameter also at part level as boolean, and I think that's it.
If you don't like the SPARE_CHECK thing you can just weed it out, but I can't tell for sure the code is gonna work without it. Just have to test it.
