Can I create a custom callout in Creo Illustrate that points to an ASM instead of a PRT?
Hi all,
Is there a way to point my customized callout to the ASM instead of the PRT? The connector number metadata that I'm attempting to target is in the ASM (highlighted in structure) and not the PRT. Please see my annotation and screenshots below.
Tom
<annotation id="ref_des" hasLeaders="true">
<name>Ref_des</name>
<description>Reference Harness ID</description>
<tooltip>Reference Harness ID</tooltip>
<thumbnail url="itmtag_prop.png"/>
<leaders>
<line-style weight="1pt" color="#000000" halo="false" dashes="Solid" start="none" end="none"/>
</leaders>
<label canEdit="true">
<text font="Arial" size="10pt" color="#000000">
<useproperty category="Cable Parameters" name="REF_DES"/>
</text>
<shape type="rectangle" border="true"/>
</label>
</annotation>
