Creo Illustrate / Loosing page size / Loosing line settings for callouts
  • September 17, 2024
  • 4 replies
  • 1158 views
Hi all,
am I the only one who keeps losing 3D page sizes and line settings for callouts?
I mean, I define a 3D page size and then create the 2D image. Everything is fine. But after saving, closing and reopening, this page size is missing. This doesn't always happen, but againe and againe. Sometimes more often, sometimes less often.
In the same way, CI sometimes loses the line setting of callouts (white shaddow, line thickness).
It is annoyingWhat could be so difficult about storing the settings securely in a database?
Is there someone else havin the same problems?
Best regards
Ramon
(Siemens Energy)
Catalina
Community Moderator
September 23, 2024
Hi @Ramon_Bohne,
Thank you for your question!
Best regards,
Catalina | PTC Community Moderator
Hi Ramon,
I would recommend logging a case with tech support so the issue can be investigated properly as this shouldn't be happening.
In the meantime I would ask you note down any details of what was done to the file when this issue occurs, as tracking down the cause can be very difficult when the issue is not consistently reproducible.
8-Gravel
December 20, 2024
Hi Ramon
Did you get any further in this case?
My issues are very similiar. Every time I open any c3di file I have to choose the 3D page settings again.
My callouts are fine but the settings for the explode lines are lost as well, so I have to mark every explode line and set them from "thin" to "explode and reenter the values for the lines and gaps".
I'm curious to learn the reason for this.
Thanks in advance
Anja
Hi Ramon,
I sometimes have issues with explosion lines.  I may set up the line as a "dotted" line.  When I close out the application and come back to it, often times those dotted lines have changed to "centerline" or "solid".
It doesn't happen all the time, but just often to be an annoyance.
/r
John
Hi JHollis,
thank you for confirming the problem with the line settings.
And I have just opened a CI file and I have this line setting problem again:
Four of the seven lines have lost their setting! That is @#!@##! 😞
@unknown:  I accidentally marked the answer as a solution. Could you please undo that 🙂
Best regards
Ramon
Please contact tech support and log a case so this can be properly investigated.
Adrian
