3-Newcomer
April 23, 2025
Creo Schematics Datatable Not Appearing
  • April 23, 2025
  • 547 views
I am the Creo Librarian for my team and we had an issue recently that caused some folks Creo Schematics files to error during the syncing process.  They get the error "This file contains an item name that already exists in the design."  This had to do with a datatable issue and we have been able to correct most peoples files by going into that datatable and deleting the duplicate parts.  However, on some of the designs, the datatable in question is not appearing in the datatable explorer and I am not sure how to recover that datatable as the program is saying that it already exists within the design.  Is there a way to recover said datatable or am I looking in the wrong location to get it back into the datatable explorer.
Justin
Article - "Verification failure error, "This file contains an item name (xxxx) that already exists in the design", while synchronizing the deign with central catalog in Creo Schematics": https://www.ptc.com/en/support/article/CS161629
3-Newcomer
May 29, 2025
Hi VladimirN,
Unfortunately this did not fix my issue.  I tried to go into the internal catalogs of the packages that were having the issues, but the internal catalog was not showing the datatables in the internal catalog that I need to delete.  The error reports that they are in the design, but cannot be located in the datatable explorer.  This is my issue.
