6-Contributor
September 22, 2025
How to change the transition Speed between different Orientations
  • September 22, 2025
  • 355 views
Hello everyone,
When I select an orientation in Creo View (Home > Orientations), the model rotates to the specified orientation. This transition takes about one second. Is there a way to make the change instant (0 seconds)?
I checked the standard configuration options but couldn’t find anything. Since there are many properties available, it’s possible I overlooked the relevant one.
Thanks in advance for your help.
Try this option. The default for this setting is 1 second. We have it set to 0.1.
max_animation_time 0.1
Julian_L.6-ContributorAuthor
6-Contributor
September 23, 2025
I tried adding the setting into a few config files, but I don’t see this property anywhere. When I searched online it only showed up for Creo Parametric. Can you clarify where exactly I need to place it so it works with Creo View?
