Loading csv file error : It is necessary to complete one of the measured parameters
  • February 23, 2022
  • 1490 views
to continue my project I want to use Creo PRODUKT INSIGHT. Before starting the project I wanted to know how this works.
I created a simple CSV file. I also created a part as a sensor and defined the sensor parameters in a xml file.
(CSV, XML files and Errors are in the PDF)
When I load the CSV file in the assembly, I get the following error message.
 invalid input
I don't know what I missed. Which parameters do I have to complete?
Do you have any idea to fix this error?
Thanks a lot
Community Manager
February 24, 2022
Hi @ME_10219529.
To clarify, are you creating the CSV from ThingWorx?  If so, this question probably needs to go to the CREO forum to determine why it's erroring on that side.
Please confirm, and if needed, I will transfer this post to the appropriate forum.
--Sharon
Hi
Thanks for the feedback.
I don't use ThingWorx. I created the CSV file in Excel and wanted to load this file into Creo for my sensor.
Honestly In real project this CSV file is created via Python. But firstly I wanted  to try out how Insight Extension works, so I created and loaded a simple CSV file. I kept getting this error message when loading.
If my question needs to go to another forum, that would be great if you forward it.
