Use Preset Explode if source data is definied in the subassemlies and not only in the top-level
Expect to obtain the Creo Elements / Direct Modeling configurations of the subassemblies in the Preset Explode of Creo View
Description:
In the help you can read that "You can use the Preset Explode function only if the source data has top-level explode states defined".
This is the structure on Creo Elements / Direct Modeling.
The objects are stored in Windchill.
The visualization of Sub-Assy1 is a monlith visualization and the visualization of the Top-Level-Assembly /Tops-Assy is a strutcure visualization.
Only the Modeling configruation off the Top-Level-Assembly is available in Creo View in the
Preset Explode
We also expect to obtain the modeling configurations of the subassemblies in the Preset Explode of Creo View
