Use the environment variable "HOME" to costumize the User Interface
In the old ProE environment it was possible to use the variable "HOME" to set the the path for the login-ID. In this way ist was possible to make a configuration for the users in this folder. With the start of ProE were this configuration used to create the interface. For the new UI-File this configuration is not possible.
