What config.pro options affect the resolution of a PVZ file?
  • September 21, 2023
  • 1122 views
I know that SHADE_QUALITY #  will affect the resolution of the PVZ file,  I'm looking for specific config.pro options outside of the recipe file.  Thanks in advance!
If you are trying to reduce resolution, the recipe is what you want to use.
If you want higher resolution, maybe the accuracy setting in the start parts.  Do you have abs accuracy or relative accuracy?  With graphics cards and processors today, you may find that using absolute is good if you are currently using relative accuracy setting.
