May 21, 2012 5:02 PM UTC
alternate row shading
Dear Adepters,
We are using tables, based on Oasis models (in a DTD).
Is there a way to alternate row shading in tables display ? Maybe using 'tabstyle' attribute of <table>, Fosi (we have one) or Processing Instructions ?
Thanks for your answers,
Sébastien
    ssauvage1-VisitorAuthor
    May 23, 2012 4:43 PM UTC
    I've made an other ACL code wich hardly insert the processing instruction, only using ACL functions, and it works.
    The problem is it that it needs a user action or an initialization script to be called; that's not "clean".
    So the processing instruction, as Suzanne wrote, is valid for element <entry>.
    I don't understand why Fosi does not insert it. I will try to isolate the problem ...
    Sébastien
    Le 23/05/2012 18:29, Paul Nagai a écrit:My next strategy would be to try calling it from something very simple (maybe <para>) and applying a color to be sure you've got everything right and that the only thing you're fighting is the table row logic. If you can get para working, then apply color to a cell. Then see if you can get it to alternate. Then try the shading PI.
    Or some similar simplification of the problems at hand.
    On Wed, May 23, 2012 at 9:18 AM, Sébastien Sauvage <sebastien.sauvage@c-s.fr> wrote:
    Thanks Paul.
    I've tried return 1 and return "1". It leads to the same result : function is called (tested with an eval call) but shading is not applied (i.e. processing instruction is not inserted by FOSI).
    Sébastien
    Le 23/05/2012 18:04, Paul Nagai a écrit:Try
    return 1
    without quotes.
    OR try changing your test to
    attval to "#EQ#\1\"
    You may be getting a string vs. number mismatch.
    (I like the former if this is the issue.)
    You look very close, though. For what it's worth, here's an ACL we call from the root element as a system-func to check whether or not to use a US Letter or A4 collection of pagesets.
    function us_letter_exists(win,oid) {
    local exists = "no";
    if (oid_xpath_boolean($oid,'/descendant::us_letter')) {
    exists = "yes";
    } # if
    return exists
    } # us_letter_exists
    On Wed, May 23, 2012 at 6:17 AM, Sébastien Sauvage <sebastien.sauvage@c-s.fr> wrote:
    It's me again !
    I found a few responses.
    I've made an ACL function in a package called zzTables;
    function testOK($win, $oid)
    eval "call of testOK with win: $win and oid: $oid" output=>*;
    return "1";
    I updated my Fosi file with block:
    <att>
    <specval attname="zzTables::testOK" attloc="SYSTEM-FUNC" attval="1">
    <charsubset>
    <usetext source="!&lt;?Pub _cellfont Shading="gray5"?&gt;!"></usetext>
    </charsubset>
    </att>
    But I have two sections for "entry":
    one declared as this : <e-i-c gi="entry"> ...
    an other as this : <e-i-c gi="entry" context="thead" *=" row&quot;="> ...
    If I put the block in first section, function is called but shading is not applied ...
    If I put it in second block, function is not called ...
    I feel I'm near but I'm missing something.
    Thanks for your help,
    Sébastien
    Le 23/05/2012 14:39, Sébastien Sauvage a écrit:Hello Suzanne.
    Thank you for your response. It sounds very close to what I need.
    In what you offer:
    How to tell the FOSI to not insert text depending on the function return (typically 0 or 1). Is it with the value of "even" in your example ?How does the called ACL function know the context (oid ofentry element, rowct of row containing entry)?Sincerely,
    Sébastien
    Le 22/05/2012 19:15, Suzanne Napoleon a écrit:HiSébastien!
    The PI for shading is inserted in <entry> tags, so it must be applied to <entry> rather than <row>.In the FOSI fragment below, the e-i-c for entry calls an ACL function named oddeven, which determines whether to insert the PI for shading.
    Hope this helps! Please let me know any questions you may have.
    Best regards,Suzanne NapoleonSuzanne Napoleon@FOSIexpert.com "WYSIWYG is last-century technology!"
    <counter initial="0" style="arabic" enumid="rowct">
    <e-i-c gi="row"><charlist inherit="1" charsubsetref="block"><enumerat increm="1" enumid="rowct"></charlist></e-i-c>
    <e-i-c gi="entry" context="row"><charlist inherit="1"></charlist><att><specval attname="oddeven" attloc="SYSTEM-FUNC" attval="even"><charsubset><usetext source="!&lt;?Pub _cellfont Shading="gray"?&gt;!"></usetext>
    </charsubset></att></e-i-c>
    May 23, 2012 4:51 PM UTC
    When the ACL below returns even, a usetext outputs the processing instruction. When gentexttagdisplay is set to full, the PI shows in the Edit window. However, when the doc is previewed, the shading does not appear. I'm thinking the table needs to be output as a gentable for this to work.
    function oddeven(window,oid)
    $n=fosivar_value(window,"rowct.txt",oid);
    if (($n % 2) == 1) {return "odd"};
    if (($n % 2) == 0) {return "even"};
    May 23, 2012 5:11 PM UTC
    Thanks Suzanne.
    I'm not sure to well understand.
    Now my problem is not in the treatment of the function.
    It is that, like in the sample I post, the shading is not applied by the FOSI (processing instruction is not inserted).
    Sébastien
    Le 23/05/2012 18:51, Suzanne Napoleon a écrit:When the ACL below returns even, a usetext outputs the processing instruction. When gentexttagdisplay is set to full, the PI shows in the Edit window. However, when the doc is previewed, the shading does not appear. I'm thinking the table needs to be output as a gentable for this to work.
    function oddeven(window,oid){$n=fosivar_value(window,"rowct.txt",oid);if (($n % 2) == 1) {return "odd"};if (($n % 2) == 0) {return "even"};}
    May 24, 2012 2:10 AM UTC
    In my case, the processing instruction is inserted, but it is ignored.
    The only other approach I can think of is to output the table as a gentable. Go to my website at
    May 24, 2012 4:06 AM UTC
    Brute force idea: Purge and write the processing instructions to each table
    on each save. Or, using a slightly smaller hammer, provide a menu selection
    to do so manually before submitting a composition request. Or attach it to
    a compose hook (is that the right name for that hook?) ...
    On Wed, May 23, 2012 at 7:10 PM, Suzanne Napoleon <
    May 24, 2012 12:50 PM UTC
    Suzanne & Paul, thanks for your Help.
    Gentable way cannot be used in the context of my project, as there is a large volume of existing data, consisting in XML documents following specific DTD with Cals/Oasis model.
    Brute force way is, I think, the function I proposed in a previous mail, which is intended to be called from a custom menu:
    function ToBeCalledFromSpecificMenu()
    local $loidCaret = oid_caret();# should be a <table>
    local $loidArrChildren[];
    local $i = 0;
    local $loid = oid_null();
    local $lintCellId = 0;
    local $loidCellFont = oid_null();
    local $lintRowId = 0;
    local $lintRowIndex = 0;
    # todo : check that $loidCaret is a <table>
    oid_find_children($loidCaret, $loidArrChildren, 'entry', 0x04);
    for ($i = 1; $i <= count($loidArrChildren); $i++)
    $loid = $loidArrChildren[$i];
    # gets Cell Id
    $lintCellId = tbl_oid_cell($loid);
    # gets oid of cellfont pi, if any
    $loidCellFont = tbl_cell_fontpi($lintCellId, 'find');
    # gets row id
    $lintRowId = tbl_cell_row(lintCellId);
    # gets row index
    $lintRowIndex = tbl_row_index($lintRowId);
    if (($lintRowIndex % 2) == 1)
    # creates cellfont pi if it does not exist
    if (!oid_valid($loidCellFont))
    $loidCellFont = tbl_cell_fontpi($lintCellId, 'insert');
    # modifies shading
    oid_modify_attr($loidCellFont, 'Shading', 'gray2');
    else
    tbl_cell_fontpi($lintCellId, 'delete');
    This function inserts desired processing instructions and cleans existing ones.
    It works, but a method using the FOSI would be more flexible, because without user interaction.
    I'll have to content myself with this brute force solution.
    Sincerely,
    Sébastien
    Le 24/05/2012 06:06, Paul Nagai a écrit:
    Brute force idea: Purge and write the processing instructions to each table on each save. Or, using a slightly smaller hammer, provide a menu selection to do so manually before submitting a composition request. Or attach it to a compose hook (is that the right name for that hook?) ...
    May 24, 2012 3:39 PM UTC
    Consider the following "features" you might want to include in this
    solution. Some features might be mutually exclusive.
    Using a unique color name that is sure not to be used by an author. It can
    be defined to duplicate your gray of choice.
    Removing previous shading, if it exists, before writing current shading.
    (The previous feature helps this one.)
    Removing the shading on file close.
    Removing/Adding the shading on file save.
    Special handling for table header and/or footer rows.
    On Thu, May 24, 2012 at 5:50 AM, Sébastien Sauvage <sebastien.sauvage@c-s.fr<br/>> wrote:
    > *Gentable *way cannot be used in the context of my project, as there is a
    > *Brute force* way is, I think, the function I proposed in a previous
    > local $i = 0;
    > # gets Cell Id
    > # gets row id
    > # gets row index
    > # modifies shading
    > else
    > ones.
    > I'll have to content myself with this *brute force* solution.
    > Sincerely,
    > Sébastien
    >> ignored.
    May 24, 2012 3:40 PM UTC
    Special handling for spanned/merged cells.
