Nov 17, 2011 8:01 PM UTC
command line-print compose
We use Datalogics DL composer, and it has length limits to amount of pages
we can produce, typically maxs out at 2,700 pages. We have been testing
PTC's Print Compose and it is faster and go farther. The issue is we
programmically produce this 16,000+ page manual that is 210 megs large (6
million lines). Arbortext Editor cannot open the file, so we cannot print
it or find how many pages is the limit Print Compose before we have to cut
apart this manual.
Is there a command line or input folder we can toss this large file to have
it run.
    Nov 17, 2011 8:30 PM UTC
    Theoretically you should be able to open it in 64-bit Editor.
    Nov 17, 2011 8:47 PM UTC
    OTOH, if you anticipate needing to 'cut it apart' anyway, pick some logical division(s) within the book and turn it into a few file entities to begin. Call those entities in place of their individual content.
    In Editor, turn off 'View+File Entities', so that all you see in the window is the file icon(s). That should let you load almost any size manual (even in 32-bit). Just be certain File Entities is 'un'checked before loading the file that calls the entities.
    Steve Thompson
    +1(316)977-0515
    Nov 17, 2011 9:23 PM UTC
    thanks. That did not work. I still get "editor.exe [A12177] Out of virtual
    memory space" I have four gig and max the virtual space. Task manager show
    about 45% of the PF usage when it quits.
    I still like to know, if I can make it command line. We do not edit the
    file, I have a builder that we want to use to send it directly to compose
    without having someone open it
    d
    On Thu, Nov 17, 2011 at 11:47 AM, EXT-Thompson, Steve <
    steve.thompson2@boeing.com> wrote:
    > OTOH, if you anticipate needing to ‘cut it apart’ anyway, pick some
    > begin. Call those entities in place of their individual content.****
    > In Editor, turn off ‘View+File Entities’, so that all you see in the
    > (even in 32-bit). Just be certain File Entities is ‘un’checked before
    > loading the file that calls the entities.****
    > *Steve Thompson*
    > +1(316)977-0515
    > *From:* Benton, Ed L [
    18-Opal
    Nov 17, 2011 10:04 PM UTC
    Hi Doug--
    Try this from a Windows command prompt:
    "C:\Program Files\PTC\Arbortext Editor\bin\editor.exe" -c "print"
    filename.xml
    That should print in batch mode, without opening the doc in an Editor
    window.
    --C
    Clay Helberg
    Senior Consultant
    TerraXML
    Nov 17, 2011 10:08 PM UTC
    That sounds very good. Off to testing.
    d
    Nov 23, 2011 3:09 AM UTC
    Clay,
    This worked like a charm. However, is there a way to define the output file name (pdf output) without having to be prompted for it?
    18-Opal
    Nov 23, 2011 5:30 PM UTC
    Hi Joseph--
    You might have to write an ACL script to set this up. In the script, you
    would need to define an array of parameters that you can pass to the
    compose::compose_for_pdf() function, and add the output file name you
    want to that array. Here is a sample script that does the bare minimum
    setup, to generate the PDF in the same location as the source file, with
    the same basename and ".pdf" extension. (In other words, "MyDoc.xml"
    will be published as "MyDoc.pdf".)
    # batch print a document
    require compose;
    function batch_print(doc = current_doc()) {
    # init params
    local params[];
    # derive output filename
    params['outputFile'] = compose::set_output_file( doc, 'preview',
    ".pdf");
    # set interactive off so it knows we're in batch mode
    params['interactive'] = 0;
    # add stylesheet param
    params['stylesheet'] = compose::get_doc_stylesheet(doc,
    "printstylesheet", "pdf");
    #compose
    compose::compose_for_pdf(doc,params);
    # go ahead and call the function now
    batch_print();
    If you put this code into a file batchprint.acl, you should be able to
    invoke it in a batch file by putting "source batchprint" into the -c
    parameter argument, like so:
    "C:\program files\PTC\Arbortext Editor\bin\x64\editor.exe" -styler -c
    "source batchprint" Document1.xml
    HTH
    --Clay
    Clay Helberg
    Senior Consultant
    TerraXML
    Feb 21, 2018 7:42 PM UTC
    Are these functions and syntax relevant to Arbortext Editor 6.0?
    I found an article on the PTC community, Document - CS233804, that uses fewer local params, but I'm having difficulty getting either example to run.
    function test_cfg::test2() {
      local params[];
      params[ "outputFile"  ] = '[path_to]\test-out.pdf';
      params[ "stylesheet"  ] = '[path_to]\doctypes\axdocbook\axdocbook.style';
      local rc = compose::compose_for_pdf( current_doc(), params );
      return rc;
