Doing manual edits on a 4 digit text number. Need macro for IsoDraw to match manual text edit
  • November 29, 2016
  • 1936 views
Doing manual edits on a 4 digit text number but noticed when I call up the Object info that the name shows the previous text. For example change a text 0401 to 0462. When I do a Object info it still shows 0401 in the name (see attachment). So I want to develop a macro that will change the object info name to match the manual edit. In this case 0462. Here's the macro code I have so far:
Here's the code:
Macro change_name_in_object_info
Define el as Element
Define Text as String
Define output as String
Define text1 as string
el=ActiveDoc.FirstSelectedElement
Select if Type is "Text"
        WHILE (Exists (el) = true)
text1=Text
el.info.name = text1
el = el.nextSelectedElement
        End While
select none
End Macro
Best answer by thendricks
Main issue was you were doing your select after assigning value to el. Try this.
    Define Temp as string
    el = ActiveDoc.FirstSelectedElement
    While (Exists(el) = true)
        Temp = el.text.string
        el.Info.Name = Temp
        el = el.NextSelectedElement
    End While
    Select None
End Macro
        el.Info.Name = Temp
    End While
    Select None
End Macro
RubenCote1-VisitorAuthor
Trevor the code you posted worked like a charm. Great as always! Thank you for helping out.
