Inserting a cross-reference "choose a target" UI question
Do your authors prefer a list, table, or tree view of potential targets for
cross references? Does it vary depending on task?
Paul Nagai
    18-Opal
    March 4, 2013
    Hi Paul--
    I'd be fascinated to find out if anyone has actually tested this, by
    offering more than one option and checking which produces the best user
    experience. I fear that most writers have only ever had exposure to one
    of these options, and thus would have trouble articulating a meaningful
    preference. (When you ask someone if they would prefer something they've
    never tried, you are essentially asking them to make a prediction, which
    may or may not be accurate.)
    Is there any chance you could do some proper UX testing to see how they
    do using each of the options? Or maybe you could provide all three
    options and let authors choose their view via a tabbed interface or some
    other mechanism?
    --Clay
    Clay Helberg
    Senior Consultant
    TerraXML
    1380 Forest Park Circle, Suite 100
    Lafayette, CO 80027
    Does the number of potential targets have a bearing in choosing the preferred method?
    Our documents use a 'part.section.subsection.article.sentence.clause.subclause' number scheme. Our authors initially asked for a list but changed their minds because of the size of the list, up to approx. 8,000 entries in our large books. We finally ended up implementing an external tool that allows them to type in the target number and returns the corresponding id value for them to copy/paste into the refid attribute.
    That's more overhead for me, keeping the tool 'data' current, but less time for the authors. Since they out-number me by 20 to 1...
    David
    David S. Taylor
    Project Manager, Structured Information
    Production and Marketing | Building Regulations | NRC Construction
    Building M-23A, Room 114 | 1200 Montreal Road | Ottawa, ON | K1A 0R6
    Telephone: 613-990-2731 | Fax: 613-952-4040
    David.S.Taylor@nrc-cnrc.gc.ca<">mailto:David.S.Taylor@nrc-cnrc.gc.ca>
    naglists1-VisitorAuthor
    I do suspect target count is important. If I'm linking to a target in the
    content I'm editing (likely a smallish, manageable chunk), then a simple
    list or table seems desirable. If I'm linking to a target not present in
    the content I'm editing, then I will want a tree representing the possible
    targets for the entire document.
    I didn't mention the possibility of a database (multiple lists/tables
    separated by target type) but I guess that's relevant too. But table
    titles, for example, are repeated and differentiating / providing context
    becomes complex or not-usable without bringing yourself back to a tree ...
    anyhow.
    But ... those are my preferences ... but I neither author nor think like an
    author in many cases so ...
    Clay: UX Testing. I like it. I don't ever get to do it. I have had several
    conversations over the last few whiles about "telemetry" as one of my
    industry pals calls it ... programmatic monitoring of user and application
    behavior. Logging. Counting. Whatever you want to call it. That might be
    fun (and smart) to try and build into SOMEthing I'm working on. My buddy
    uses it when he can to be able to provide evidence to engineering (he's in
    support) about where the code is generating the most customer
    calls/knowledgebase searches.
    David: How do you keep your data current? Do you have agreed upon "linkbase
    refresh" points in the authoring cycles? Or is it something authors request
    when needed? Or do you run a nightly job? Or some other strategy?
    On Mon, Mar 4, 2013 at 7:38 AM, Taylor, David S. <
    > preferred method?****
    > Our documents use a
    > copy/paste into the refid attribute.****
    > time for the authors. Since they out-number me by 20 to 1…****
    > David****
    > *David S. Taylor*
    > *Project Manager, *Structured Information
    > Production and Marketing | Building Regulations | *NRC Construction*****
    > Building M-23A, Room 114 | 1200 Montreal Road | Ottawa, ON | K1A 0R6****
    > *From:* Paul Nagai [
    > question****
    > for cross references? Does it vary depending on task?
    > Paul Nagai
    Hi Paul,
    Yes, there are specific points in our document development process (DDP) where the 'linkbase' is updated.
    The authoring in our process actually ends about the midpoint of the document's development. The document is passed to editors and translators for completion. During editing and translation any missing or incorrect links are fixed and the linkbase updated. Authors are provided an updated draft document to confirm that edits and translation are technically accurate and links are correct. (Depending on the complexity of the document, this 'cycle' may repeat as necessary.)
    Once an author passes a document to editing and translation he/she continues to implement further changes to that document for its next scheduled release. The most up-to-date version of the linkbase is always available for this continuous authoring.
    David Taylor
    Thanks, David. Sounds about right.
    On Tue, Mar 5, 2013 at 8:07 AM, Taylor, David S. <
    > Hi Paul,****
    > where the 'linkbase' is updated.****
    > document, this 'cycle' may repeat as necessary.)****
    > available for this continuous authoring.****
    > David Taylor****
    > UI question****
    > anyhow.****
    > an author in many cases so ...****
    > calls/knowledgebase searches.****
    > "linkbase refresh" points in the authoring cycles? Or is it something
    > authors request when needed? Or do you run a nightly job? Or some other
    > strategy?****
    > david.s.taylor@nrc-cnrc.gc.ca> wrote:****
    > Our documents use a
    > David****
    > *David S. Taylor*****
    > David.S.Taylor@nrc-cnrc.gc.ca****
    > question****
    > Paul Nagai
