Integration Between Codebeamer and Slack
I am trying to integrate Codebeamer with slack and in the process the bot user token is showing invalid. The slack team has confirmed that the token is valid and that the problem is from the codebeamer side. Can someone please help me with this issue. The token is showing invalid in codebeamer for me.
