Nov 21, 2011 5:37 PM UTC
Edit Drawing Program with JLink or Toolkit
I have a issue about edit the code I find under "Drawing Program". I try to use com.ptc.pfc.pfcModel.ProgramExportInstructions but this ones only causes a jxthrowable. With parts and asemblys everything works ok.
So I learned that "ProProgram" and "DrawingProgram" are different things. I need a way to export and to reimport the code, because I want to link the parameters from a drawing to parameters of the current model in the drawing. I think the some parameters would help to simplify the search and handle of drawings inside of a pdm system.
I don't find a way to change these code in Toolkit too. So have everyone do this before, or have a idea how to do it?
Best regards,
Eike
Nov 21, 2011 6:40 PM UTC
Eike,
I would create a ticket with PTC TS to ask how to export the Drawing Program. I also saw the documentation for ProOutputFileWrite that states the following:
ProMdl<proobjects_h.html#promdl> model
/* (In)
A pointer to the model.
* PRO_IGES_FILE<proutil_h.html#pro_iges_file> and PRO_DXF_FILE<proutil_h.html#pro_dxf_file> work for drawings only.
* PRO_PROGRAM_FILE<proutil_h.html#pro_program_file> works for parts and assemblies only.
* For CL data, this pointer must reference a manufacturing model.
Patrick Williams | Engineering Systems | o: 616.698.3766 | c: 616.947.2110
[cid:image001.jpg@01CCA84A.B40D0460]
Nov 22, 2011 9:11 AM UTC
Also Pro2dImportCreate() has entry for program as -
PRO_PROGRAM_FILE = 4,
/* Import & Export */
FV_01
Nov 22, 2011 4:57 PM UTC
Hi all,
Eike,
There is an old pro/etrick to use config.pro pro_editor setting to point it to your IO stream processing utility. The utility has to use blocking IO.
HIH.
Feliks.
In Reply to Eike Petersen:
Best regards,
Eike
Nov 23, 2011 9:40 AM UTC
@ Patrick : Thank u very much.
@ Rahul : Thats a nice idea, but same problem as write in file, only support :
  • PRO_STEP_FILE
  • PRO_SET_FILE
  • PRO_IGES_FILE
  • PRO_MEDUSA_FILE
  • PRO_DXF_FILE
  • PRO_DWG_FILE
@ Feliks: Very nice idea, I try it : )
((Aunt Edit: change J.D. to Feliks, sry Feliks ^.^ Thank you! ))
Jan 10, 2012 6:21 AM UTC
@Eike:
Did you tried method suggested by Feliks?
Will it be possible for you to share more details on how to use to it?
Rahul
Feb 6, 2012 11:39 AM UTC
Weeks later,
Everything works allright. Its not a perfekt solution, an API function would be better, but it works : )
I've used a C# Program to get the Input and Output stuff.
using System;
using System.Collections.Generic;
using System.Linq;
using System.IO;
using System.Text;
namespace PROTKIO
class Program
static void Main(String[] args)
String dir = Environment.GetEnvironmentVariable("appdata");
String pathProTk = dir + "\\FOLDER\\protkio.txt";
String pathPtoTkFini = dir + "\\FOLDER\\proiotkfini.txt";
if (args.Length > 0)
Console.Out.WriteLine("Something is going on");
StreamWriter myfiniWriter = File.CreateText(pathPtoTkFini);
myfiniWriter.WriteLine("0");
myfiniWriter.Close();
StreamWriter myWriter = File.CreateText(pathProTk);
String line = ";
using (StreamReader myReader = new StreamReader(args[0]))
while ((line = myReader.ReadLine()) != null)
myWriter.WriteLine(line);
myWriter.Close();
myfiniWriter.WriteLine("1");
Console.Out.WriteLine("Ready for wainting");
Boolean wait = true;
while (wait)
try
String finiline = ";
using (StreamReader myFiniReader = new StreamReader(pathPtoTkFini))
finiline = myFiniReader.ReadLine();
if (finiline == "2")
wait = false;
catch (Exception ex)
Console.Out.WriteLine("Uuuuh ... got an exception : ) I think another program is writing my files");
Console.Out.WriteLine("Hei ho someone has freaking my code. Time to write back");
StreamWriter myNewWriter = File.CreateText(args[0]);
using (StreamReader myReader = new StreamReader(pathProTk))
myNewWriter.WriteLine(line);
myNewWriter.Close();
Console.Out.WriteLine("Finished the crapwork");
else
Console.Out.WriteLine("You need more arguments");
Best regards,
Eike
