Node numbering and fatigue
We have a simple model (plate with hole)
It has 2 loadsets, Loadset 1 and Loadset 2.
We create and save the mesh
We then carry out a linear static study first with loadset 1 - Analysis1. Then with Loadset 2 - Analysis2. i.e. 2 distinct analyses (not summed or combined).
and the constraints are unchanged
The saved mesh is reused and therefore we now have 2 results directories with consistent mesh.
We can then carry out a fatigue analyis using the results from analysis 1 and then 'append' a fatigue analysis using results from analysis 2.
(sometimes loads move about, hence 2 analyses. The real study requires many more load positions than 2 but this is keeping it simple and manually debug-able using the ascii output)
Now a description of the problem encountered ...
The h-element section of the .neu files, first 6 elements:
h-elements 840   Analysis1
1 6 22884 23759 23753 23762 0 0 0 0
2 -12 23759 23943 23753 23762 23954 23946 0 0
3 6 23759 23758 23943 23954 0 0 0 0
4 -12 23758 23945 23943 23954 23952 24165 0 0
5 6 23758 23757 23945 23952 0 0 0 0
6 -12 23757 23756 23945 23952 23766 23951 0 0
h-elements 840   Analysis2
1 6 23368 24237 24231 24240 0 0 0 0
2 -12 24237 24421 24231 24240 24432 24424 0 0
3 6 24237 24236 24421 24432 0 0 0 0
4 -12 24236 24423 24421 24432 24430 24643 0 0
5 6 24236 24235 24423 24430 0 0 0 0
6 -12 24235 24234 24423 24430 24244 24429 0 0
Why oh why oh why has Mechanica changed the node numbers !!!
Third party fatigue solvers don't like this ,,,, and these are the ones that are supposed to work with Mechanica.
Apart from the pair highlighted which have a difference of 484 in the node numbers, all other pairs of node numbers have the difference of 478.
From the h-node section of the .neu file the pairs of node numbers have the same co-ordinates (reasonable proof that the mesh is consistent)
I have only just started this investigatation into why our life contours are poor and am hoping for a revelation regarding this. Do I really have to write code to work on the output files to change this? what is the obvious user error?
Anyone? (even PTC development he asks tentatively)
Why can't you run both load sets in a single analysis? Still not summed or combined.
346gnu13-AquamarineAuthor
It is a contact analysis.
Each load has it's own input time history and/or
There is a geometry change (this is a mechanism, easiest to visualise a conrod in a single stroke engine)
The stress state at each time step gives us a stress history. We therefore modify positions/loads for the next part of the history. This history is one of the inputs to the fatigue study.
We are ignoring results near contacts (amongst other 'reasonable' assumptions), .
I believe we have done this before by setting up each load case in individual analysis, then running both analysis in a design study. In these cases the mesh geometry and numbering is preserved.
